Everything posted by robinasu
Certificate and Dashboard Problems - Help Please?
I would say it was not actively trying to remove clients when it froze. The activity lights were not blinking. Plus, I let it sit for quite a while. When I removed devices 1 by 1 it was a very fast process. What is the best way to erase every node and globally reconfigure all nodes? When the applet froze I believe it caused my remotelinc to be out of sync. The ISY is out of sync with the remote. Everything else seems fine.
And do we force everyone to buy an iPad? With kind regards, Michel I see your point. Plus, an app from you would put pressure on your ecosystem. By the way, I love the 994. It's done everything I need. I just wonder if Java if getting a little long in the tooth. Maybe a pure browser based solution would lower your overhead in the long term. On the side: I was trying to remove multiple devices from a scene last night and the applet froze on several attempts. I had t o force quit using my mac several times. Everything was fine when I removed the devices one by one.
Have you guys thought about an iPad app? I think it would be awesome!
I should also add: I am using Firefox and the lastest Java7. I am using a wired local network, too.
Hi all, I just picked up eKeyboard and enabled internet access on my 994i PRO. The admin console suggests to request a new cert, but after I click the button, nothing happens. So far, eKeyboard is working on cellular with my ISP's fixed IP address. Although, when I turn off my phone wifi it breaks. I think I have a couple problems. I found this pdf: http://www.universal-devices.com/docs/I ... 0Guide.pdf I tried to load the dashboard as instructed in the pdf, but the link fails. I verified that I have the correct version number in the link, which is the latest version. I also replaced the URL with my 994's statip IP and received this message: /99i/3.3.10/dashboard.jnlp not found How do I access the dashboard to adjust the certificate settings? Why won't anything happen in the admin panel when I click to manage certificates? How can I make eKeyboard work with both cellular and wifi networks? I have a Mac. Thanks, Rob
RemoteLink2 Quirks w/AllOff Scene Question
Yep. I would accept the lights not blinking the right colors. I'll switch to the 4-scene or 8-scene non toggle and tone down my ambitions unless somebody has a solution.
Hi Lee, I understand the remotelink status cannot be modified. I am looking for some code or ideas to use the ISY to track the remotelink toggle state and ensure that every remotelink button press results in a change of state of the controlled unit. Right now when you set all units to off while the remotelink toggle status is "on" the remote link button must to pressed twice to turn the lights on again. I want to eliminate the double click while retaining fast on, dim, bright, on, off, etc. Any ideas? Is there a repository for programs around? I am surprised to not see any. Maybe I just don't know where to look.
Hello, I would like to retain all the fast-on, fade etc features of the remoteLink2 8 button remote in toggle mode and eliminate the loss of correct state when using an AllOff scene. Can you recommend any work arounds?
if (any unit in scene) possible using admin console?
Thanks for the reply. I was hoping the ISY would track that. For example, you can see individual unit status when you look at a scene using the admin console.
Hi, just picked up a 994 and I like it. I have started playing with the admin console programs. I would like to set a variable "allOn" to 1 when any units in my scene "allOn" are on. What is the best method to do this?
