Igdixon
Members-
Posts
19 -
Joined
Last visited
Everything posted by Igdixon
The ISY firmware is 3.17 . What do you mean when you say not coupled? You are right, I did hit the set button to make that link! The Outletlincs were just purchased a few days ago.
I'm unable to control the outletlinc with the ISY console. It changes from on/off off/on in the console, but the actual light does nothing.
It is being controlled directly from the keypad, I was able to link the 2 with no problem. Yes I'm getting that red ! when I try to create a scene!
My current project which is underway is installing several outletlincs in several locations throughout my home. Installation has been pretty straight forward so far but I'm having difficultly when it comes to controlling the outletlinc. I thought once I entered the address I would be able to control the device that was plugged into it from my ISY admin panel and my iPad. I was able to linc 1 outletlinc to a keypad linc so I would be able to control outdoor lighting but that's it. I'm not able to control those same lights from my iPad or admin panel, just from the linked keypad. Please help! Thanks!
Second night that it worked without a hitch!
It worked last night, I went back into "IF","THEN" and "ELSE" and saved it. The reason that I had the second line was that the keypad "D" would still be illuminated even though the light was off. Is there an available training course for the ISY.
For "Alana's light off" it indicates it's idle. Last run time was 03/23/2012 07:31.55pm and finish time is 03/23/2012 07:31.55pn. Next schedule run 11:00 pm. Status is False and Path is blank. Run at startup there is a dash and it's enabled.
If Time is 11:00:00PM And Status 'Alana's Bedroom' is not Off Then Set 'Alana's Bedroom' Off Set Scene 'Alana's Room Keypad D' Off Send Notification to 'Ivory Dixon' Else - No Actions - (To add one, press 'Action') It was working before and now it has recently stopped. Thanks for the help!
Can't figure this out. I have a basic program to shut off a light at 11:00 pm. Once the light goes off a keypad light also turns off and then a notification is sent out. Everything was working properly to my surprise, but then I went back into the program thinking that I may want to try and change something it now stopped working. I don't want to be afraid to edit/change something but then again I want the programs to work correctly. Is there a set procedure On how to edit and or change programs? Are u supposed to wait until the program won't be running to make any changes? Please advise!
I just got it working!!!!!!!!Thanks for all your time!!!!
I followed your recent set of instructions and nothing appears in Event viewer
What I find interesting is that if I controlled that particular dimmer via the MobiLinc app it was coming on at the level I was requesting, the 40%.
I finished the programming at least an 1 hr before the start time of the program. That bathroom dimmer is a 2477d dual band switchlinc dimmer v40
If From 11:00:00PM To 5:00:00AM (next day) Then In Scene 'Master Bath Dimmer' Set 'Master Bath Dimmer' 40% (On Level) Else In Scene 'Master Bath Dimmer' Set 'Master Bath Dimmer' 100% (On Level) The name of the scene is "Master Bathroom dimmer" When the scene was created, I used the dimmer switch which is located in the master bathroom and it is programed as the controller
Thanks for the info! When u hit the button "copy scene attributes" does that permenatley copy the scene attributes of that particular scene?
I created the scene with the bathroom dimmer and I have it set as the controller. Slowly but surely I was able to copy the identical program that I was instructed to but it's not working the way I want so I must be doing something wrong. If I use my MobiLinc app and go to the scene area and I pick "bathroom dimmer" it will work just fine. If I go to the actual controller and hit the paddle it just goes to 100%. Please help!
Can an Insteon dimmer switch be programmed by an ISY99i so that when that switch is manually pressed between certain hours that it would only come on at let's say 50%. I would like to program a bathroom switch so that if it's pressed between 11pm and 5am it will automatically come on at 50%. All other times when pressed I would want it to come on at 100%. Thanks for the help
