ferdies
  1. Excellent. I did not know that and maybe have missed reading it in the instructions. I received the access code after launching the skills! Will work on it now using my network module. Thank you!
  2. Hi Ranyth, I have downloaded the app from the alexa skill store successfully a week back. However, I was not able to receive an email with regard to the authorization. Checked my spam folder as well but it is not there as well. Any suggestions? Thanks!
  3. Hi, Anyone who has a current setup of: GLYDEA™ Z-WAVE® PLUG IN MODULE (https://www.somfysystems.com/file.cfm/Z-Wave_Glydea_Instructions.pdf?contentID=284865) Somfy Controller ISY? What is your experience so far? Thanks.
  4. Hi - do you have any feedback on Insteon or Z-Wave Switch and Philips Hue Bulbs? Is it s good option? Thanks
  5. Hi, I need your expert opinion on this as I am designing the lighting system for the new house we are planning to build. Lighting System: 1. I like the concept of having to change colour hues by utilizing Philips Hue bulbs and the associated bridge 2. Legrand Wave Switch and Micro-Module – in key strategic locations in the house (I am planning to have most the individual switches (combination of Insteon and Z-Wave switches/dimmer) to be hidden in the control room to have a clean and minimalist interior). Micro module will be will be linked and controlled by ISY programs (scene, switch, network modules, etc). These Wave Switch and Micro Modules combos would essentially turn on most/if not all lights per pre-defined zones. http://forum.universal-devices.com/topic/19282-legrand-adorne-switch-and-z-wave-micro-module-pairing/ 3. Motion sensors – via ELK Systems. Purpose: Lights ON/Occupancy sensor, etc. Potentially Wave Switch may not be always being used since motions will determine if lights should be turned on or off. Again, I have to work on the program logic 4. Alexa – for voice activation 5. And potentially the list goes on and on, depending on the budget availability. My current concern is on Item #1 (instead of using standard LED bulbs) but to use Philips HUE bulbs – again to have different colour availability AND Insteon/Z-Wave switches and dimmers. Does plan the sound ridiculous and an over kill? What is another option/cheaper alternative you guys could suggest? Insteon/Z-Wave switches have to on to control Philips Hue bulbs, correct? I.e. changing colours, etc… https://www.reddit.com/r/amazonecho/comments/42b2is/do_you_guys_leave_the_light_switch_up_when_a_hue/. Possibly, turn lights on/changing colours would be a 2-step process which obviously would add more delays! System design dilemma that requires your expert opinion. J Security: 1. ELK System Z-Waves · Door Locks Thanks!
  6. Thanks! I was thinking there was a way to disable ALL programs all at the same time. I guess I have to do it individually Sent from my Nexus 7 using Tapatalk
  7. Or is there any way to disable all programs? Thanks.
  8. Thanks for the feedback, Michel. Just to provide more clarity - I have only few Insteon device in my new place, and mostly, plug-ins devices. So essentially, I wanted to do is to access programs and list of variables offline so I can copy some programs. could I save into a file all my programs and other configs, not using backup? Again, I have moved to a new place but I brought some plug-in devices and my ISY. Thanks.
  9. Hi, I had my ISY's configs (variables, email notifications/contents) and programs I want to preserve and reference back from my old install. What is the best way to do it? I don't want to re-create some of the programs but I am in a temporary place at the the moment with less devices and would like to use only a some features/programs I have created. I will then have a full-blown version when I move to a permanent one (http://forum.universal-devices.com/topic/19218-new-installation-insteon-or-z-wave/. Appreciate the feedback.
  10. Thank you! Do you mind further elaborating on RTI. I have checked this website for an introduction. http://www.rticorp.com/. I am assuming that RTI would be responsible for integrating all these disparate systems, correct? Is it designed for a DYIer? Or professional installer is required? Based on prelim research - it has to be installed by custom electronics professionals.
  11. That's correct. I was thinking about that. Since I am in the process of building a house, I will do this as per this website: "A 4-in. junction box solves most box-fill problems. Throw on a single- or double-gang plaster ring that comes flush with the drywall, and you’ve got a box that’s hard to overfill." http://www.finehomebuilding.com/2001/12/01/more-wires-need-bigger-boxes Plastter covers are available - http://www.alliedmoulded.com/catalog/residential-products/electrical-box-covers-plaster-rings/4-square-junction-box-plaster-rings-and-covers/ SO I am assuming that this will work, correct?
  12. Hi, Since I like the idea of wave switch so I am planning to use Legrand WaveSwitch (http://www.legrand.us/adorne/products/switches/aswv1532w2.aspx) and pair it with Aeon Z-wave In-Wall Micro controller (https://www.amazon.com/Aeon-Labs-DSC26103-ZWUS-Wall-Controller/dp/B008VWBNAU). Do you think there will be an issue on this pairing? Thanks.
  13. Thanks Scottmichaelj! Yes, really the objective is to make sure that I can integrate most of these things together. In my previous installation, it was basically all workarounds and a bit messy. I am not familiar with openHAB but I will further explore. I did an initial research since I would also like to integrate Asterisk with openHAB binding (yes - I am still using Asterisk for my VoiP PBX. It worked and get phones calls if there's a trigger at home and other functions - https://github.com/openhab/openhab/wiki/Asterisk-Binding. But this is not the primary objective. Simplicity for a user's perspective (my kids and wife) as well as easy maintenance from my end is the key objective! Of course, aesthetics is important, hence I like the look and feel of Lutron devices. Appreciate the feedback.
  14. Thanks. What about Lutron Caseta? This is a DIY. Any chance for it to be compatible with ISY? Sent from my Nexus 7 using Tapatalk
  15. Thanks for all the feedback. Just to digress a bit from Z-Wave... Would it be possible to install Lutron (http://www.lutron.com/en-US/Products/Pages/WholeHomeSystems/Homeworksqs/Overview.aspx) and will ISY be able to control Homeworks? The reason I am asking is that I like the programming flexibility of ISY - NetWork Module. Or this will be an overkill? Appreciate it. Thanks.
