Plau
Everything posted by Plau
  1. I switched to dhcp and made ip reservation in my router, but still the same error message, I use another ha software (domoticz) and prowl work as it is (same api key) I have no idea where investigated now!
  2. he is accessible by admin console or dashboard, I'm not sure to understand where you want going ?
  3. Unfortunately the dashboard for 3.3.10 is missing, anyway I'm not sure issue came from this side, the system was up and running for more than 3 years. I did not notice any change on my network or hardwares since issue.
  4. Thanks Jon, mine don't look like yours
  5. I must be blind, unable to see "HTTPS Server Settings." in the Administrative Console, print screen will be usefull
  6. Hi Guys Prowl notification doesn't work since a couple days, I meet this issue a coupole years ago http://forum.universal-devices.com/topic/9347-resolved-network-resource-prowl-error/where solution was under settings the Verify checkbox under the section "HTTPS Server Settings." But I'm unable to located this box !
  7. Ok now I have 3 program It's working but if the door garage close before I open the door ($sAlarmZ3_GarageDoorHouse), the program 'Garage Door House Contact' doesn't start !
  8. I have something like that : and an other : Program 'Garage Scene HallWay' First issue is with the program 'Garage Scene HallWay' he turn light on, but never turn off the scene!!! Second issue is the first program, he works for enable the 2nd program but never disable it after time elapsed !
  9. I think I have the same trouble with my eyes, where is located this box ? could you put the print screen ? Regards
  10. I could use my thermostats Honeywell (prestige THX93..) that handles this case, but there is a limitation (not on the VH7200) , is the ability to drop below 40% humidity for the dehumidifier, I know that this can be dangerous, but here in Canada when the temperature drops below -30ºC sometimes I have to go down 35% humidity a couple of day (-22ºF I think) to prevent the water in the bottom of my Windows. Also i see on the viconic web site a zigbee versions but I'm not impressed with the reliability, almost 2 years and dead.
  11. My controller for humidification and dehumidification VICONIC (VH7200 Humidity Controller) is dead. Do you have any suggestions with which device compatible with ISY that he could be replaced?
  12. Plau replied to Plau's topic in ISY994
    Thank for your comment Guys, I finally found something working for my setup. I just add in my "sub program" Outside Garage Light 100% & Motion Sensor Outside Garage 100% the then condition, to point my main program ! If From Sunset To Sunrise (next day) And ( $sAlarmZ13_GarageDoorHoney is 0 Or $sAlarmZ14_GarageDoorPaco is 0 ) Then Set 'Outdoor / Garage Outside' On Wait 1 minute Run Program 'Outside Garage Evening' (If) Else - No Actions - (To add one, press 'Action')
  13. Plau replied to Plau's topic in ISY994
    for example in the evening, when the evening program is running and the motion sensor is activated, the light falls at 100% but at the end of the timer does not return at the evening program (light 60%)
  14. I’m not able to make my programs for my outside light garage working properly! I ‘have 3 programs: -Evening, I turn the light at 60% for a couple hours -When I leave, Garage doors open, to sunset at sunrise turn light on 100%, couple minutes -Motion sensor, when I arrive at the garage door to sunset at sunrise turn light 100%, couple minutes Both programs work well but doesn’t return at previously state, or disable other programs! My Motion Sensor is set up like this ! Jumper 2 and 5 installed Sensing Mode: unchecked On Only Mode: unchecked Night Mode:unchecked Evening program outdoor light x% If From Sunset To 10:19:00PM (same day) Then Set 'Outdoor / Garage Outside' 60% Else Set 'Outdoor / Garage Outside' Off Outside Garage Light 100% If From Sunset To Sunrise (next day) And $sAlarmZ13_GarageDoorHoney is 0 Or $sAlarmZ14_GarageDoorPaco is 0 Then Set 'Outdoor / Garage Outside' On Wait 2 minute Set 'Outdoor / Garage Outside' Off Else - No Actions - (To add one, press 'Action') Motion Sensor Outside Garage 100% If From Sunset To Sunrise (next day) And Status 'Outdoor / MS Outdoor Garage' is On Then Set Scene 'Garage Outside Light' On Wait 1 minute Set Scene 'Garage Outside Light' Off Else - No Actions - (To add one, press 'Action')
  15. Hello Michel I re create a network resource with now this error message! I'm not sure to understand about the credentials, if I send api key no need credential! do I need set up credential for use network module?
  16. when I test my network resource created for prowl, I get this message!
  17. Thank you for your help, both programs works except if my light is dimming! During the program execution the windows system busy appear 2 times !!! If I want add more rooms around 5x, which is the best way?
  18. many thanks LeeG, it's exactly what I need, work fine. Question with or without else filled, if my light I control for flashing is open and the program turn on, at the end the program my light don't stay on as previously, if you have a suggestion!
  19. I would like received an SMS if my door garage stayed open for more than 15 minutes and open and close a couple time my bedroom light (for wake up my wife ), so I buy a 2421 trigerlinc for perform this. Somebody can help me with the program an how manage the 2421? thank you in advance!
  20. How link 3 way or 4 way switches through Isy99, real (physically wired) or Virtual Multi-Way, it's for controlling a ceiling lamp I don't found no documentation about that. I tried trough scene but nothing works, I'm just able to do something when I linked manually the switches and he seems to be not the best way with ISY. Which one is the controller and wich one must be the responder or both. If someone could explain how it works, thank you in advance
