AT&T to end email-to-text ×
hoopty
  • Posts
    53
Everything posted by hoopty
  1. Same here. Lightning took out my setup and I really had no option except to start over with something else. It really wasn't that difficult and if you take care laying it out, it can be done up to look pretty nice when it's done. I'd even consider making some for anyone who isn't handy w/ a soldering iron. Hit me up.
  2. The SMS standard limits the character count to 160, it's not by carrier. (Twitter has 140 limit)
  3. Well, those numbers don't look right do they... I'm not sure why you wouldn't have any heating cycles, unless there's something wrong w/ the program. Have you seen the variable increment when a call for heat is initiated? Also, if the report is showing zero, but the variable actually has a different value, maybe your custom notification is calling the wrong variable. Just some thoughts. As for the math, here is how it breaks down. The counter itself increments by one every five seconds that the HVAC is running. So one minute would equate to a count of 12 (or 60/5). The way I calculate for the report is like this: Lets say our count for the day ended up being 3197 1. Make the xxx_Hr variable equal the total count for the day. xxx_Hr = xxx_5sec = 3197 2. Divide xxx_Hr variable by 720 to get the number of hours it ran. (720 = 12 counts per minute * 60 minutes/hr) xxx_Hr/720 = 3197/720 = 4.4402777777 - The variables always round down so xxx_Hr ends up equaling 4. 3. Make the xxx_Min equal the total count for the day. xxx_Min = xxx_5sec = 3197 4. Divide xxx_Min by 12 to get the number of minutes it ran. (again, 60/5 based on the 5 second count interval) xxx_Min = 3197/12 = 266.4166666 - Again, the variable rounds down to 266. 5. Then I set the temp variable to equal xxx_Hr. temp = xxx_Hr = 4 6. Multiply temp by 60 to get the number of minutes in the hours it ran. temp*60 = 4*60 = 240 7. Subtract temp from xxx_Min to obtain the remainder of minutes after the hours are calculated. xxx_Min - temp = 266 - 240 = 26 So you get a run time of xxx_Hr and xxx_Min or 4 Hr and 26 Min(s). And if you change the counter interval, you will have to re-calculate the numbers for 12 and 720. I hope this helps.
  4. I ran a few more tests and it was no more than a second off over a 3 minute period. And that could be attributed to several things such as lag in the interface or difference in start time of prog and timer.
  5. Teken, did you ever get this to work for your setup?
  6. After reading that thread, I don't see how. This program doesn't repeat the wait statement. The wait occurs first and is only there to allow for the first five seconds to pass before the variable is incremented. After that, the variable +1 is will repeat every 5 seconds.
  7. I wonder if you change the wait time to more than 1 second, if that would have any affect on it. Maybe you wouldn't see the one second going on behind the scenes, if the wait time were longer than the propagation time... just a thought.
  8. Yes. For 2 of the 3 anyway. You would need to change /= 12 to /=10 and /= 720 to /= 600. Leave *= 60 alone.
  9. Well, that's a bit more complicated isn't it? I think you can attack it a couple of different ways. First, you could just duplicate all the variables and programs 5 times and label them such that you can tell them apart. i.e. heat1_cycles_daily, heat2_cycles_daily, etc... This method is the easiest to pull off and understand, but I don’t think that is the most efficient way of doing things. But depending upon the resource drain, it might not be a bad idea, as you can set each end of day to run independently at different times. The second option would be more complicated. You'd still need quite a few more variables and you'd have to modify the calc and the send/reset program pretty significantly. Without knowing your complete setup and expected outcome for this, here’s how I would start out: Define variables (non-state): $Cool1_Cycles_Daily $Cool2_Cycles_Daily $Cool3_Cycles_Daily $Cool4_Cycles_Daily $Cool5_Cycles_Daily $Heat1_Cycles_Daily $Heat2_Cycles_Daily $Heat3_Cycles_Daily $Heat4_Cycles_Daily $Heat5_Cycles_Daily $Cool1_Cycle_Time_Daily_5Sec $Cool2_Cycle_Time_Daily_5Sec $Cool3_Cycle_Time_Daily_5Sec $Cool4_Cycle_Time_Daily_5Sec $Cool5_Cycle_Time_Daily_5Sec $Heat1_Cycle_Time_Daily_5Sec $Heat2_Cycle_Time_Daily_5Sec $Heat3_Cycle_Time_Daily_5Sec $Heat4_Cycle_Time_Daily_5Sec $Heat5_Cycle_Time_Daily_5Sec $temp $Cool1_Cycle_Time_Hr $Cool2_Cycle_Time_Hr $Cool3_Cycle_Time_Hr $Cool4_Cycle_Time_Hr $Cool5_Cycle_Time_Hr $Heat1_Cycle_Time_Hr $Heat2_Cycle_Time_Hr $Heat3_Cycle_Time_Hr $Heat4_Cycle_Time_Hr $Heat5_Cycle_Time_Hr $Cool1_Cycle_Time_Min $Cool2_Cycle_Time_ Min $Cool3_Cycle_Time_ Min $Cool4_Cycle_Time_ Min $Cool5_Cycle_Time_ Min $Heat1_Cycle_Time_ Min $Heat2_Cycle_Time_ Min $Heat3_Cycle_Time_ Min $Heat4_Cycle_Time_ Min $Heat5_Cycle_Time_ Min Programs: Cool1_Cycles/Run_Time If Status 'T-Stat / T-Stat_1' is Calling for Cool Then $Cool1_Cycles_Daily += 1 $Cool1_Cycles_Daily Init To $Cool1_Cycles_Daily Wait 5 seconds Repeat Every 5 seconds $Cool1_Cycle_Time_Daily_5Sec += 1 Else $Cool1_Cycle_Time_Daily_5Sec Init To $Cool1_Cycle_Time_Daily_5Sec Copy Cool1_Cycles/Run_Time program 4 more times change all instances of Cool1 to Cool2, Cool3, etc… and reference the appropriate TSTAT. Same goes for the Heat_Cycles/Run_Time. Create 5 separate programs utilizing Heat1, Heat2, etc… Daily_Cycle_Times_Calc If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then $Heat1_Cycle_Time_Hr = $Heat1_Cycle_Time_Daily_5Sec $Heat1_Cycle_Time_Hr /= 720 $Heat1_Cycle_Time_Min = $Heat1_Cycle_Time_Daily_5Sec $Heat1_Cycle_Time_Min /= 12 $temp = $Heat1_Cycle_Time_Hr $temp *= 60 $Heat1_Cycle_Time_Min -= $temp $Cool1_Cycle_Time_Hr = $Cool1_Cycle_Time_Daily_5Sec $Cool1_Cycle_Time_Hr /= 720 $Cool1_Cycle_Time_Min = $Cool1_Cycle_Time_Daily_5Sec $Cool1_Cycle_Time_Min /= 12 $temp = $Cool1_Cycle_Time_Hr $temp *= 60 $Cool1_Cycle_Time_Min -= $temp $temp = 0 $Heat2_Cycle_Time_Hr = $Heat2_Cycle_Time_Daily_5Sec $Heat2_Cycle_Time_Hr /= 720 $Heat2_Cycle_Time_Min = $Heat2_Cycle_Time_Daily_5Sec $Heat2_Cycle_Time_Min /= 12 $temp = $Heat2_Cycle_Time_Hr $temp *= 60 $Heat2_Cycle_Time_Min -= $temp $Cool2_Cycle_Time_Hr = $Cool2_Cycle_Time_Daily_5Sec $Cool2_Cycle_Time_Hr /= 720 $Cool2_Cycle_Time_Min = $Cool2_Cycle_Time_Daily_5Sec $Cool2_Cycle_Time_Min /= 12 $temp = $Cool2_Cycle_Time_Hr $temp *= 60 $Cool2_Cycle_Time_Min -= $temp $temp = 0 ****REPEAT 3 MORE TIMES FOR REMAINING TSTATS**** Else - No Actions - (To add one, press 'Action') Send_Daily_Status_And_Reset If Time is 11:59:30PM Then Set 'T-Stat / T-Stat1' Query Set 'T-Stat / T-Stat2' Query Set 'T-Stat / T-Stat3' Query Set 'T-Stat / T-Stat4' Query Set 'T-Stat / T-Stat5' Query Wait 3 seconds Run Program 'Daily_Cycle_Times_Calc' (Then Path) Wait 3 seconds Send Notification to 'E-mail' content 'Daily_Climate_Status' Wait 3 seconds $Heat1_Cycles_Daily = 0 $Heat1_Cycles_Daily Init To 0 $Cool1_Cycles_Daily = 0 $Cool1_Cycles_Daily Init To 0 $Heat1_Cycle_Time_Daily_5Sec = 0 $Heat1_Cycle_Time_Daily_5Sec Init To 0 $Cool1_Cycle_Time_Daily_5Sec = 0 $Cool1_Cycle_Time_Daily_5Sec Init To 0 $Heat2_Cycles_Daily = 0 $Heat2_Cycles_Daily Init To 0 $Cool2_Cycles_Daily = 0 $Cool2_Cycles_Daily Init To 0 $Heat2_Cycle_Time_Daily_5Sec = 0 $Heat2_Cycle_Time_Daily_5Sec Init To 0 $Cool2_Cycle_Time_Daily_5Sec = 0 $Cool2_Cycle_Time_Daily_5Sec Init To 0 ****REPEAT 3 MORE TIMES FOR REMAINING TSTATS**** Else - No Actions - (To add one, press 'Action') You might need some waits between the TSTAT query lines, I’m not sure. You may have to play around with some of this timing wise as there is a lot going on. I put this together assuming that you'd have all your stats in one single report. You'll have to modify your notification(s) to meet your desired format. Note: I’ve removed the monthly stats for the sake of cutting down on code and variables. If that’s a must have, it can be done. I just didn’t feel that the benefit of having that stat outweighed the complexity that leaving it in would create. One last thing. I have NO idea how this is going to affect your ISY’s resources if multiple programs are running and counting, let alone the amount of calculating it is going to be doing when you run that program. I don’t have that much stuff going on at any given time, so that is something to think about also. Good luck! Let me know how it turns out.
