ronvond
  1. ronvond replied to ronvond's topic in eisy
    I didn’t realize that UDI had such great service. By the time I re-checked the status of my order my new EISHY was in my mailable. Thank you!
  2. ronvond replied to ronvond's topic in eisy
    I did receive the email, but just getting anxious for delivery. Patience was never one of my strong points!! Thanks for your response.
  3. ronvond posted a topic in eisy
    I recently ordered an Eisy, Zmatter USB and adaptor cable. How can I check order status? Thanks Ron
  4. ronvond replied to ronvond's topic in eisy
    Can someone supply a link to the UDI parts catalog?
  5. ronvond posted a topic in eisy
    I recently upgraded my system to the Polisy after installing the z-wave z-matter board. I seem to do this right after there is a major system upgrade. I would like to hopefully do a final upgrade. In addition to the z-wave / z-matter upgrade, I am using a 2413s rev 2.4 0318 with a spare 2413s Rev 2.5 4718 on the shelf. In addition to the EISY I would have to purchase the USB enclosure for the z-wave/z-matter board as well as the connecting cable for the 2413. Are there any other pieces/parts I should be ordering? Also, are these parts available for immediate delivery or is there a backorder issue. Thanks for your help, Ron
  6. In the process of upgrading my SSD before installing ZMatter I noticed the reference slot is in what appears to be the wrong position on the SSD board. Is this a manufacturing error or can I simply install the board upside down. I don't want to risk destroying my Polisy. Thanks, Ron
  7. The problem may be with your iPhone, not with ISY. I experienced the same issue using MobiLinc Pro. In your iPhone settings make sure your "Allow Location Access" is set to ALWAYS. Not "While Using The App"
  8. It does look like a straight forward program. Could I ask why the “dusk/dawn” line is in the program? If there’s a good reason to have that in the program you might want to add parentheses bracketing the entire IF statement.
  9. Mr. Bill. Thank you for the advice on Insteon traffic during a link count. I never knew that. I tried it and you're right. I went from 232 to 82 after tripping a motion sensor.
  10. ronvond replied to paulw's topic in ISY994
    Nothing happening here yet. I guess you just got lucky. Ron
  11. ronvond replied to paulw's topic in ISY994
    My MobiLinc Pro also mysteriously stopped working without any changes to the system. My ISY is working fine. I also have MobiLinc X and that continues to work. I tried rebooting the ISY, accessing the MobiLinc Pro from various computers. No luck. It just appears dead. I have sent in a request for service to MobiLinc.
  12. Responding to the geofence comment. Thank you! I've been tearing my hair out trying to figure why my wife's iPhone 6, version 12.5.5. works fine and my iPhone 12, version 15.2 fails.
  13. Ed, I had the same problem with all my Christmas programs. I placed all the programs in a folder called Christmas Programs. I then use a variable to enable / disable all programs in the folder. If $Christmas_Programs > 49 Then Allow the programs in this folder to run.
  14. Query All - [ID 0002][Parent 0001] If Time is 3:00:00AM Then Set 'ISY' Query Else - No Actions - (To add one, press 'Action') Factory Query Program
  15. By default, at least on my system, the default ramp rate for the devices is set to 9 minutes. Please check to make sure that is not your problem. Good luck, Ron
