Everything posted by dpark
"Irrigation Requirement" - When does this calculated?
Thanks IndyMike. There are other factors might have caused this, such as weather temperature check since I'm using the Irrigation Module V2. I'm going to move the temperature logic(I don't think I need this) and see what happens. I'll update this post if it happens again. Thanks again.
Hi, I upgraded the latest version recently and I have irrigation runs at 5am when the requirement is > 0.3, this morning the value is 0.38 but the irrigation didn't started at 5am. Normally the value gets calculated at midnight. I was wondering if the latest version calculates the value in different time than the previous one. Thank you.
"Irrigation - Cycle Complete" is preventing sending email?
Thanks IndyMike. I added "Wait 10 seconds" prior cycle complete and it works. Thanks again.
Hi, I'm having a strange issue here. I'm using Irrigation Program V2 and I'm not receiving the 'finished' email. I've tried several scenarios and it seems it's only working when i take out "Irrigation - Cycle Complete" task from the program. I do see the program last run which it sends email from the summary page but I do not get email. Very strange... Thank you.
Weatherbug High Temperature Incorrect?
Understood. Thank you. -Xathros I don't want to create a new post so I'm bumping this. Is the forecast still in the work? I would like to have this feature added as well. Thanks!
3-Way Switching and Grouping
Yes, that is what I did. Thank you!
Hi, I finally set up 3-way switching and I grouped them as per instruction, and it works only on local. If I turn it on or off from ISY, the other switch doesn't respond. I just bought this 3 months ago and everything is new to me, I spent all day to figure it out the 3-way switching. Thanks!
[PROGRAMMING] Always On From - To
I'm doing this for my porch lights so this will work! Thanks!
Yes, that is basically what I did but I would also like to turn the light off automatically after 8:00pm. If I add Else statement there to turn the light off, it just loops - on and off when I hit off switch. So I created another program for "off hours" and added Then to turn it off. I was hoping to do this in one program. Thanks!
Hi, I am trying to program so that the light is always ON From - To time. So if someones turns off, it would turn back ON automatically. I was able to accomplish this with two programs but is it possible to do this in one program? Thanks!
