cwitter
  1. @Michel Kohanim, I can appreciate that it's difficult. Is it on the roadmap to do? Or should we just plan to do it manually? Just want to make plans. Thanks, Craig
  2. I'll include the download link at the bottom of this email, but understand that there are 2 parts to understand about this here before you update. 1. V1.33 or under cannot be updated to V1.37, doing so will break its calibration and cause inaccurate data. 2. If firmware V1.34 or above, then it can be updated to V1.37 You can download the OTA update software here for V1.37 US Frequency: https://we.tl/t-wYkdK3zNgW Make sure of this before you continue with updating. The HEM Gen5 will need to be unpaired first from your ISY, then utilize the Z-Wave USB Adapter through the OTA update software to pair the HEM Gen5 and update it. But definitely make sure to check the firmware version, the values are in HEX so you should see one of these 3 values in the version report: 01 21 = V1.33 01 22 = V1.34 01 23 = V1.35
  3. I had to buy their dongle and their support provided the firmware and update tool. You have to verify the version of the firmware that you have, before you can upgrade. Their support said One thing to make sure of, a windows PC will be needed to utilize our firmware update software, alternatively using Z-WaveJS may be a possibility. I'm not sure how to check with the ISY994i, but before we continue forward, to check the firmware version of your HEM Gen5, you can follow these steps: Requirements: Z-Wave USB Adapter Windows PC You can find the download of Zensys Tool here: https://assistance.domadoo.com/article/zensys-tool-2555.html Connect Controller to Zensys Tool 1) Open up Zensys Tool (make sure that no other software is connected to your controller [ie. Z-Stick, SmartStick+, UZB1]) 2) Your controller should automatically detect your controller after it opens, if it does not continue through the rest of the steps 3) Click on Categories 4) On the drop down menu, click on "Settings" 5) Select your Z-Wave USB Controller to connect to, then click OK. Finding Firmware version of a Z-Wave Device 1) Highlight the device that you want to check the firmware of 2) Click on the Node Information Icon 3) If it is a battery device, you will now need to wake it up to finish the command, then Zensys Tool will scan the device information and update it. 4) Now click on "Command Class" tab 5) Select: Command Classes: COMMAND_CLASS_VERSION_V1 Command Name: VERSION_GET 6) Then click on Send 7) If you are trying to get the information of a battery device, make sure to wake it up now A packet log will show up now, you can ignore most of the information, the only 4 digits you are look at are on the right side In this case, of the image above, the firmware version is V1.08 or V1.8 If your not sure, just send me a screenshot of the Version Report which should help me understand what firmware version your HEM Gen5 is running. Very likely it is running firmware V1.35
  4. Works perfect! Thanks so much!
  5. In case anyone else runs into this.. I had to get a firmware update from Aeotec. The device shipped with version 1.35, and need 1.37. After that, everything worked prefectly. Thanks, Craig
  6. @bmercier Here's the output. I also attached it as a pdf if that's easier. Device example is zw060_1. Thanks in advance, Craig https___192.168.2.253_rest_zwave_node_0_def_get_full=true.pdf
  7. This XML file does not appear to have any style information associated with it. The document tree is shown below. <nodeDefs> <!-- Z-Wave ZW018_1 'ZW 018 On-Off Power Switch' --> <nodedef id="UZW0024" nls="121"> <sts> <!-- cc=0x25.03 SWITCH_BINARY grp=2 ch=0 --> <st id="ST" editor="ZW_OFF_ON_UNKNOWN"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <cmd id="HAIL"/> <!-- cc=0x25 SWITCH_BINARY grp=2 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <!-- cc=0x27 SWITCH_ALL grp=2 ch=0 --> <cmd id="ALLON"/> <cmd id="ALLOFF"/> <cmd id="DON"> <p id="" editor="ZW_0_100_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="QUERY"/> <cmd id="SETTIME"/> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl> <link linkdef="BSW"/> </ctl> <rsp> <link linkdef="ASSOC"/> <link linkdef="BSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW018_119 'ZW 018 Multilevel Switch' --> <nodedef id="UZW0038" nls="119"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=0 ch=0 --> <st id="ST" editor="_51_0_R_0_100"/> </sts> <cmds> <sends> <!-- cc=0x26 SWITCH_MULTILEVEL grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> <cmd id="FDUP"/> <cmd id="FDDOWN"/> <cmd id="FDSTOP"/> </sends> <accepts> <!-- cc=0x26 SWITCH_MULTILEVEL grp=0 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW039_1 'Living Room Floor Lamp' --> <nodedef id="UZW0039" nls="134"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=1 ch=0 --> <st id="ST" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <cmd id="HAIL"/> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> <cmd id="FDUP"/> <cmd id="FDDOWN"/> <cmd id="FDSTOP"/> </sends> <accepts> <!