Wozzy
Everything posted by Wozzy
  1. I am not running the windows firewall after enabling the java console here is the output after clicking http://www.universal-devices.com/99i/3.3.4/admin.jnlp put I still get the same error.. Java Web Start 10.9.2.05 Using JRE version 1.7.0_09-b05 Java HotSpot Client VM User home directory = C:\Users\bryan ---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message m: print memory usage o: trigger logging p: reload proxy configuration q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack 0-5: set trace level to ---------------------------------------------------- Match: beginTraversal Match: digest selected JREDesc: JREDesc[version 1.6+, heap=-1--1, args=null, href=http://java.sun.com/products/autodl/j2se, sel=false, null, null], JREInfo: JREInfo for index 0: platform is: 1.7 product is: 1.7.0_09 location is: http://java.sun.com/products/autodl/j2se path is: C:\Program Files (x86)\Java\jre7\bin\javaw.exe args is: null native platform is: Windows, x86 [ x86, 32bit ] JavaFX runtime is: JavaFX 2.2.3 found at C:\Program Files (x86)\Java\jre7\ enabled is: true registered is: true system is: true Match: ignoring maxHeap: -1 Match: ignoring InitHeap: -1 Match: digesting vmargs: null Match: digested vmargs: [JVMParameters] Match: JVM args after accumulation: [JVMParameters] Match: digest LaunchDesc: http://www.universal-devices.com/99i/3.3.4/admin.jnlp Match: digest properties: [] Match: JVM args: [JVMParameters] Match: endTraversal .. Match: JVM args final: Match: Running JREInfo Version match: 1.7.0.09 == 1.7.0.09 Match: Running JVM args match: have:<> satisfy want:<>
  2. I get ""Error" "Not Found"" after I click OK the ISY Finder comes up regardless of what I manually add (my IP or my URL) I get the same message
  3. Michel I am on Windows 7 Enterprise 64bit
  4. update seem to go fine from 3.2.6.. I can connect using direct internal IP address .. when I try and go through the Procedure to take care of the Certificates . after I go to http://www.universal-devices.com/99i/3. ... board.jnlp I get a "not Found" in the isy finder , I then try to add the IP and it still says "not found" isy 994i/ir pro please let me know what I doing wrong thanks
