beachfront71
  1. As mentioned, I have text alerts for my garage door I would like to keep using it for both email and text alers... Under Email Notifications/Settings Groups I have 2 contacts: 1. Is a Gmail account and works fine 2 . Is a Verizon text account - (CellNumber@vtext.com) - that used to work and not longer does ... Any ideas why this might not work anymore? Set up is pretty straight forward and simple...
  2. sorry,, heres what I was trying to do: I have a dead switchlinc that I am not going to replace The switch is part of a scene that also includes a button on a keypad linc to control the switch as well. I removed the switch from my ISY dashboard but could not figure out how to remove the associated button on the KPL.
  3. I did all of this .. If I have a 6 button KPL and want to remove Button D (Kitchen). I go down to the scene called Kitchen lights and right click-remove from scene but Button D Kitchen lights is still in the keypad link grouping up top so I go the there and right click delete to remove the button .. It then asks if you want to remove the ENTIRE KPL... Same with disable ... If I go to button D / Kiichen lights and right click disable .. it disables all the other buttons as well
  4. For what its worth, I am removing the keypads one by one then re ingesting them with links cleared ... A pain in the A$$ but not that bad..
  5. Thanks, and I have done all that. The problem is when I look at my keypads in the ISY admin concole, the Kitchen Light is still on/assigned to both keypads. If I right click and try to disable or delete, it wants to delete all the other button assignments on the keypad as well.
  6. Hello and thanks in advance. I have 2 Keypadlinc's that I need to remove 1 buttons function that links to a lightswitch that is no longer in use.. Lets call the button to remove ---> KITCHEN LIGHTS I can not figure out how to do this without wiping the whole Keypad and starting over.. When I go to delete the name of that button or disable it, all the other buttons are included in the request.. I have individually removed Kitchen lights from all scenes and then deleted the scene and the individual Kitchen Lights switch... But still have the Kitchen light button on the keypads I need to remove... Again, thanks for any guidance.
  7. Well. I upgraded phone from 7.1.1 to 8.1.1 and that fixed the problem although it seems like that should not be a problem in the first place.
  8. Any help here appreciated .. I use mobilinc connect for out of band access to my system. All is well except Mobilinc is not updating the status of my switches .. On / off/ open/ closed .etc.. Can not figure out why this could be as the setup is simple and I have been using it for years but it has been unused for a while due to a bad PLM that was replaced. ISY99i Iphone 5 ISY dashboard and phone can control everything, Admin console updates any changes as they are made but its not being updated on the phone. Thanks. N
  9. Hi and thanks. Forgot username / password so I reset the ISY .. (hold pin down for 5 seconds, etc.) When I pull up the user panel and put in admin admin and log in .. I then change the user and pass to my prefered choice.. Then.. I upload an old settings file to restore all my settings but it seems to keep uploading the old usernam and password so it locks me out again ... Am I doing something wrong here/>? THanks
  10. I can confirm the IO linc issue. Went back to 3.2.6 and working as normal again.
  11. Thanks ! That at least confirms the problem. Could you tell me what version I should download to so I can have it running normal? I see 3.2.6 as the latest relase and 3.3.1 as the prior beta.. T
  12. the switch is mounted on the garage door rail and the magnet on the top of the garage door in a way where the 2 would only connect if the door was fully opened ... sensor status on mobilinc and isy are actually showing the same ... When the door is closed the switch and magnet show OFF As soon as I open the door, the status of switch goes to ON even though the magnet is 10-12 feet away ... One other note: (dont know if this matters) In the ISY admin it says: Garage Door Relay is a responder to Garage Door sensor is a responder to is a controller for
  13. Yesterday I upgraded to the latest 3.2 as well as updated the mobilinc app in itunes.. I do not know if any of the upgrades are related to my new problem but here it is and thanks for any help. 1. I have isy set up to send me a text when the garage door is closed as well as being able to monitor real time status of the sensor(opened/closed) 2. I have the garage door kit (io linc) set up in reverse mode and in Mom C-- when sensors are on it is open, when sensors are off door is closed Here is what I am seeing: When I open the garage .. it takes approx 5 seconds for the door to fully open and for the sensors to move into the on position (where they are close to each other) The problem is that now when I open the garage the sensor status immeadiatley shows "ON" even though the sensors are not together .. if that makes sense It seems like the sensor status is being based on the relay being turned on or off and not by if the sensors are actually detecting each other or not ... Is there something I am missing here in the settings? I hope that makes sense..ignore spelling errors!
  14. The sensor is mounted so that when the door is fully opened it connects with the magnet ... when you close the door, after that first 5 inches of travel the sensor is now no longer connected with the magnet and the text is sent stating the door is closed before the door actually finishes moving into the closed postion.
  15. Hi and thanks in advance. I have the following script for my garage door to let me know when it is shut: If status of "garage sensor" is off Then send notification to "ME" content "garage door is closed" Else No actions. I also have a notification sent to me if the garage door is open for more than 60 minutes. One thing I noticed is if you close the garage door but something is in the way of the safety sensors, the garage door would reverse back to open but the sensor would have triggered off during this time and sent me a text that it was closed. Anyone have an idea of how I could add a statement to check the garage door status 5 minutes after the notification was sent? Something like: wait 5 mintues, if sensor is still off then do nothing, otherwise send text garage door open. If it matters, I have it set up backwards so when the sensors are ON the door is open and when they are OFF the door is closed. Thanks again for the help.