-- cc=0x27 SWITCH_ALL grp=1 ch=0 --> <cmd id="ALLON"/> <cmd id="ALLOFF"/> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl> <link linkdef="ASSOC"/> </ctl> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW018_186 'ZW 018 Color Switch' --> <nodedef id="UZW0043" nls="186"> <sts> <!-- cc=0x33.04 SWITCH_COLOR grp=0 ch=0 --> <st id="GV0" editor="_107_0_R_0_255"/> <!-- cc=0x33.04 SWITCH_COLOR grp=0 ch=0 --> <st id="GV2" editor="_107_0_R_0_255"/> <!-- cc=0x33.04 SWITCH_COLOR grp=0 ch=0 --> <st id="GV3" editor="_107_0_R_0_255"/> <!-- cc=0x33.04 SWITCH_COLOR grp=0 ch=0 --> <st id="GV4" editor="_107_0_R_0_255"/> <!-- cc=0x33.04 SWITCH_COLOR grp=0 ch=0 --> <st id="GV5" editor="_107_0_R_0_255"/> </sts> <cmds> <sends/> <accepts> <cmd id="DON"> <p id="GV0" editor="_107_0_R_0_255" optional="T"/> <p id="GV5" editor="_107_0_R_0_255" optional="T"/> <p id="GV10" editor="_107_0_R_0_255" optional="T"/> <p id="GV12" editor="_107_0_R_0_255" optional="T"/> <p id="GV13" editor="_107_0_R_0_255" optional="T"/> <p id="GV14" editor="_107_0_R_0_255" optional="T"/> </cmd> <cmd id="FDUP"> <p id="ID" editor="_25_0_S_7421_N_IX_CCI"/> <p id="STARTLEVEL" editor="_107_0_R_0_255" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="ID" editor="_25_0_S_7421_N_IX_CCI"/> <p id="STARTLEVEL" editor="_107_0_R_0_255" optional="T"/> </cmd> <cmd id="FDSTOP"> <p id="ID" editor="_25_0_S_7421_N_IX_CCI"/> </cmd> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW018_143 'Washing Machine' --> <nodedef id="UZW004D" nls="143"> <sts> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="CC" editor="_1_3"/> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="ST" editor="_73_3"/> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="CV" editor="_72_3"/> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="PF" editor="_53_7"/> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="TPW" editor="_33_3"/> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="PULSCNT" editor="_55_3"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x32 METER grp=0 ch=0 --> <cmd id="RESET"/> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW095_1 'Energy Monitor' --> <nodedef id="UZW0060" nls="143"> <sts> <!-- cc=0x32.02 METER grp=1 ch=0 --> <st id="CC" editor="_1_3"/> <!-- cc=0x32.02 METER grp=1 ch=0 --> <st id="ST" editor="_73_3"/> <!-- cc=0x32.02 METER grp=1 ch=0 --> <st id="CV" editor="_72_3"/> <!-- cc=0x32.02 METER grp=1 ch=0 --> <st id="TPW" editor="_33_3"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x32 METER grp=1 ch=0 --> <cmd id="RESET"/> <cmd id="QUERY"/> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW050_143 'ZW 050 Energy Meter' --> <nodedef id="UZW0061" nls="143"> <sts> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="ST" editor="_73_3"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="S0"/> <link linkdef="S0_BASIC"/> <link linkdef="MC_S0"/> <link linkdef="MC_S0_BASIC"/> <link linkdef="S0_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW072_1 'ZW 072 Notify Sensor' --> <nodedef id="UZW006B" nls="185"> <sts> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> <!-- cc=0x84 WAKE_UP grp=1 ch=0 --> <cmd id="WAKEOPTS"> <p id="INTERVAL" editor="ZW_WAKE_INTERVAL"/> </cmd> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW023_1 'Master Bedroom - Left Lamp' --> <nodedef id="UZW0078" nls="134"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=1 ch=0 --> <st id="ST" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <cmd id="HAIL"/> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> <cmd id="FDUP"/> <cmd id="FDDOWN"/> <cmd id="FDSTOP"/> </sends> <accepts> <!-- cc=0x27 SWITCH_ALL grp=1 ch=0 --> <cmd id="ALLON"/> <cmd id="ALLOFF"/> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl> <link linkdef="ASSOC"/> </ctl> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW065_1 'Dining Room - Middle Shade' --> <nodedef id="UZW007D" nls="107"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=1 ch=0 --> <st id="ST" editor="_51_0_R_0_100"/> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> <cmd id="FDUP"/> <cmd id="FDDOWN"/> <cmd id="FDSTOP"/> </sends> <accepts> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FADE"> <p id="DIR" editor="ZW_MLS_DIR"/> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> <p id="DIR2" editor="ZW_MLS_DIR" optional="T"/> <p id="STEP2" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl> <link linkdef="MLSW"/> </ctl> <rsp> <link linkdef="ASSOC"/> <link linkdef="MLSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_MLSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW077_1 'Dining Room - Left Shade' --> <nodedef id="UZW007E" nls="107"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=0 ch=0 --> <st id="ST" editor="_51_0_R_0_101_N_IX_DIM_REP"/> <!