Vegetto420
  1. Hey all, Ok Someguy, I have seen your posts in the redeye forum and I have posted this as well. As I have 3 places that run on a redeye and ISY and an ELK as well. All three place's are filled with insteon switches and this would be awesome to be able to hit watch tv and your lights respond to this command. So for the guys here at ISY here is some info and maybe between all of us we can get this ball rolling. The guys over at thinkflood have just released their IP control for devices here is the link to the main page http://thinkflood.com/. So what they are using is a http or rs-232 commands to achieve control with device on the network. And since the ISY is on the network this should work with no problems. Well the only problem is as someguy mentioned most of us aren't to familiar with http coding or rs232 coding. The reason to go this way apposed to the IR way is so that you can get a response back so it's a 2 way not a one way system. So as a user on the redeye I would be able to see if a light is on or off just like most of the moble apps that are out there for the ISY. If there is some way of getting a list of the ip commands that the ISY uses and get them to Craig at redeye then this can become a reality. I know that Craig has a lot of Insteon devices and so do I as well as an ISY. I would be glad to do some testing or help get this going in anyway I can. The reason is that I would rather have 1 app to run everything than 4. Since the ELK can be integrated into the ISY then that gets rid of 1 app and then if the ISY can be integrated into the redeye then I would be down to 2. Redeye as also just added IP camera viewing to the remote as well so there goes another app, as a guy that is into the whole home automation this is the way to go 1 app controls them all! Any info or help with this would be great thanks guys.
  2. Thanks lee, I thought that there had to be a controller and the responders. So I thought that the controller had to be the app on the apple device. I tried to make a seen and adjust the levels in that scene and as I did that I would do it in real time as well. For an example I have a set of bed side lights controlled by a insteon switch and then the main light as well in the bedroom. So the scene I wanted was to turn off the lmain light and dim the bed side lights abit just for reading at night for an example. I guess my question is is once I have placed all the devices in the scene can I adjust the levels and then save? and once this is done I would press that button on the apple device and it would run the scene? Before in the other place I had to program in if, then commands. If IRcode 1 is received then run this scene. So that's why I'm a bit confused but I think I can get it now thanks.
  3. Hey all, I have installed an isy 99 as well as the whole house is being controlled with an ipad and ipod touch and a iphone. The last system I set up was with an elk and scenes through keypad links and rules. My question is the mobilinc pro see's all the scenes that are already made. But I want to make scene's that are triggered from the app only. I have no time scene's nor any rule scene's so I'm trying to figure out how to make a scene for an example when the button on the ipod is pressed then the lights dim in this scene. Maybe I missed something I've looked all over the forums and went to moblic's forums as well and I coundn't find anything on this. Any ideas would be great! This seem so simple it's probably right in front of me and I have missed it. Thanks all Jason
