Thank you, that did it (deleting and re-adding the affected devices).
Curiously I needed to update my programs, even though it seemed to map to the new devices automatically anyway.
I have a Lamplinc that doesn't work already plugged into the same spot as one that does work and its on the same plug as the PLM.
I've previously upgraded to 3.2.6 as well.
Would signal issues explain why the scenes always fail, but directly commanding the device from ISY always works?
I currently have the PLM and 2 of the Lamplincs plugged in at the same spot, one lamp works, the other doesn't in scenes. The other Lamplinc that doesn't work is a dual band on the other phase that is bridging the phases with the PLM.
I've got some lamplincs and controlincs. I've linked them to ISY and I can control the lamplincs individually via ISY. I created a scene for each lamplinc and put the lamplinc and a button from each of the controlincs into the scene. The controlincs physically work to turn off the lamps as desired, but only one of the scenes will cycle the lamp when directed by ISY online. Even then, it shows the controlincs as "Failed" status during a scene test. The other scenes show all devices as "Failed".
I'm relatively new to Insteon and ISY so I'm having trouble figuring out where I've gone wrong. Any pointers as to where to look or what to try?