  10. Gotcha. That's what I was thinking. Cut the error in half on both ends and it should average out in the long run. I should change it to a # divisible by two, whatever I decide to go with.
  11. I don't understand. I have the counter starting after 5 seconds of run-time using the 'Wait 5 seconds' command. Watching it work, by starting it manually and monitoring the variables, it works like you'd expect. Only after 5 seconds have elapsed, does it add the first count. Wait 5 seconds Repeat Every 5 seconds $Cool_Cycle_Time_Daily_5Sec += 1 The only problem I see with this particular logic, is when the unit shuts off between counts, and you miss counting the last 1-5 seconds. Hence why I chose a small 5 second counting window. I suppose you could shorten the count time to as small as 1 second, but I assumed that that would use too much resources and might cause problems if another program tried to run at the same time. The way I see it is, if I miss a complete 5 seconds every cycle (not likely), my count is off (low) a max of 1 minute every 12 cycles. When the math is calculated, the variables get rounded down as well. From that, I could be as much as 59 seconds low per report also. I wonder if that wait statement shouldn't be removed as a way of compensating for the rounding down. Anyway, I do want things to be as accurate as possible, and if there is a quick and easy way to do it, I'm all for it. But at the end of the day, a couple of minutes either way isn't that big of a deal to me. When it's running for 8 or 10 hrs in the summer, 2-3 minutes is minor.
  12. Is this because there will be one last count after the cooling stops (program goes false)? Meaning once the last repeat starts, the count will always increment one more time?
  13. The rest of the screenshots:
  14. Here ya go. Hope this helps.
  15. I originally posted this in the thread that about counting the cycles, but felt it was kind of buried there and may never get seen. So I decided to make it a how to post. I really liked the idea of counting the number of cycles I saw in another thread, as one of the main things I like about the ISY and the Venstar adapter, is that I can export the logs and examine how my HVAC system is running. So as I was implementing it, I remembered another thread in the forum about a counter to report accumulated on time for a particular light. I figured it would be a natural fit for this set of programs, so I merged the two and below is what I've got running. All credit goes to the original posters of these programs, I just molded them to fit my needs. The following programs will count the heating and cooling cycles as well as accumulate the run time of each cycle. At the end of the day (or whenever you choose), it will send out a notification letting you know how many cycles of each ran, and the accumulated time, in hours and minutes, for each as well. The counter runs on a 5 sec clock, therefore you have to divide by 12 to get minutes (you have to divide by (12*60) or 720 to get hrs). I chose 5 seconds as it gives a bit more accuracy. You can set it for whatever you want, but remember to change the calc program, so your end of day numbers come out right. I have the calc program disabled as it is only called by the end of day routine. I put in the monthly variable, but don't have it set up yet, other than to dump each of the daily figures into it. I plan on setting up variables to calculate the dates and such, then I can run a monthly report and reset the numbers at that time. An example of the notification I put together looks like this: Cooling ran for a total of 18 cycles today. Total