inline
  1. I upgraded to the 3.3.1 (Beta) without any issues. Also I tested and confirm working that my wildcard cert installed without issue and works correctly on my ISY. Thank you! Also, I don't see the lockup issue anymore in the admin console when looking at the electricity or weather usage.
  2. inline replied to a post in a topic in ISY994
    I use Kaspersky too. Go into the settings and then the Web antivirus part. Click the settings under security level and then go to the trusted URLs tab add the URL/IP for the ISY and you should be okay.
  3. I need this ability as well. I have a wildcard cert for my domain and I'd like to import it. My Synology NAS allows this, you just specify the certificate and the private key and it's done. Is this possible for the ISY? If not, can this be implemented? I don't want to generate a new CSR when I have a perfectly fine wildcard cert that works....
