TheWizard
  1. Check out this link from Lifehacker... http://lifehacker.com/pre-order-amazons-new-echo-dot-without-an-echo-or-fire-1763260177 Tried it with an Android and it worked. Not sure about iOS though. It shows that I "pre-ordered" it and it will be "Arriving Jul 20, 2016". That is not the May date that I've heard. I know someone who ordered it last night with their Echo and had a delivery date of May 17th. I guess I'll have to wait and see if my date gets updated or maybe it knew I was ordering on the Android app and gave me a later date. I'll have to try it with my regular Echo in the morning and see what date it says. Good Luck. UPDATE 3/10/16: Arriving date was updated to "Arriving May 18, 2016"
  2. Barry, I think you can just use: --upnp.config.address=$_IP don't use the quotes. That syntax is used in some shell scripts I have where a string is being passed with a command, or in your case loading the emulator. -Don
  3. Nice message Same to you! The dash took a little while to figure out. I won't post the "I had some fun" meaning to give others a chance. I'll wait a few hours. I guess I kind of gave a clue though. -TheWizard
  4. I had the same problem. If I remember correctly I think the following worked. Not sure why, but it did. I had the problem while running v3.3.3. Right click on the main KPL button (the one controlling the load, not A, B, C or D) and select Diagnostics | Query Insteon Engine. The Wizard
