automationgeek
  1. Seem the library python-pushover didn't install. I would try to remove and reinstall the nodeserver first. If that doesn't work you can always try to install the python library manually. SSH into polisy and than run this command sudo -u polyglot pip3 install python-pushover
  2. It would be the ip address of the pc running the application. example : 192.168.1.200 and port 8443.
  3. Yes exactly, as for site parameter unless you changed the value, you can omit it. It would use the default value. For the 90 seconds delay you can change it to whatever value you want.
  4. Adolfo started following automationgeek
  5. I have a few Lamp and Applicance Modules that I'm strictly using for xmas lights. I was wondering what you be the best approach, I was initially thinking of unpluging the module and store them until next year, but I was wondering if that would not cause a issue with isy99 trying to query the device ? Should I just keep them plugged until next year ? I am trying to avoid not having to unlink them and relink them every year. but I would like to free up some of my outlet. Thanks
