plars3n
Everything posted by plars3n
  1. I'm an INSTEON installer and am at a customer who has the same scenario described above. I assumed the PLM dead. Replaced it, no change. Found this thread. INSTEON support was unchecked. Checked it, saved, restarted IOX. PLM working. I'm going the check my other eisy customers. Thanks for this thread!
  2. I've been using the ISY's in my residential integration business for about 12 years. They are a fantastic piece of kit. I have them doings things that even surprised Michel (back in the day). I am glad that I did because now that INSTEON is discontinuing products that have been the core of by business (micro dimmers, etc.) I have options instead of pulling the systems out of customers houses as components die off. It sounds like I it's time to learn what this Polisy and Polyglot is all about.
  3. Thanks, again, for your great and timely support. This level of support is just one of the reasons I insist that every system I sell, or work on, has an ISY. I ran several PLM Link tasks and received accurate matching counts. The number of links changed, although in the log I saw no other traffic. Run Number 1 370 2 288 3 192 4 115 5 48 I don't understand why the number of links would change. It must be time for me to re-read the manual. Extra Credit: I Deleted and Re-Installed a dimmer just to see how it worked with the PLM. Pruning down the log, these are the results. Fri 08/16/2013 09:40:16 AM : [MNG-LNK-RSP ] 02 6F 40 E2 00 1E FE 51 01 20 41 06 Fri 08/16/2013 09:40:17 AM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1E FE 51 01 20 41 15 Fri 08/16/2013 09:40:16 AM : [MNG-LNK-RSP ] 02 6F 40 E2 00 1E FE 51 01 20 41 06 Fri 08/16/2013 09:40:17 AM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1E FE 51 01 20 41 15 Conclusion: Sounds like I need to replace the PLM. What would happen if I re-initialized it, and then restored it? Thanks!
  4. Thank you for the detailed info and the quick reply. What would you recommend I do next? Thank you again! -Paul
  5. Both unit's are upgraded to Pro from basic. Maybe that is important? I selected add remotelinc2, 8-button. Here's the log: Tue 08/13/2013 02:30:24 PM : [1C 4E C9 ] Added to list of devices to link to ISY Tue 08/13/2013 02:30:24 PM : [iNST-TX-I1 ] 02 62 1C 4E C9 0F 0D 00 Tue 08/13/2013 02:30:24 PM : [iNST-ACK ] 02 62 1C.4E.C9 0F 0D 00 06 (00) Tue 08/13/2013 02:30:24 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 0D 02 (02) Tue 08/13/2013 02:30:24 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:24 PM : [iNST-TX-I1 ] 02 62 1C 4E C9 0F 10 00 Tue 08/13/2013 02:30:24 PM : [iNST-ACK ] 02 62 1C.4E.C9 0F 10 00 06 ID-REQ (00) Tue 08/13/2013 02:30:24 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 10 00 ID-REQ (00) Tue 08/13/2013 02:30:24 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:25 PM : [iNST-SRX ] 02 50 1C.4E.C9 00.12.37 8B 02 14 (14) Tue 08/13/2013 02:30:25 PM : [std-Broadcast] 1C.4E.C9-->00.12.37, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:25 