pinuz
  1. Hello Michel, any good news?
  2. pinuz replied to CopyRon's topic in Amazon Echo
    +1 here, assumed functionality was removed, didn’t bother since never worked as it should have
  3. Looks like he is using Mobilinc Portal to control ECHO (just like me) the option you suggest should be only available to ISY Portal integration
  4. Are the echo in between the main router and an access point? I solved my "echo is unable to connect to the Internet" and the blue circle loop you are describing by creating a guest network with Lan access on both my EA6900 with merlin and my access point extender with dd wrt, same settings, and also put the dots in static ip with Google dns. Also enable the roaming assistant (which basically drops the client at certain power level to allow to connect to the adjacent access point. If this makes sense for you, please try it. Echo response time improved too after this. Hope this helps Sent from my iPad using Tapatalk
  5. pinuz replied to paulbates's topic in Amazon Echo
    Definitely something I will test Sent from my iPad using Tapatalk
  6. My experience with mobilinc is completely different, it's either things in my hands work better or I am lucky device after device. Few times I asked for support I got an almost instant reply via email. I am on mobilinc service and I am evaluating if udi portal is better or not. I don't really use the connect from my IOS devices since I find dyndns faster than mobilinc connect so I may save money with UDI Portal if functionality is similar Sent from my iPad using Tapatalk
  7. I don't have a demo video to show but with Simple Control and ISY I believe the level of customization you can reach is superior. Like changing channels vol up down. We aren't using any remote anymore to open TV's in the house after we integrated alexa. Sent from my iPad using Tapatalk
  8. +1 I have been a beta for long time and I will be probably part of the next too which should introduce Alexa supoort Sent from my iPad using Tapatalk
