mcrean
  1. mcrean replied to mcrean's topic in UD Portal
    Thanks, Works now!
  2. mcrean posted a topic in UD Portal
    I paid for ISY portal and trying to create an account gives me an HTTP error 500 in several browsers. I looked through the forums and can't find any answers.
  3. In regards to the Xenon lamp problem. I can vouch for the low signal voltage causing noise when the module is off. I had an electronic fluorescent ballast that would numb the module it was plugged into and others while it was off. Imagine my surprise when I finally figured that one out. Good luck!
  4. Is it just me or has the X10 side gotten unreliable all of a sudden? Has anyone with X10 experienced a degradation in reliability?
  5. I too would also like to roll back to 2.6.8. I tried to do it, but it said isy denied the upgrade. Do I have to do a factory reset? If so, what order of firmware upgrades should I do to get to 2.6.8? Thanks,
  6. I just did a factory reset on a SLD and when I change the on-level (Applied Locally) it does not program the switch. If I sent an 'on' command from the Isy, it goes to the right level, but not when I press the paddle. Is this normal? The Isy is reporting V.27.
  7. Under program details, to add or edit a schedule the time drop down menus just show .... Also under Manage Programs, the buttons show partial words then... (New...; Und...) I am using Firefox with an iMac. It looks like a font size issue. Is this something I can correct? I think it happened when I upgraded to 2.6.10. Thanks.
  8. Woo Hoo! First to report. No issues here so far. Thank you Michel for sacrificing for us, we appreciate it!
  9. mcrean posted a topic in ISY994
    Hello, I just noticed I am able to sort columns on the Main Page, for My Lighting. I am not able to sort columns under Program Summary. Is this something I can fix? Thanks
  10. I was just looking in my programs after the upgrade, and to edit a time in an existing program, it just shows ... in the time drop downs under 'schedule'. I cleared the Java and re-booted. It is still there. Do you see this?
  11. Please reference: http://forum.universal-devices.com/viewtopic.php?t=1466 The part about: Adjusting On Level/Ramp Rates with a program. Is there a way to change the on level and ramp rate for applied locally? If so this would be perfect for one of my programs.
  12. mcrean posted a topic in ISY994
    This program did not work properly. I was on vacation so Keypadlinc D was On. On Friday and Monday the program ran and executed 'Then' On Sat and Sun the program did not run the 'Then' Path. Is it a parenthesis issue? If On Mon, Tue, Wed, Thu, Fri Time is 5:30:00PM Or On Sat, Sun Time is 10:00:00AM And Status 'KeypadLinc D (Vacation)' is Off Then Set 'Digital Picture Frame' On Else - No Actions - (To add one, press 'Action') Thanks again.
  13. mcrean posted a topic in ISY994
    I am using a Mac with OS X. On my PC, I can sort the columns in program summary. On the Mac, I cannot. I figured this was a Java version thing until I discovered I could sort the columns in the Main window. Is this something that can be fixed easily? I tried the new version of Java, but Firefox will not even run the applet and Safari acts the same as before, so I reverted back to the old version. Thanks!
  14. Ok then, Chris. Should there be a defined order, say either one we can set, or somehow made to run in the order of the times they are referencing? ie. a program that is set to run at 10:00 AM will run before a program that is set to run at 11:00 AM. Can that be put in the next drop? I think it would be very beneficial. Thanks!
  15. Mr. Jahn, Thank you for your reply, but I was asking specifically what order the programs themselves run. At an 11:00 PM reboot, any program that should have run sometime that day, ran and sent the appropriate commands out to the modules. They all show the same time as have run because they run so fast. Does the "Sunrise" program run before the "Sunset Program", etc.? Is that new catch up on schedules grace period supposed to only run programs that were scheduled within 15 minutes (or set duration) of a restart? If so, it did not work and all my programs ran. Thanks!
