cats
  1. Nevermind--got it.... Thanks, though. cats
  2. I am having a rough day, and this is seeming to go on....I just read about the java problems and, sure enough, it was enabled in my browser. =(. But, I wanted to upgrade my isy99i to the latest version. I followed the instructions and have upgraded the console, but, my firmware didn't upgrade. What am I missing? Thanks, cats
  3. Good evening, I just read the qualifications for upgrading to your newest version....my question is, I have a Mac with OSX Lion, the very latest version, yet, even when I look on Apple's website, Java version for my OS is Java build 1.6.0_37. That is the version I am currently running. Is this not going to work with your latest version, then? Thanks, cats
  4. I think that's what happened! I had read the manual, but, I was pretty confused by then to understand how to fix it, since I didn't know what I'd done exactly. I should have turned the power off for a minute, I guess. Anyway, thank you all so much...this is my first foray into this type of stuff....
  5. cats replied to cats's topic in ISY994
    Thank you...if I run across it again, I'll copy the link. I've been reading so many different pages, I'm confused as to where some things are now. I'm sorry.
  6. I think it works!!!!! I think when it went into Auto mode today, it is working correctly! Thank you for all your help, even in my ditziness. I think what happened is that I put it in manual mode somehow for last night, and it was stuck there until today..... Great news on that front. I'm really loving this stuff!
  7. cats replied to cats's topic in ISY994
    Oh, it was in one of the Wiki guides...I was boring down into all the links....Thank you though. So, if I am using scenes, I don't have to worry about groups...
  8. cats posted a topic in ISY994
    I read some information on grouping vs. scenes, but I really didn't understand it... Why would you group? When do you group? Thank you.
  9. cats posted a topic in ISY994
    How do I get the Categories to have data in them? When I try to run anything listed in the Categories, it gives me a blank. Also, is there a real-time log, or does the program always export to excel? (or any spreadsheet?)
  10. I just checked with electrician, and, yes, it is wired correctly, btw,...thanks for checking!
  11. BTW, yes, I put the sensitivity to mid position.
  12. I had no idea about the Fast on and Fast off buttons....so should I just use On or off buttons to turn of the InLineLinc then? I'm sorry you are on both forums...I've been reading all I can and cannot make enough sense, but, that comment just did, because I used that button! (Both, actually) SO, now, I have unlinked it from everything and deleted the inLineLinc. I will re add it..... Should I make a scene with all the "outside lights" I want to control and add InLineLinc with sense as the controller?
  13. I want an outdoor motion sensor with lights and an InLineLinc with sense module to turn on other porch lights. I want it to respond to motion to turn on for 5 minutes (all lights). If, during that time, I want to switch the lights back off with a 2440 remote or 2430 desktop controller, I want that to happen with a button. Then, if the motion detector senses any movement, I want the lights turned back on. Also, I do not want the inlinedlinc to turn my lights on all night long 3 minutes after the 2494msbn has turned off the lights. How do I set this up in iSY99I? Thanks...sorry I've been confusing.
  14. If I leave the lnLineLinc with sense on, the flood lights are on, and the motion detector doesn't seem to work....what in the world should I do?
  15. Hello, I just installed a 2494msbn motion detector with inlineLinc with sense and a new iSSY99i. I can turn on the sense and the motion detector will work. I have created scenes linking the device with other outside lights I want to control. They indeed can turn on with the inLineLinc and motion detector. However, I also have a 2440 remote and 2430 desktop controller that I want to be able to turn the lights off with all off or just the outside lights. Do I put the InLineLinc in with these scenes? If I do that, the motion controller doesn't work. Also, do I just leave the inLineLinc on all night?
