JCrank
  1. Or you could use something like https://www.amazon.com/dp/B00JJJK2VU/ref=cm_sw_r_cp_api_o9P8ybB8KWXNB And control it with network resources from the isy Sent from my iPhone using Tapatalk
  2. You could use insteon switch to control a relay that has a 120 volt coil, then switch the low voltage with the relay contacts How many watts will you be switching on the low voltage side? Once we know this I can find you a suitable relay. Sent from my iPhone using Tapatalk
  3. ok thanks, thats for the confirmation that the fanlinc will not work in that way. I already have programs setup for my fan speeds so I will set them up in the portal.
  4. Anyone have a fanlinc working? I have one linked in the portal and discovered on the echo but I can't seem to get it to respond. Alexa says ok when I saw "Living room fan on" or "living room fan high" but the fan doesn't come on.
  5. Working great so far thanks for all the hard work!!
