pjjameso
  1. pjjameso replied to Techman's topic in eisy
    Tried all suggestions, here is a screenshot from eisy.local.
  2. pjjameso replied to Techman's topic in eisy
    Thanks, upon further inspection pg3x is showing iox as 6.0 vs 6.05
  3. pjjameso replied to Techman's topic in eisy
    So it seems everything went okay except PG3 still say 6.0. Have rebooted, closed the browser and relaunched using eisy.local. Still same result. Thoughts?
  4. Thanks Bob, Just returned from my overseas trip will make the updates to the configuration
  5. Bob, As expected the join command is not working... On another note, I missed something as each time I restart the sonos plugin if finds all the speakers. Was there something I needed to add to stop the auto discovery? Im heading out of town for a couple of weeks so wont be able to reply to you after tonight. Appreciate the effort, I will ping you when I return if you are still interested in pursuing a solution
  6. You are AMAZING Bob! Thank you for the effort. Will test ASAP...
  7. Bob, is there a way to place an option box in polyglot to not create specific nodes? Thinking I would just delete all the nodes except for the two I want have joined. I have manually deleted them but as you noted they keep reappearing.
  8. Thank you Bob for your thoughtful response. Fully appreciate how difficult it would be to update code without a device to test. Im thinking the easiest way to progress, if you are willing, is to modify the ST-Sonos plug-in as it has all the features of the Sonos plug-in but with the join command included. The issue with ST-Sonos is that the numeration of the individual Sonos units keeps changing. So when I create a program and the if statement is executed the then statement may join with another Sonos unit vs the one originally saved in the program. I have even tried to delete all the sonos units except for the two I want to join based upon the program but all the units keep reappearing. Buttkicker - [ID 0032][Parent 0001][Not Enabled] If 'Emporia / Bmt UPS' Killowatts >= 0.4000 kW Then Set 'ST-Sonos / Buttkicker' Join Basement Else - No Actions - (To add one, press 'Action') Let me know if you want to step back from this request or take a look and see if its a quick fix or much more involved.
  9. The issue I had was that the mute and volume commands would no longer work using the Harmony skill. Tried all sort of workarounds including buying the sofabaton x2. Everything back to normal now since I reverted to the old alexa.... go figure
  10. @bpaauwe @bpwwer Bob, Would you be willing/able to add a join function to the Sonos Polyglot plug in? I realize you forked this over from the ST-Sonos plugin which incorporated the join function. Issue with the ST version as you recall was that the way the individual units were queried messed up the order and as such units would join other units randomly. Happy to pay for your time on this request Thanks in advance
  11. Wow, I have had nothing but issues after getting automatically signed up for alexa+. Actually bought a Sofabaton X2 thinking that the Harmony Elite was the issue with the new Alexa+. Was ready to post a new help request when i saw above that you could uninstall alexa+, did so and now everything is working correctly again. Thank you to the forum!
  12. From Grok it appears the appletv is very aggressive with cec. Just received the blocker and it works perfectly. Now I have consistent automation using the harmony elite remote.
  13. Genius! Thanks so much just ordered a blocker. Will revert if it solves the issue.
  14. Already off in appletv, lg overrides and turns on and off. Truly a pita…
  15. You can but the LG turns it back on. Seems to be a known issue if you use eArc.