PM : [1C 4E C9 0 ] Calibrating engine version Tue 08/13/2013 02:30:25 PM : [iNST-TX-I2CS] 02 62 1C 4E C9 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 Tue 08/13/2013 02:30:25 PM : [iNST-ACK ] 02 62 1C.4E.C9 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06 (00) Tue 08/13/2013 02:30:25 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 2F 00 (00) Tue 08/13/2013 02:30:25 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:26 PM : [iNST-ERX ] 02 51 1C 4E C9 21 32 B0 11 2F 00 00 01 0F FF 01 E2 01 21 32 B0 FF 00 01 DB Tue 08/13/2013 02:30:26 PM : [Ext-Direct ] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Tue 08/13/2013 02:30:26 PM : [1C 4E C9 0 ] Using Database Link Table offset 0x0FF8 (reported 0x0FF8) Tue 08/13/2013 02:30:26 PM : [iNST-TX-I1 ] 02 62 1C 4E C9 0F 1F 00 Tue 08/13/2013 02:30:26 PM : [iNST-ACK ] 02 62 1C.4E.C9 0F 1F 00 06 GOF (FLAGS) Tue 08/13/2013 02:30:26 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 1F B2 GOF (B2) Tue 08/13/2013 02:30:26 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:26 PM : [1C 4E C9 1 ] Start : Adding device to ISY Tue 08/13/2013 02:30:26 PM : [1C 4E C9 1 ] Finish : Adding device to ISY was Successful Tue 08/13/2013 02:30:27 PM : [1C 4E C9 1 ] Link 0 : 0FF8 [E2012132B0FF0001] Saving [E2012132B0FF0001] Tue 08/13/2013 02:30:27 PM : [iNST-TX-I1 ] 02 62 1C 4E C9 0F 1F 00 Tue 08/13/2013 02:30:27 PM : [iNST-ACK ] 02 62 1C.4E.C9 0F 1F 00 06 GOF (FLAGS) Tue 08/13/2013 02:30:27 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 1F B2 GOF (B2) Tue 08/13/2013 02:30:27 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:27 PM : [1C 4E C9 2 ] Start : Adding device to ISY Tue 08/13/2013 02:30:27 PM : [1C 4E C9 2 ] Finish : Adding device to ISY was Successful Tue 08/13/2013 02:30:28 PM : [1C 4E C9 2 ] Link 1 : 0FF0 [E2022132B0FF0002] Saving [E2022132B0FF0002] Tue 08/13/2013 02:30:28 PM : [1C 4E C9 3 ] Start : Adding device to ISY Tue 08/13/2013 02:30:28 PM : [1C 4E C9 3 ] Finish : Adding device to ISY was Successful Tue 08/13/2013 02:30:28 PM : [1C 4E C9 3 ] Link 2 : 0FE8 [E2032132B0FF0003] Saving [E2032132B0FF0003] Tue 08/13/2013 02:30:28 PM : [1C 4E C9 4 ] Start : Adding device to ISY Tue 08/13/2013 02:30:28 PM : [1C 4E C9 4 ] Finish : Adding device to ISY was Successful Tue 08/13/2013 02:30:29 PM : [1C 4E C9 4 ] Link 3 : 0FE0 [E2042132B0FF0004] Saving [E2042132B0FF0004] Tue 08/13/2013 02:30:29 PM : [1C 4E C9 5 ] Start : Adding device to ISY Tue 08/13/2013 02:30:29 PM : [1C 4E C9 5 ] Finish : Adding device to ISY was Successful Tue 08/13/2013 02:30:29 PM : [1C 4E C9 5 ] Link 4 : 0FD8 [E2052132B0FF0005] Saving [E2052132B0FF0005] Tue 08/13/2013 02:30:30 PM : [1C 4E C9 6 ] Start : Adding device to ISY Tue 08/13/2013 02:30:30 PM : [1C 4E C9 6 ] Finish : Adding device to ISY was Successful Tue 08/13/2013 02:30:30 PM : [1C 4E C9 6 ] Link 5 : 0FD0 [E2062132B0FF0006] Saving [E2062132B0FF0006] Tue 08/13/2013 02:30:30 PM : [1C 4E C9 7 ] Start : Adding