dzarn
Everything posted by dzarn
  1. Not exactly a Google Home topic, so please move it if there's a better forum. Is it possible to capture events from my Nest smoke detectors with the ISY? Specifically, if an alarm goes off, I would like to turn off some devices (my whole house fan) and turn on all lights. I have the ISY portal, and have my ISY connected to Google Assistant already. Thanks!
  2. paulbates, thank you - your reply gave me what I needed to figure it out. The DNS server I had been using is apparently no longer valid, which the NTP query tipepd me off to. Updated that and we're in business. Thanks again!
  3. My ISY is showing offline in the my.isy.io portal page. The ISY itself shows Offline, Registered under Portal Integration - UDI, with only a refresh button. It's been this way for over a week. I've tried deleting the ISY and re-adding it from the portal page, along with updating from 4.5.4 to 4.6.2, with no change. What am I missing? How do I get things talking again?
  4. I hadn't correlated it with the programs, but that's what it is. Mine is an Enerwave ZW500DM switch. Like above, manually controlling it from the admin console works fine. I have a program setup so that a KeypadLinc button can control the Z-wave switch, and that's what triggers the Failed Comm alert. I'm on 4.5.4.
  5. Is there any way to disable the 'Failed Communicating with device' alerts in the admin console, at least for issues that happen while the console isn't actually open? Every time I open the console I have to click through about 40 of these. They're all for 2 Z-wave switches, which both work without issue, so I've never bothered trying to figure out why the ISY doesn't like them. But the alerts are annoying
  6. I second the request to make the only ISY the preferred - this had me beating my head against the wall this weekend.
  7. dzarn posted a topic in ISY994
    Is there a maximum length for the cable between the ISY & PLM? I'm using a 2413S, the ISY has its own power supply. Thanks!
  8. I would like to make the light in my bedroom come on to only 50% when turned on from dusk to dawn, and 100% during the day. The light is on a FanLinc, if that matters. I have 2 programs setup now, but apparently I'm missing something. The light stays at 100% on level all the time. I'm turning it on with button A on a 6-button KPL, or an 8-button RemoteLinc, both of which are controllers in the 'Master Bed Light' scene? Any ideas what's wrong? OnLevel Day: If Time is Sunrise + 15 minutes Then In Scene 'Master Bed Light' Set 'Master Bedroom FanLinc-Light' 100% (On Level) In Scene 'Master Bed Light' Set 'Master Bedroom FanLinc-Light' 0.2 Sec (Ramp Rate) Else - No Actions - (To add one, press 'Action') OnLevel Night If Time is Sunset - 15 minutes Then In Scene 'Master Bed Light' Set 'Master Bedroom FanLinc-Light' 50% (On Level) In Scene 'Master Bed Light' Set 'Master Bedroom FanLinc-Light' 2.0 Sec (Ramp Rate) Else - No Actions - (To add one, press 'Action')
  9. Here's what I am using. Only had it going for a couple days (since 3.2.0) but so far no problems. The only thing I haven't got in place yet is a scene to control the keypad LEDs, as right now the LED can be off when the fan is on and vice versa. Total of 5 programs - 4 to cycle between speeds, and 1 to turn off on a double-click (this one isn't required, just for convenience). The cycle programs are all identical except for respective speeds. I have one using a KPL button, and one using a RL2 button. Living Room Fan Off If Control 'Living Room KPL - B' is switched Fast On Or Control 'Living Room KPL - B' is switched Fast Off Then Set 'Living Room FanLinc-Fan' Off Else - No Actions - (To add one, press 'Action') Living Room Fan Cycle Off-Low If ( Control 'Living Room KPL - B' is switched On Or Control 'Living Room KPL - B' is switched Off ) And Status 'Living Room FanLinc-Fan' is Off Then Set 'Living Room FanLinc-Fan' Low Else - No Actions - (To add one, press 'Action') Living Room Fan Cycle Low-Med If ( Control 'Living Room KPL - B' is switched On Or Control 'Living Room KPL - B' is switched Off ) And Status 'Living Room FanLinc-Fan' is Low Then Set 'Living Room FanLinc-Fan' Med Else - No Actions - (To add one, press 'Action') Living Room Fan Cycle Med-Hi If ( Control 'Living Room KPL - B' is switched On Or Control 'Living Room KPL - B' is switched Off ) And Status 'Living Room FanLinc-Fan' is Med Then Set 'Living Room FanLinc-Fan' High Else - No Actions - (To add one, press 'Action') Living Room Fan Cycle Hi-Off If ( Control 'Living Room KPL - B' is switched On Or Control 'Living Room KPL - B' is switched Off ) And Status 'Living Room FanLinc-Fan' is High Then Set 'Living Room FanLinc-Fan' Off Else - No Actions - (To add one, press 'Action')
  10. Installed 3.2.0 and it worked perfectly. No lost programs, and was able to add my FanLincs without trouble. Finally have 1 button controlling my fan (instead of 4). Thanks Michel (and everyone else at UD)!!
