AT&T to end email-to-text ×
BillJudd
  • Posts
    7
Everything posted by BillJudd
  1. BillJudd
    setup
    Thanks for the advice on AVAST; it worked and I am in business!
  2. BillJudd
    setup
    Thank you so much LeeG. It definitely is AVAST, Now I need to figure out how to configure AVAST to allow the popup.
  3. BillJudd
    setup
    okay, I dropped the "shields" on AVAST and I got the pop-up and got the two devices on the system. So what is the magic cure for configuring AVAST?
  4. BillJudd
    setup
    I am using AVAST. So how do I work around that?
  5. BillJudd
    setup
    definitely a new setup. Before I click the linking tab, everything seems fine. I can access configuration and run diagnostic on the PLM. But if I select "linking" then things go wrong. I never get the "linking in progress" popup. But I do observe that when I start linking that the PLM beeps and the led starts blinking for what seems to be an a w f u l l y l o n g time. Another beep and the led is steady. But nothing on the admin console.
  6. BillJudd
    setup
    so how long does this initial linking process take? I am not getting the "linking in progress" window. btw, I did the power off reset.
  7. BillJudd
    setup
    Just got my 99i pro. Hooked it up and I can get the admin console. However, when I start linking all I get is "Discovering Nodes Retry! What am I doing wrong (or not doing)?
  • Create New...