device to ISY Tue 08/13/2013 02:30:30 PM : [1C 4E C9 7 ] Finish : Adding device to ISY was Successful Tue 08/13/2013 02:30:30 PM : [1C 4E C9 7 ] Link 6 : 0FC8 [E2072132B0FF0007] Saving [E2072132B0FF0007] Tue 08/13/2013 02:30:31 PM : [1C 4E C9 8 ] Start : Adding device to ISY Tue 08/13/2013 02:30:31 PM : [1C 4E C9 8 ] Finish : Adding device to ISY was Successful Tue 08/13/2013 02:30:31 PM : [1C 4E C9 8 ] Link 7 : 0FC0 [E2082132B0FF0008] Saving [E2082132B0FF0008] Tue 08/13/2013 02:30:31 PM : [iNST-TX-I1 ] 02 62 1C 4E C9 0F 1F 00 Tue 08/13/2013 02:30:31 PM : [iNST-ACK ] 02 62 1C.4E.C9 0F 1F 00 06 GOF (FLAGS) Tue 08/13/2013 02:30:32 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 1F B2 GOF (B2) Tue 08/13/2013 02:30:32 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:32 PM : [1C 4E C9 0 ] Successfully added device Tue 08/13/2013 02:30:35 PM : [All ] Writing 68 bytes to devices Tue 08/13/2013 02:30:35 PM : [1C 4E C9 1 ] Link 0 : 0FF8 [E2012132B0FF0001] Writing [E2012132B0FF0001] Tue 08/13/2013 02:30:35 PM : [iNST-TX-I2CS] 02 62 1C 4E C9 1F 2F 00 00 02 0F FF 08 E2 01 21 32 B0 FF 00 01 D3 Tue 08/13/2013 02:30:35 PM : [iNST-ACK ] 02 62 1C.4E.C9 1F 2F 00 00 02 0F FF 08 E2 01 21 32 B0 FF 00 01 D3 06 (00) Tue 08/13/2013 02:30:35 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 2F 00 (00) Tue 08/13/2013 02:30:35 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:36 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1C 4E C9 00 12 37 15 Tue 08/13/2013 02:30:36 PM : [PLM ] Group 1 : Writing Responder Link matching [1C 4E C9 1 ] Link 0 : 0FF8 [E2012132B0FF0001] Tue 08/13/2013 02:30:36 PM : [1C 4E C9 1 ] Link 1 : 0FF0 [E2022132B0FF0002] Writing [E2022132B0FF0002] Tue 08/13/2013 02:30:36 PM : [iNST-TX-I2CS] 02 62 1C 4E C9 1F 2F 00 00 02 0F F7 08 E2 02 21 32 B0 FF 00 02 D9 Tue 08/13/2013 02:30:36 PM : [iNST-ACK ] 02 62 1C.4E.C9 1F 2F 00 00 02 0F F7 08 E2 02 21 32 B0 FF 00 02 D9 06 (00) Tue 08/13/2013 02:30:37 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 2F 00 (00) Tue 08/13/2013 02:30:37 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:37 PM : [MNG-LNK-RSP ] 02 6F 41 A2 02 1C 4E C9 00 12 37 15 Tue 08/13/2013 02:30:37 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 23 2F 00 (00) Tue 08/13/2013 02:30:37 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Tue 08/13/2013 02:30:37 PM : [PLM ] Group 2 : Writing Responder Link matching [1C 4E C9 1 ] Link 1 : 0FF0 [E2022132B0FF0002] Tue 08/13/2013 02:30:38 PM : [1C 4E C9 1 ] Link 2 : 0FE8 [E2032132B0FF0003] Writing [E2032132B0FF0003] Tue 08/13/2013 02:30:38 PM : [iNST-TX-I2CS] 02 62 1C 4E C9 1F 2F 00 00 02 0F EF 08 E2 03 21 32 B0 FF 00 03 DF Tue 08/13/2013 02:30:38 PM : [iNST-ACK ] 02 62 1C.4E.C9 1F 2F 00 00 02 0F EF 08 E2 03 21 32 B0 FF 00 03 DF 06 (00) Tue 08/13/2013 02:30:38 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 2F 00 (00) Tue 08/13/2013 02:30:38 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:39 PM : [MNG-LNK-RSP ] 02 6F 41 A2 03 1C 4E C9 00 12 37 15 