abelaguilar
Everything posted by abelaguilar
  1. Does anyone know how to send direct commands to insteon devices from within the isy interface? I had the insteon led light bulbs and during power failures or outages, the unit may get stuck in an off command and the only way to turn it off so that it can resync is via this custom command set. I have done it inthe past with the smartlinc web interface software using a smartlinc 2412n.
  2. Thank you for the reponse. I will have to look into phase coupling. Are you using a plm to transmitt >300 ft away?
  3. I just found out from smarthome that the 2413S will interface with the isy99 via port A. My only concern is, will the 300 ft cause a problem? I'll find out as soon as I receive it in the mail. Just trying to do some planning before it gets here.
  4. Hello: I recently ordered by isy99 and need to know how to send a signal to our front gate 300ft away to control insteon led lightbulbs. I have a cat 5 down there and I am using the smarthome smartlinc which I believe is not compatible with isy99. I think I need a PLM, but don't know if that distance is a problem. any suggestions? thanks again..!!
