SteveT
  1. Thanks - so I assume that devices that act as repeaters will not work, but instead a range extender is needed?
  2. Thanks @Techman - turned out to be distance from the hub! I was thinking that another zwave device could do the inclusion, but I guess not. So I end up running long ethernet cables across the house temporarily - Not sure what type of repeater also allows for new devices to be added...
  3. I am trying to temporarily user an older ISY994 and have issues getting the Zooz Zen71 switches to join my Z- Wave network.. I was able to get an older Aotech binary switch online, but these do not seem to be visible within discovery even when the other switch is close - ideas? For association, the directions indicate 3x the top paddle. I also tried excluding, etc. no dice. The ISY994 just does not see it. I have the Z-wave board (500 series - I believe) - without the antenna. Thank you! Steve
  4. Onto the next issue - after doing the factory reset - and trying to do the upgrade, or save programs I get a "tcp client DNS error" [my.isy.io] -- With the upgrade, I get a "Upgrade failed: failed uploading file (reported written size is invalid)... Java.io broken pipe. Previously it had been on the portal, and since expired, but i deleted and rebooted in case that was the issue. Related error: ? "Could not open config file to read /CONF/HZWNDKEY.TXT", Could not open file "/CONF/PORTALS.PSF" stuck! thanks, Steve
  5. great- thank you I will try that.
  6. Hi - brought the old unit out of retirement - and after the factory reset was able to get into the box. However, I will not be using Insteon, only Z-Wave but the unit is booting to safe mode. In my policy, I see the option to disable Insteon under system but not under 5.3.4 which is the last firmware? Anyone else have success? Thank you-Steve
  7. SteveT replied to SteveT's topic in EnvisaLink-DSC
    ..and the other issue is the keypads and other accessories. Old tech that works is more expensive than the new stuff. Good luck.
  8. SteveT replied to SteveT's topic in EnvisaLink-DSC
    I think it’s online only programming from what I found out- not for me ..
  9. SteveT replied to SteveT's topic in EnvisaLink-DSC
    Thanks @apostolakisl, I have been doing further research and it’s really not looking good. The work-around that eyez-on has is very limited it seems. I have been emailing them also. A >$200 risk and maybe it will do arm and disarm and zone status with more parallel modules. But no details like exit delay/partition status. It’s unfortunate, as the DSC Neo looks to be a decent system and wireless “PowerG” as well- but without the management and integration - it’s backwards as you say. Steve
  10. SteveT replied to SteveT's topic in EnvisaLink-DSC
    yes- I have been looking into it. Looks like I am going to test :). Don't have a choice - need to keep the integration with my home setup.. and the older 433 MHz stuff is hard to find for the DSC 1832... Wish me luck. I will report back.
  11. SteveT started following DSC Neo
  12. SteveT posted a topic in EnvisaLink-DSC
    Hi - I am looking to upgrade from my DSC 832 to the DSC Neo, and was wondering if anyone has the EYEZ-ON board setup in Universal mode with this plug-in? I trigger routines for arm/disarm mostly. Not sure I will get that status without full bus integration. thank you, Steve
  13. Z-Matter board within Policy also not responding!! Ugh. UPDATE: Since I was basically hard down, I followed @DennisC , @Geddy recommendation, and upgraded to PG3x. The issues w/ZMatter board and other failures were resolved with the upgrade. I was then able to migrate my PG2 and PG3 nodeservers to PG3x flawlessly by installing in the same slots! Amazing. I am relieved. Nice programming work. Up and running - phew.
  14. I am kind of hesitant if it deletes something in the PG2 configuration that i will need. I see that article, and read through it - should be a non-issue, but then again, so was this upgrade supposed to be something quick!! LOL.
  15. It was working fine w/ v5.8.0, PG2 and PG3 - FYI. I wish there was a warning - I know it was in the forum, but messaging in the upgrade. Will do - thank you!
  16. yes- I have not upgraded to PG3x as I have a PG2 node server that i am still using. I guess I may be stuck now as I cannot even get to the PG2 or PG3 interfaces. More problems... Node server is blank. I will open a ticket, and revert. thanks all-Steve