Tue 08/13/2013 02:30:39 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 23 2F 00 (00) Tue 08/13/2013 02:30:39 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Tue 08/13/2013 02:30:39 PM : [iNST-DUP ] Previous message ignored. Tue 08/13/2013 02:30:39 PM : [PLM ] Group 3 : Writing Responder Link matching [1C 4E C9 1 ] Link 2 : 0FE8 [E2032132B0FF0003] Tue 08/13/2013 02:30:39 PM : [1C 4E C9 1 ] Link 3 : 0FE0 [E2042132B0FF0004] Writing [E2042132B0FF0004] Tue 08/13/2013 02:30:39 PM : [iNST-TX-I2CS] 02 62 1C 4E C9 1F 2F 00 00 02 0F E7 08 E2 04 21 32 B0 FF 00 04 E5 Tue 08/13/2013 02:30:39 PM : [iNST-ACK ] 02 62 1C.4E.C9 1F 2F 00 00 02 0F E7 08 E2 04 21 32 B0 FF 00 04 E5 06 (00) Tue 08/13/2013 02:30:40 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 2F 00 (00) Tue 08/13/2013 02:30:40 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:40 PM : [MNG-LNK-RSP ] 02 6F 41 A2 04 1C 4E C9 00 12 37 15 Tue 08/13/2013 02:30:40 PM : [PLM ] Group 4 : Writing Responder Link matching [1C 4E C9 1 ] Link 3 : 0FE0 [E2042132B0FF0004] Tue 08/13/2013 02:30:40 PM : [1C 4E C9 1 ] Link 4 : 0FD8 [E2052132B0FF0005] Writing [E2052132B0FF0005] Tue 08/13/2013 02:30:40 PM : [iNST-TX-I2CS] 02 62 1C 4E C9 1F 2F 00 00 02 0F DF 08 E2 05 21 32 B0 FF 00 05 EB Tue 08/13/2013 02:30:40 PM : [iNST-ACK ] 02 62 1C.4E.C9 1F 2F 00 00 02 0F DF 08 E2 05 21 32 B0 FF 00 05 EB 06 (00) Tue 08/13/2013 02:30:41 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 2F 00 (00) Tue 08/13/2013 02:30:41 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:42 PM : [MNG-LNK-RSP ] 02 6F 41 A2 05 1C 4E C9 00 12 37 15 Tue 08/13/2013 02:30:42 PM : [PLM ] Group 5 : Writing Responder Link matching [1C 4E C9 1 ] Link 4 : 0FD8 [E2052132B0FF0005] Tue 08/13/2013 02:30:42 PM : [1C 4E C9 1 ] Link 5 : 0FD0 [E2062132B0FF0006] Writing [E2062132B0FF0006] Tue 08/13/2013 02:30:42 PM : [iNST-TX-I2CS] 02 62 1C 4E C9 1F 2F 00 00 02 0F D7 08 E2 06 21 32 B0 FF 00 06 F1 Tue 08/13/2013 02:30:42 PM : [iNST-ACK ] 02 62 1C.4E.C9 1F 2F 00 00 02 0F D7 08 E2 06 21 32 B0 FF 00 06 F1 06 (00) Tue 08/13/2013 02:30:42 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 2F 00 (00) Tue 08/13/2013 02:30:42 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:43 PM : [MNG-LNK-RSP ] 02 6F 41 A2 06 1C 4E C9 00 12 37 15 Tue 08/13/2013 02:30:43 PM : [PLM ] Group 6 : Writing Responder Link matching [1C 4E C9 1 ] Link 5 : 0FD0 [E2062132B0FF0006] Tue 08/13/2013 02:30:43 PM : [1C 4E C9 1 ] Link 6 : 0FC8 [E2072132B0FF0007] Writing [E2072132B0FF0007] Tue 08/13/2013 02:30:43 PM : [iNST-TX-I2CS] 02 62 1C 4E C9 1F 2F 00 00 02 0F CF 08 E2 07 21 32 B0 FF 00 07 F7 Tue 08/13/2013 02:30:43 PM : [iNST-ACK ] 02 62 1C.4E.C9 1F 2F 00 00 02 0F CF 08 E2 07 21 32 B0 FF 00 07 F7 06 (00) Tue 08/13/2013 02:30:44 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 2F 00 (00) Tue 08/13/2013 02:30:44 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:44 PM : [MNG-LNK-RSP ] 02 6F 41 A2 07 1C 4E C9 00 12 37 15 Tue 08/13/2013 02:30:44 PM : [PLM ] Group 