pyroman175@yahoo.com
  1. Ok between the two of you I might get this. Lol. The third line is the relay for the swamp cooler to turn on. Are you guys saying I stead of directly turning the device on at the relay, I turn it on in the scene instead? The fifth line was just for the status of the relay and the 2 second delay was just to prevent to much traffic at once
  2. Thanks lee, but I also tried that with no luck, the relay comes on but the kpl status didn't change.
  3. Hey guys I can't seem to get this to work. I have a swamp cooler controlled by a relay. I can get the kpl to control the swampe cooler and show the right status, but I also have a program that will activate or shut off the swamper during certain climate conditions and this is where the kpl light won't activate or deactivate .....any help would be great. Thanks pete
  4. Great thank you so much Indymike. I will make adjustments to the crop coefficient until it matches the farm down the road. Mohave#2 that you got the information of .28 is only about 4 miles down the road. I will now have something to compare to and dial it in exactly the way I need it. Thank you for your time and effort into my problem
  5. it seems my irrigation is not calculating the right amount, can you see if this is set up correctly? It was over 102 degrees yesterday and it only shows .1575 deficit. do i need to change the crop coefficient? I have palm tress and grass. Just so you know this screen capture was taken at 0730 this morning
  6. I agree with jmed999 is there any info on the new irrigation calcs? I live in Arizona and it gets to 120 during the day here, wind would always give me more water requirements than a 100 degree day would. I hope the new calcs will be better for the heat. Thanks Michel
  7. Yes I was wondering why my irrigation never activated this morning after a hot day yesterday. Noticed weatherbug backyard stations are down again. Michael I sure hope you guys integret davis weather stations into the ISY soon
  8. Thank you sir, I'm up and running !!!!
  9. cool thanks up and running paid the $18 and it is now on weatherbug. problem now is i cant't get isy99 to locate it in the climate module. It still only shows other weather stations but not mine. any ideas thanks pete
  10. Hey Michel I have a problem with a switchlinc 2486s. It tells me I've lost communication on my isy994 but on my mobilinc it's shows the status both off and on, but I'm unable to control it through mobilinc. Any help would be appreciated
  11. I have the davis pro 2 and would love to do this, but don't see where to sign up for $18.00 a year. It says there's a $50 sign up fee plus a monthly fee. Please let me know where to sign up for $18 a year. Thanks pete
  12. hey michel does this look right? i use this command instead of the rain and over 70 degree commands. the .09 is just to see if it activates
