AT&T to end email-to-text ×
muck4618
  • Posts
    18
Everything posted by muck4618
  1. That worked! Thanks for your help!
  2. Thanks! I will see if I can get it working tonight.
  3. I think that using a variable is the way to go but I don't know how to set them up. I have a feeling that after I figure out how to create variables it will open up a lot of options to me.
  4. I created a program using the ELK module that will send an email if Elk keypad access code is not invalid. It sends an email if a valid or invalid access code is entered. Does anyone else have this problem?
  5. I have a TriggerLinc on a back door that I would like to turn on the light (SwitchLinc) the first time the door is opened/closed and then off the next time the door is opened/closed. Scenario is that the wife wants the light to come on when we let the dog out and turn off when we open the door to let the dog in. I can't figure it out. Thanks in advance for your help. Scott
  6. The TriggerLinc is registering correctly now in that the Open/Closed state change when the door is opened or closed. I removed the "else" and the light comes on as expected. Now the wife wants the light to come on when we open the door to let the dog out (between sunset/sunrise) and stay on until we open the door again to let him back in.
  7. I verified that the jumper is attached and I removed the battery for a while to make sure it applies. I think it might be triggering correctly because I can get it to turn the light on but it also turns on at sunset. I just want it to turn the light on between sunset and sunrise. If From Sunset To Sunrise (next day) And Status '14.49.3E-Opened' is On Then Set 'Master Door Light' Fast On Else Set 'Master Door Light' Off
  8. I just installed a togglelinc which is being monitored by an ISY-99i but the state of the Open and Close devices are always "On". Shouldn't Open be Off when the door is closed. I just want to create a program in the ISY to turn the light On when the door is open and not turn it off when it is closed. I have tried jumper on and off. Thanks in advance for any suggestions
  • Create New...