cooling run time was 5 hour(s) and 23 minute(s). Heating ran for a total of 4 cycles today. Total heating run time was 1 hour(s) and 49 minute(s). Define variables (non-state): $temp $Cool_Cycles_Daily $Heat_Cycles_Daily $Heat_Cycle_Time_Daily_5Sec $Cool_Cycle_Time_Daily_5Sec $Heat_Cycle_Time_Hr $Cool_Cycle_Time_Hr $Heat_Cycle_Time_Min $Cool_Cycle_Time_Min $Heat_Cycle_Time_Monthly $Cool_Cycle_Time_Monthly $Heat_Cycles_Monthly $Cool_Cycles_Monthly Define Custom Notification: Daily_Climate_Status Programs: Cool_Cycles/Run_Time If Status 'T-Stat / T-Stat' is Calling for Cool Then $Cool_Cycles_Daily += 1 $Cool_Cycles_Daily Init To $Cool_Cycles_Daily Wait 5 seconds Repeat Every 5 seconds $Cool_Cycle_Time_Daily_5Sec += 1 Else $Cool_Cycle_Time_Daily_5Sec Init To $Cool_Cycle_Time_Daily_5Sec ----- Heat_Cycles/Run_Time If Status 'T-Stat / T-Stat' is Calling for Heat Then $Heat_Cycles_Daily += 1 $Heat_Cycles_Daily Init To $Heat_Cycles_Daily Wait 5 seconds Repeat Every 5 seconds $Heat_Cycle_Time_Daily_5Sec += 1 Else $Heat_Cycle_Time_Daily_5Sec Init To $Heat_Cycle_Time_Daily_5Sec ----- Daily_Cycle_Times_Calc If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then $Heat_Cycle_Time_Hr = $Heat_Cycle_Time_Daily_5Sec $Heat_Cycle_Time_Hr /= 720 $Heat_Cycle_Time_Min = $Heat_Cycle_Time_Daily_5Sec $Heat_Cycle_Time_Min /= 12 $temp = $Heat_Cycle_Time_Hr $temp *= 60 $Heat_Cycle_Time_Min -= $temp $Cool_Cycle_Time_Hr = $Cool_Cycle_Time_Daily_5Sec $Cool_Cycle_Time_Hr /= 720 $Cool_Cycle_Time_Min = $Cool_Cycle_Time_Daily_5Sec $Cool_Cycle_Time_Min /= 12 $temp = $Cool_Cycle_Time_Hr $temp *= 60 $Cool_Cycle_Time_Min -= $temp $temp = 0 Else - No Actions - (To add one, press 'Action') ----- Send_Daily_Status_And_Reset If Time is 11:59:30PM Then Set 'T-Stat / T-Stat' Query Wait 3 seconds Run Program 'Daily_Cycle_Times_Calc' (Then Path) Wait 3 seconds Send Notification to 'E-mail' content 'Daily_Climate_Status' Wait 3 seconds $Heat_Cycle_Time_Monthly += $Heat_Cycle_Time_Daily_5Sec $Heat_Cycle_Time_Monthly Init To $Heat_Cycle_Time_Monthly $Cool_Cycle_Time_Monthly += $Cool_Cycle_Time_Daily_5Sec $Cool_Cycle_Time_Monthly Init To $Cool_Cycle_Time_Monthly $Heat_Cycles_Monthly += $Heat_Cycles_Daily $Heat_Cycles_Monthly Init To $Heat_Cycles_Monthly $Cool_Cycles_Monthly += $Cool_Cycles_Daily $Cool_Cycles_Monthly Init To $Cool_Cycles_Monthly $Heat_Cycles_Daily = 0 $Heat_Cycles_Daily Init To 0 $Cool_Cycles_Daily = 0 $Cool_Cycles_Daily Init To 0 $Heat_Cycle_Time_Daily_5Sec = 0 $Heat_Cycle_Time_Daily_5Sec Init To 0 $Cool_Cycle_Time_Daily_5Sec = 0 $Cool_Cycle_Time_Daily_5Sec Init To 0 Else - No Actions - (To add one, press 'Action') Let me know if you have any questions. Also, always looking for ways to streamline, so let me know if you see those opportunities as well. Thanks.
  16. Thanks kevkmartin for the slick counting program! That gave me an idea to add a counter to accumulate runtime as well. The entire setup can be found here: viewtopic.php?f=26&t=8081
  17. Oops, sorry, meant 240V not 120. Brain ****... And yes, when you do figure the cost of the AP in the big scheme of things, it is a minor cost. And I agree, once you get started, inevitably you'll end up adding more and needing it anyway.
  18. The easiest way would be to open your panel and put a voltmeter across the two circuit breakers and if it reads ~240 volts they are on separate legs. If it reads 0 volts they share the same leg. If you aren't comfortable with that, you could just try it without the access point and see if it works. If it doesn't, you could always order the access point later and add it as necessary. Edit: fixed error in voltage readings.