  11. Gotcha, thank you for the tip. One more question then - the LampLinc looks like it has Sense, so you can use the local load's on/off switch, but there's no info about setting it up as a controller. Does this mean it can control itself locally by sensing the load, but it doesn't send that out to the rest of the world, i.e. can't trigger a scene? If that's the case, I could setup a program to check the status and then trigger the ceiling fans from there, right? Is there any way to disable the dimming on the LampLinc, so it's always either 100% on or 0% off, since it'll have a fan hooked up to it? Thanks!
  12. Couple questions I'm hoping can be answered here. Basically I want to be able to detect my fireplace fan turning on (it's thermostatically controlled), and trigger my ceiling fans to turn on. SynchroLinc can do this, but it's controller-only, right? I can't also turn off the fireplace fan using this? ApplianceLinc can turn it on and off, but can it sense the load coming on on it's own and trigger a scene?
  13. We were actually sending identical messages to several different phones on all 4 major networks. T-Mo, Sprint & Verizon came through immediately, AT&T would come in hours later, but with no indication that it was hours late.
  14. I don't have a solution, but I've seen the same thing happen - the message sends fine, but somewhere along the line takes a nap for several hours. Then it pops up on the phone like nothing happens. The only way we were able to 'prove' it was to put a timestamp in the message body. So it's definitely not just you.
  15. I've picked up a couple of FanLincs, and currently have them linked to a KPL & RemoteLinc2 manually (i.e. not using ISY). I added the FanLinc to the ISY, and it sees the light control fine but the fan portion doesn't show up at all. Is there any way to jury-rig this until official support is added? I'm fine manually setting the on level to X value to change the fan speed, rather than having an option for Low/Med/High. Basically is there any way to get the ISY to at least see the unsupported device, so I can play with sending commands via program or whatever?
  16. Not sure if there's other apps, but I use Conductor and am very happy with it. Especially like the ability to tie widgets to devices/programs/scenes - makes it easy to have a homescreen button to bump up my heat when I leave for home. I have a universal remote that I use for TV/Audio/Myth, and I just setup the DVD option to control the ISY. Took a bit of trial and error to find a manufacturer code that both worked with ISY and didn't affect other devices (i.e. turn off the TV randomly). I only use it to control a couple things (light and fan in the TV room), but it works great. I have a few buttons mapped to the light so I can do Off/25%/50%/On I haven't run into any that don't. I think sometimes when totally new devices come out there can be a bit of a lag before the ISY firmware is updated for them, but it's usually pretty quick.
  17. Not problems per se, more just a question. To put it more generically: Say I have 2 programs, ProgramA and Program B: ProgramA: If LightSwitch1 is switched On And ProgramB is True Then Set Light1 On Else Set Light2 On ProgramB: If $Variable1 is 1 Then Send Notification to email content "The variable is 1" Else Send Notification to email content "The variable is not 1" So if I run ProgramB at 10 AM, it sends me a notification based on $Variable1, and the status of ProgramB (true/false) is updated. If I then run ProgramA at 11 AM, it uses the value from when ProgramB last ran, but doesn't actually run ProgramB. So if Variable1 changed between the running of ProgramB and ProgramA, say at 10:30 AM, ProgramA uses the old value of ProgramB, which is incorrect. Is there any way to have ProgramB run when checked by ProgramA, thus updating its status as of the time ProgramA runs? I know I could put a schedule on ProgramB, but I'd rather only have to update the schedule on ProgramA. Hopefully that makes more sense. Thanks, Drew
  18. Hey Tim, Yep, I left something out. In my troubleshooting I took out the schedule condition for the watering program, and forgot to add it back in. In the If it also has "On Mon, Thu Time is 9:30:00 PM". So it only runs at 9:30 PM if the Rain Delay program is true.
  19. **Edit: Added in the schedule on the Watering program I'm setting up a program to run my sprinklers, and I have a RainDelay variable that I can set for X days (gets dropped by 1 nightly at midnight). I have a program Check Rain Delay which checks if there is a delay, and if so, emails me (this way I can have an idea of how long it's been since the lawn has been watered). So in the actual watering program, I first check the result of the Check Rain Delay program. However, this just checks the last result from the Check Rain Delay run, it doesn't actually run the program first, then check the result. Is there any way to have the watering program run the check program, then get the result back? Or do I have to wrap this all in another program that runs the check, then runs the watering? Thanks for your help!! Check Rain Delay Program: If $RainDelayDaysLawn is 0 Then - No Actions - (To add one, press 'Action') Else Send Notification to 'Drew Email' content 'Rain Delay Info' ---------------------------- Watering Program: If On Mon, Thu Time is 9:30:00PM And Program 'Check Rain Delay' is True Then Set 'Irrigation / Sprinklers / Front Yard' On Wait 30 minutes Set 'Irrigation / Sprinklers / Front Yard' Off Set 'Irrigation / Sprinklers / Back Yard West' On Wait 30 minutes Set 'Irrigation / Sprinklers / Back Yard West' Off Set 'Irrigation / Sprinklers / Back Yard East' On Wait 30 minutes Set 'Irrigation / Sprinklers / Back Yard East' Off Else - No Actions - (To add one, press 'Action')
