rahnee
  1. Updated and now I cannot get to my Polyglot. Polisy. Rebooted multiple times, no resolved. Browser says "cannot connect to server". Update: @Michel Kohanim was able to resolve the issue.
  2. Upgraded from 5.6.0, no issues. Like the reboot notice!
  3. Per ticket with @Chris Jahn, This is fixed in the next build. Unfortunately the build is being held up a bit for unrelated reasons, but hopefully it will be out soon. I believe this was in reference to 5.5.5 that was released yesterday and updated this afternoon. Bug Fixes Associations and Scenes Links (Fixes issues with scenes and many status reports from devices) Some Binary Sensors not reporting status Green icons indicating pending writes to the device Node address conflicts for Alarm / Alarm Sensor / Binary Sensor ZEN34 / ZEN17 / ZEN16 / ZSE42 supported Central Scene Controller nodes missing in some cases Insteon/X10: Not decoding X10 responses correctly
  4. Zwave X-Ray (right click on node Zwave, Zwave X-Ray)
  5. Are your locks setup S2 or S0?
  6. No I did not as when trying to include the locks, it only allowed S2
  7. @Geddy Done. Thought I'd start with the forums as someone may have had insight/solutions etc.
  8. @Michel Kohanim - is this a known issue and/or expected?
  9. Migrated from 994i to Polisy and zwave/zmatter dongle. Since I only have 2 locks (Schlage BE469 and 2 repeaters (Aeotec extender 7), I decided I would exclude all zwave and reset dongle. Once that was completed I added all devices back, repeaters and then locks. Used the QR codes to add everything with S2 security. Everything works fine, I can control via AC, programs etc. The issue is that the locks no longer provide STATUS updates (locked or unlocked) when they are used (aka code on door lock). Status updates work if controlled in the AC. In the 994i w/500 series controller everything worked as expected with status updates. If I query, I get the update, if I don't query the lock will show locked even though I unlocked it manually. I did factory reset on of the locks to rule that out. Any/all insight is appreciated
  10. @oberkc I got it figured out...PEBCAK. I had the wrong PIN. Not that I have everything setup properly, I excluded, reset and re-added everything. I can control the devices from AC without issue. What I a NOT getting is status updates from the locks. aka locked/unlocked. Previously on the ISY 994i with zwave 500 board I got status updates quickly and reliably. Do you get updates automatically?
  11. Update 1: Used the wrong PIN on the lock (had them backwards). Used the correct Pin and they added as expected. Just migrated from 994i to Polisy. Had the zwave 500 board in the 994i but for whatever reason the zwave didn't come over. Figured I would simply reset the zwave dongle, new zwave/zmatter from UDI. Excluded all devices and started clean. Adding the BE469, it connects immediately, identifies then as S2 and I add it. Device is "interviewed" and then only 1 node is created vs the 4-6 that I was expecting. It identifies it as ZY <number> Entry Control. that is the only node. I've tried on another lock, same result. An I doing something wrong? Baffled.
  12. Ditto. Had to touch a light switch....not something I am used to doing. Http 500 on portal login.
  13. yes, the SSL Cert expired this morning. Tickets have been submitted.
  14. @Michel Kohanim The SSL certificate for My.isy.io expired this morning @ 8AM EST. They need to update the cert.
  15. Fantastic...thank you as always. I am back online!
