Dual NIC access to ISY
Thanks! Sorry, I thought that was a different device.
Thank you! I'll look into that! Sounds promising.
Thank you! Unfortunately, I should have mentioned that I suggested a wired to wireless adapter to the IT staff and they said it would be flagged as a rogue access point and automatically shut down. So, I suspect this device would behave the same way.
I have a situation with my dad's ISY994i that I'm hoping to hear if anyone has come across and could provide me any insights. He currently has a very standard setup (ISY994i, PLM, home network, ISY Portal for Alexa, about 20+ insteon devices). All is well and has been for years. He is in a community where they provide wireless Internet access for a reduced rate, but when I checked with them, they cannot handle providing an IP address to the ISY. So, I bought a mini-switch and connected the ISY directly to his PC via an ethernet port (separate network from his typical WiFi/internet) in order for him to be able to program the ISY. That worked well. Unfortunately, I forgot about Alexa / ISY Portal needing Internet access to the ISY. I tried network sharing and binding the 2 NICs (wireless and wired) but neither solution was successful. Has anyone tackled something like this with positive results? TIA
Has anyone used an ISY994i with a Wifi to Ethernet adapter?
Thank you! Great idea on the old router in bridge mode. I'll look into that first, since it would require no cash outlay for him at all!
My dad lives in a senior community where they can offer him deeply discounted Wifi, but no physical (ethernet) connectivity. He uses an ISY994i for his basic Insteon needs (along with Alexa). Has anyone ever tried using any of the Wifi to Ethernet bridges that are available on Amazon and elsewhere? If so, any pros, cons, or pointers you can give me? TIA!
Weird behavior after multiple power outages... any help appreciated where to look.
I was away on vacation last week, and we had numerous storms that caused several power outages. We have a whole house generator, and I have my entire network (Including ISY994i but EXCLUDING PLM) on a UPS. I didn't change anything in ISY the week before vacation. Upon return one of the buttons in an 8 button box that usually turns on/off my LIFX desk lamp (via Polyglot v2 on an RPi) wasn't working, so I logged into the RPi/Polyglot and an upgrade was offered for Polyglot to 2.2.11 which I activated. That evening, none of my normal on/off programs for various lights ran. Finally, I can still turn everything on/off manually through Agave app on my phone and via Alexa. (So I'm assuming the PLM is OK.) Now, I can access Admin console ONLY through http, not https as I always had previously. Once in I can control lights manually from Admin Console BUT no programs run on schedule. I also tried to "Run Then" via Programs tab, but no luck. Each time I enter the admin console, it starts the "System Busy" "Please do not power off/unplug the system or make adjustments..." When it reaches part way through, it gives me a login screen and says the ISY has been rebooted. I'm not finding any forum entries that point me in any specific direction. I am on v. 5.0.16C Any help on what to explore would be greatly appreciated! Thanks in advance UPDATE 10 minutes later: For the first time the system busy finished. When I tried to run a "Run Then" I get this error:
Ping Node Server - False Negatives
is shortpoll parameter in seconds or in minutes? (Guessing seconds, but thought I saw minutes somewhere but now can't find it) Thanks!
Release 4.8.0 Is Now Official
Thanks for the feedback! A couple Polisy questions, if I may: 1. Does having the Polisy replace my existing ISY994i or do I need to keep it? 2. If it replaces ISY, does it have Z-wave onboard? 3. If it replaces ISY, does it need a separate PLM or is that onboard the Polisy? Thanks you!
Just a quick update....I upgraded to 5.0.16C over the weekend without much trouble. A few program issues as most have described but all relatively easy to fix. Now z-wave (unrelated to this upgrade), now that's a whole other issue. I mainly wanted access to polyglot cloud but I was disappointed that none of the polys that I wanted are up there. So, I guess I'll be exploring a Rpi. I will probably wants polisy down the road, but I need to be sure it will do all that i want before spending that amount. Thanks to everyone and UDI!
OK, just for giggles before going to bed, I decided to clear Java cache INCLUDING Applets and try upgrading again. This time, it succeed successfully and I am on 4.8.0. Should I have any concerns about upgrading to 5.0.16?
I just attempted, twice, to upgrade from 4.7.5 to 4.8.0. Both times it failed. The second time I watched closely, and saw it failed at 95% with the attached error message. I am able to accept the error (OK), logout and log back in successfully but am still on 4.7.5. I have been working on the system quite a bit the past few days and have gotten a number of these java errors, but typically the action I was taking succeeded anyhow. I had all intentions of upgrading to 5.0.16C but now I am very nervous to try that if this simple upgrade won't proceed. I've always done automatic upgrades in the past with no issues. FWIW... I do have the -Xmx512m parameter to give Java more room. Any advice? Thanks in advance!
Door Sensors and Scenes
Thanks, larryllix. Yes, i did already add that "catch all" off from one of your earlier posts.
I tested this 2 program solution last evening and it worked beautifully. I added a Wait 5 seconds this morning to program 2 to allow us to "walk through the door" before the light goes out. Thanks again!
Thank you. Way too easy!
