r3richard
Everything posted by r3richard
  1. Try send, wait, repeat 1
  2. All seems to be working now. Thanks for your prompt attention to the matter
  3. My portal account says "Offline since Friday, February 16th, 8:24:10 AM " if that helps ??? Alexa responds " the hub is not responding" etc. any help will be much appreciated, thanks
  4. just a thought..... you might have to resort to putting each pair of buttons into a common scene for each pair in which both buttons are controllers, sort of like a three way switch for each pair
  5. r3richard replied to r3richard's topic in ISY994
    Sorta what I thought too. Could I use the wired in Instanton device with the sensor wire--is the sensor wire sensitive enough to work just like the touch controls?
  6. r3richard posted a topic in ISY994
    I have wall sconces that are each turned on by a touch control dimmer inside the fixture. I would like to also control them by a wired in Instant on device. I want to keep the touch control dimmer function as it is a cleverly concealed thumbtack near the fixture. I have these sconces all over the house and want to control them individually and/or together. Can I just parallel the wired Instanton? Or would that blow the device when the touch pad provided the power? help please. thanks