  19. If you only want garage door control and the PLM is plugged into a circuit that uses the same leg as the garage door, then you wouldn't need the access point. That's the setup I started with. ISY, PLM, and a couple of I/O Lincs.
  20. hoopty
    Wiring question
    I was thinking that you only needed neutral hooked up to get control signals, but I guess in this case you are also powering the switch itself via the neutral and therefore current would be flowing across the ground. Am I understanding this correctly? I did consult an electrician, but probably didn't take into account the fact that the switch draws some power... I found the kits here: http://www.smarthome.com/_/ProductResults.aspx?Ntt=2474 Ironically, they're actually cheaper than the switch I put in originally.
  21. hoopty
    Wiring question
    I had one of these circuits and after consulting an electrician, ended up figuring out which was line and which was load (white wasn't marked w/ black tape), wiring up the switch appropriately, and tying the neutral (white) and ground (bare) on the switch to the ground coming into the box. It is my understanding that in this configuration, you only really need the neutral wire connected to get the Insteon signal to the switch. The bare and neutrals tie together in the panel anyway and the bare should feed your switch the signals. This configuration is working just fine for me.
  22. I got most of this from the wiki I think... It requires 4 programs, but will do everything you are looking to do First is the program to turn the lights on once motion is detected. It uses the control line from the MS so that you can turn the lights off via the switch even if the status of the MS is On. If Control 'Garage / Garage MS' is switched On And Status 'Garage / Garage Lights' is not On And Program 'Garage MS Timer Enable' is True Then Set 'Garage / Garage Lights' On Else - No Actions - (To add one, press 'Action') Second is the timer program that shuts off the light once motion ceases to be detected. I have it set to beep 4 times 1 minute before it shuts off as a warning. The timer program will be disabled if 'Garage MS Timer Enable' program is false. Which happens if you turn the switch on manually, thus allowing you to work without fear of the lights going out on you while you're still in the room. You just have to remember to turn them off when you're done... If Status 'Garage / Garage MS' is Off And Status 'Garage / Garage Lights' is On And Program 'Garage MS Timer Enable' is True Then Wait 3 minutes and 54 seconds Set 'Garage / Garage Lights' 1 (Beep Duration) Wait 2 seconds Set 'Garage / Garage Lights' 1 (Beep Duration) Wait 2 seconds Set 'Garage / Garage Lights' 1 (Beep Duration) Wait 2 seconds Set 'Garage / Garage Lights' 1 (Beep Duration) Wait 1 minute Set 'Garage / Garage Lights' Off Else - No Actions - (To add one, press 'Action') Third is the 'Garage MS Timer Enable' program. It basically allows the MS to be overridden. It will disable both the On and Timer programs if false. If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set Program 'Garage MS Timer Enable' To Run At Startup Else Set Program 'Garage MS Timer Enable' To Not Run At Startup Fourth is the program the sets 'Garage MS Timer Enable' program to true or false. If you have a dimmer switch, you could use Fast On as well, but as these are florescent, I'm not using a dimmer. If Control 'Garage / Garage Lights' is switched On And Control 'Garage / Garage Lights' is not switched Off Then Run Program 'Garage MS Timer Enable' (Else Path) Else Run Program 'Garage MS Timer Enable' (Then Path) Another program I like is just turning the lights on whenever I open the overhead doors. The ones on the opener aren't very bright and I like the added light when I pull in. The Timer program will also take care of these as well, so just park and go inside, they'll go off 5 minutes later. And again, using the control line allows you to turn off the lights if you want to leave the door open and have the lights off. If ( Control 'Garage / Garage Door Sensor-Big' is switched Off Or Control 'Garage / Garage Door Sensor-Small' is switched Off ) And ( Status 'Garage / Garage Lights' is Off ) Then Set 'Garage / Garage Lights' On Else - No Actions - (To add one, press 'Action')
  23. Well that sucks. Works in Win 7 with Firefox...
  24. I believe this is the format you're looking for. http://Username:Password@ISYIP/rest/status/deviceid
  25. I don't know if you or anyone else has had this problem, but I was using the hardwired garage door button to ope the door and MobiLinc to close it, and the scene status would ultimately end up out of sync. So I figured out that a simple program could solve that for me. Here is what it looks like: If Status 'Garage / Garage Door Sensor' is On (Closed in my case) Then Set Scene 'Scenes / Garage Door Relay' Off (Closed) Else Set Scene 'Scenes / Garage Door Relay' On (Open) This solution may have been obvious, but it took a while to finally click for me. I looked through the forum trying to find a fix for this and couldn't find it, so maybe it'll help somebody out...
  • Create New...