7 : Writing Responder Link matching [1C 4E C9 1 ] Link 6 : 0FC8 [E2072132B0FF0007] Tue 08/13/2013 02:30:45 PM : [1C 4E C9 1 ] Link 7 : 0FC0 [E2082132B0FF0008] Writing [E2082132B0FF0008] Tue 08/13/2013 02:30:45 PM : [iNST-TX-I2CS] 02 62 1C 4E C9 1F 2F 00 00 02 0F C7 08 E2 08 21 32 B0 FF 00 08 FD Tue 08/13/2013 02:30:45 PM : [iNST-ACK ] 02 62 1C.4E.C9 1F 2F 00 00 02 0F C7 08 E2 08 21 32 B0 FF 00 08 FD 06 (00) Tue 08/13/2013 02:30:45 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 2F 00 (00) Tue 08/13/2013 02:30:45 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:46 PM : [MNG-LNK-RSP ] 02 6F 41 A2 08 1C 4E C9 00 12 37 15 Tue 08/13/2013 02:30:46 PM : [PLM ] Group 8 : Writing Responder Link matching [1C 4E C9 1 ] Link 7 : 0FC0 [E2082132B0FF0008] Tue 08/13/2013 02:30:46 PM : [1C 4E C9 1 ] Link 8 : 0FB8 [0000000000000000] Writing [00..............] Tue 08/13/2013 02:30:46 PM : [iNST-TX-I2CS] 02 62 1C 4E C9 1F 2F 00 00 02 0F BF 08 00 00 00 00 00 00 00 00 F9 Tue 08/13/2013 02:30:46 PM : [iNST-ACK ] 02 62 1C.4E.C9 1F 2F 00 00 02 0F BF 08 00 00 00 00 00 00 00 00 F9 06 (00) Tue 08/13/2013 02:30:47 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 2F 00 (00) Tue 08/13/2013 02:30:47 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:47 PM : [1C 4E C9 1 ] Link 9 : 0FB0 : Writing High Water Byte Tue 08/13/2013 02:30:47 PM : [iNST-TX-I2CS] 02 62 1C 4E C9 1F 2F 00 00 00 0F B7 01 00 00 00 00 00 00 00 00 0A Tue 08/13/2013 02:30:47 PM : [iNST-ACK ] 02 62 1C.4E.C9 1F 2F 00 00 00 0F B7 01 00 00 00 00 00 00 00 00 0A 06 (00) Tue 08/13/2013 02:30:47 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 2F 00 (00) Tue 08/13/2013 02:30:47 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:48 PM : [iNST-ERX ] 02 51 1C 4E C9 21 32 B0 11 2F 00 00 01 0F B7 01 00 00 00 00 00 00 00 00 09 Tue 08/13/2013 02:30:48 PM : [Ext-Direct ] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Tue 08/13/2013 02:30:48 PM : [iNST-TX-I2CS] 02 62 1C 4E C9 1F 2F 00 00 00 0F B7 01 00 00 00 00 00 00 00 00 0A Tue 08/13/2013 02:30:48 PM : [iNST-ACK ] 02 62 1C.4E.C9 1F 2F 00 00 00 0F B7 01 00 00 00 00 00 00 00 00 0A 06 (00) Tue 08/13/2013 02:30:49 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 2F 00 (00) Tue 08/13/2013 02:30:49 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:49 PM : [iNST-ERX ] 02 51 1C 4E C9 21 32 B0 11 2F 00 00 01 0F B7 01 00 00 00 00 00 00 00 00 09 Tue 08/13/2013 02:30:49 PM : [Ext-Direct ] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Tue 08/13/2013 02:30:49 PM : [iNST-TX-I2CS] 02 62 1C 4E C9 1F 2F 00 00 02 0F B7 08 00 00 00 00 00 00 00 00 01 Tue 08/13/2013 02:30:49 PM : [iNST-ACK ] 02 62 1C.4E.C9 1F 2F 00 00 02 0F B7 08 00 00 00 00 00 00 00 00 01 06 (00) Tue 08/13/2013 02:30:50 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 2B 2F 00 (00) Tue 08/13/2013 02:30:50 PM : [std-Direct Ack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:50 PM : [1C 4E C9 1 ] Memory : Write dbAddr=0x1005 [0E] cmd1=0x20 cmd2=0x0E Tue 08/13/2013 