rick.curl
  1. Aidot does offer matter sharing, but only to other users of the Aidot app. Google Home and Smarthome will both require that I install a matter hub. I thought Eisy would serve as a Matter hub. Will Eisy eventually support adding Matter devices without having to add another hub or gateway? I'm confused.
  2. Good catch! I had missed that IPV6 was required. Got it turned on now, but I'm still getting "Could not add Matter Device. Bluetooth Unsubscribed. 500" I don't have Google Home. I can successfully add these smart plugs to the Aidot app (from their manufacturer). I did reset the plugs to factory default before trying to add them to the Eisy.
  3. Android. It's a Google Pixel 7. I did upgrade to 5.9.1.18, but no joy. Looking forward to getting this working. I really need to be able to control a few devices via Wifi instead of PLC or Insteon's mesh RF system. We've got a big piece of property and our Wifi network has outdoor repeaters.
  4. Last week I tried to pair a Linkind Smartplug LC09003-PLUG-US-4 and I got this error message:. Could not get Matter QR Code rendezvous Type for MT:4Q0002:E15S60F76G00. 500 At the time I was on 5.9.1.7. I upgraded to 5.9.1.17 and tried again. I thought for a minute that it was going to work, but UD mobile finally gave me the error message: "could not add Matter Device. Bluetooth Unsubscribed. 500". Any idea what it is telling me?
  5. I wonder if Pushover might be the solution. Look here: https://pushover.net I am using it to send me text messages from Eisy when my generator is running. -Rick
  6. Similar problems here. I got a pack of four Linkind Smartplugs LC09003-PLUG-US-4. When I try to add them by scanning the QR code with UD mobile, I get: Could not get Matter QR Code rendezvous Type for MT:4Q0002:E15S60F76G00. 500 Hopefully somebody will straighten it out soon....... -Rick
  7. That makes a lot of sense I didn't know that. I just replaced the Zigbee smart switch with a different brand and all is good now. Thanks for the help!
  8. it looks like this is an issue with Wooley smart plugs. Not the fault of Eisy. Now that I know this- is there a way I can write a program so if a scene is switched on, to send the "on" commend every 5 minutes or so? I thought it would have been easy, but under the "if" section of code I can check a number of things, but I don't see a way to check to see if a scene is turned on or not. Am I missing something obvious? -Rick
  9. I got the bookcase moved so I can see the Zigbee device. It's a Woolley SA-035-10A-ZB: https://www.aliexpress.us/item/3256805874315420.html It also has the number BSD17 on it. There's nothing in the instruction sheet that indicates a default timing function. Any thoughts? Thanks.
  10. Unfortunately the switch is in a wall box behind a big heavy bookcase. I'll try to get access to it in the next couple days. I really should have made a note of the type of switch. Lesson learned. -Rick
  11. Thanks. Previous logs: Four logs giving the time: [ Time] 19:52:30 60(0) preceeded by: Create Rest U7 [/rest/profiles/ns/3/connection] Create Rest U7 [/rest/profiles/ns/4/connection] Create Rest U7 [/rest/profiles/ns/0/connection] Before that there were a bunch more entries giving the time. Does this help? I would have uploaded the log, but I only printed a screen.
  12. I recently added a Zigbee wall switch to control fans in my living room and it is generally working, but the fabs unexpectedly turn off after about half an hour. If I turn on the event viewer at level 3 I see this when the fans turn off: [D2D Event ] Event [ZB55785_001_1] [ST] [0] uom-78 prec = 0 [ZB55785_001_1] ST 0 (uom=78 prec=0) What is this telling me? Thanks! -Rick
  13. UPDATE: I unplugged and re-plugged the PLM and the extra traffic is GONE! Hope it stays that way.
  14. I tried it with and without the extra tap. No joy. In case it was the DZPA1 at fault, I tried to add a Minoston MP20Z and it failed too.
  15. I have exactly the same issue, and, like you, I am seeing the traffic from 02 52 FF 80 a couple times a second. I don't have a spare PLM. Should I try to get one? I wonder if anyone else is seeing the same thing.