02:30:50 PM : [iNST-TX-I1 ] 02 62 1C 4E C9 0F 20 0E Tue 08/13/2013 02:30:50 PM : [iNST-ACK ] 02 62 1C.4E.C9 0F 20 0E 06 (0E) Tue 08/13/2013 02:30:50 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 AB 20 FD (FD) Tue 08/13/2013 02:30:50 PM : [std-Direct Nack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:50 PM : [1C 4E C9 1 ] Memory : Write dbAddr=0x1004 [08] cmd1=0x20 cmd2=0x08 Tue 08/13/2013 02:30:50 PM : [iNST-TX-I1 ] 02 62 1C 4E C9 0F 20 08 Tue 08/13/2013 02:30:50 PM : [iNST-ACK ] 02 62 1C.4E.C9 0F 20 08 06 (08) Tue 08/13/2013 02:30:51 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 AB 20 FD (FD) Tue 08/13/2013 02:30:51 PM : [std-Direct Nack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:51 PM : [1C 4E C9 1 ] Memory : Write dbAddr=0x1003 [05] cmd1=0x20 cmd2=0x05 Tue 08/13/2013 02:30:51 PM : [iNST-TX-I1 ] 02 62 1C 4E C9 0F 20 05 Tue 08/13/2013 02:30:51 PM : [iNST-ACK ] 02 62 1C.4E.C9 0F 20 05 06 (05) Tue 08/13/2013 02:30:51 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 AB 20 FD (FD) Tue 08/13/2013 02:30:51 PM : [std-Direct Nack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Tue 08/13/2013 02:30:51 PM : [1C 4E C9 1 ] Memory : Write dbAddr=0x1002 [02] cmd1=0x20 cmd2=0x02 Tue 08/13/2013 02:30:51 PM : [iNST-TX-I1 ] 02 62 1C 4E C9 0F 20 02 Tue 08/13/2013 02:30:51 PM : [iNST-ACK ] 02 62 1C.4E.C9 0F 20 02 06 (02) Tue 08/13/2013 02:30:52 PM : [iNST-SRX ] 02 50 1C.4E.C9 21.32.B0 AB 20 FD (FD) Tue 08/13/2013 02:30:52 PM : [std-Direct Nack] 1C.4E.C9-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
  6. Ok, I did some testing. First, I did the PLM restore, no change. I then deleted and added the remotes, no change. I took the remotes back to my office and added them to a 99i running 3.3.10, they worked great. To summarize, I have two 994i - 4.0.5 installations that have this issue and a 99i - 3.3.10 that does not. I suspect a bug in the 994i and/or 4.0.5 version of firmware. Thank you for your help. -Paul
  7. Hello All, I have installed mini remotes (RemoteLinc2) in a couple of ISY systems. They work great in scenes for controlling other INSTEON devices. But, I can't get them to control programs and variables. When I run a trace, at any level, I don't see any traffic generated by them. Scenes work, but nothing is shown on the ISY. I need to program these remotes to increment variables for ceiling fan and window shade control. Until the ISY sees the commands they generate, I'm stuck. I've tried restoring, deleting and then adding them again, holding them close to the dual-band PLM when pressing buttons, and adding the buttons to scenes and devices; everything short of animal sacrifice. Nothing works. Any ideas? Thank you.
  8. plars3n posted a topic in ISY994
    Hello, I have just installed a SeriaLinc into an existing ISY99i based system. I would now like to control that SeriaLinc using the ISY. Is there any current way to do this? If not, is there a plan to support this device in the future? Thank you, -Paul