-- cc=0x80.03 BATTERY grp=0 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x26 SWITCH_MULTILEVEL grp=0 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FADE"> <p id="DIR" editor="ZW_MLS_DIR"/> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> <p id="DIR2" editor="ZW_MLS_DIR" optional="T"/> <p id="STEP2" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="MLSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_MLSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW060_1 'Family Room Shade' --> <nodedef id="UZW007F" nls="107"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=1 ch=0 --> <st id="ST" editor="_51_0_R_0_100"/> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> <cmd id="FDUP"/> <cmd id="FDDOWN"/> <cmd id="FDSTOP"/> </sends> <accepts> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FADE"> <p id="DIR" editor="ZW_MLS_DIR"/> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> <p id="DIR2" editor="ZW_MLS_DIR" optional="T"/> <p id="STEP2" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="MLSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_MLSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW078_1 'Front Entry Light' --> <nodedef id="UZW008B" nls="121"> <sts> <!-- cc=0x25.03 SWITCH_BINARY grp=1 ch=0 --> <st id="ST" editor="ZW_OFF_ON_UNKNOWN"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <cmd id="HAIL"/> <!-- cc=0x25 SWITCH_BINARY grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <!-- cc=0x27 SWITCH_ALL grp=1 ch=0 --> <cmd id="ALLON"/> <cmd id="ALLOFF"/> <cmd id="DON"> <p id="" editor="ZW_0_100_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="QUERY"/> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="BSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="MC_BSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW024_1 'Garage Door Opener' --> <nodedef id="UZW008D" nls="184"> <sts> <!-- cc=0x66.03 BARRIER_OPERATOR grp=0 ch=0 --> <st id="ST" editor="_97_0_R_0_104"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x66 BARRIER_OPERATOR grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW061_1 'ZW 061 Remote Control' --> <nodedef id="UZW0092" nls="126"> <sts> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> <!-- cc=0x84 WAKE_UP grp=1 ch=0 --> <cmd id="WAKEOPTS"> <p id="INTERVAL" editor="ZW_WAKE_INTERVAL"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW072_155 'Office Motion Sensor' --> <nodedef id="UZW009D" nls="155"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ST" editor="ZW_OFF_0_ON_100"/> </sts> <cmds> <sends> <!-- cc=0x30 SENSOR_BINARY grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts/> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW094_1 'Entry Way Siren' --> <nodedef id="UZW00A2" nls="137"> <sts> <!-- cc=0x25.03 SWITCH_BINARY grp=0 ch=0 --> <st id="ST" editor="ZW_OFF_ON_UNKNOWN"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <cmd id="HAIL"/> <!-- cc=0x25 SWITCH_BINARY grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="DON"> <p id="" editor="ZW_0_100_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="QUERY"/> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="SCENE_S0_R_CFG"/> <link linkdef="SCENE_MC_S0_R_CFG"/> <link linkdef="S0"/> <link linkdef="S0_BSW"/> <link linkdef="MC_S0"/> <link linkdef="MC_S0_BSW"/> <link linkdef="S0_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW072_308 'ZW 072 Home Security Alarm 1' --> <nodedef id="UZW00B3" nls="308"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ALARM" editor="_25_0_S_0100_N_IXA_HS"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW069_1 'ZW 069 Unavailable' --> <nodedef id="UZW00B9" nls="0"> <sts> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW072_118 'ZW 072 Multilevel Sensor 1' --> <nodedef id="UZW00BC" nls="118"> <sts> <!-- cc=0x31.05 SENSOR_MULTILEVEL grp=1 ch=0 --> <st id="CLITEMP" editor="_17_1"/> <!-- cc=0x31.05 SENSOR_MULTILEVEL grp=1 ch=0 --> <st id="LUMIN" editor="_36_0"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW050_1 'Front Door Lock' --> <nodedef id="UZW00BD" nls="111"> <sts> <!-- cc=0x62.03 DOOR_LOCK grp=1 ch=0 --> <st id="ST" editor="ZW_LOCK_STS_2"/> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="USRNUM" editor="_70_0_R_0_30"/> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <cmd id="ALARM"> <p id="" editor="_15_0_S_D80445E"/> </cmd> </sends> <accepts> <!-- cc=0x62 DOOR_LOCK grp=1 ch=0 --> <cmd id="LOCK"/> <cmd id="UNLOCK"> <p id="" editor="ZW_UNLOCK_NT" optional="T"/> </cmd> <cmd id="QUERY"/> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="S0"/> <link linkdef="S0_BASIC"/> <link linkdef="MC_S0"/> <link linkdef="MC_S0_BASIC"/> <link linkdef="S0_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW061_201N001 'ZW 061 Scene Button 1' --> <nodedef id="UZW00BF" nls="201"> <sts/> <cmds> <sends> <!-- cc=0x5B CENTRAL_SCENE grp=1 ch=0 --> <cmd id="DON"/> <cmd id="FDSTOP"/> <cmd id="FDUP"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW019_1 'Ally's Sound Machine' --> <nodedef id="UZW00C0" nls="122"> <sts> <!-- cc=0x25.03 SWITCH_BINARY grp=1 ch=0 --> <st id="ST" editor="ZW_OFF_ON_UNKNOWN"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <cmd id="HAIL"/> <!-- cc=0x25 SWITCH_BINARY grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <!-- cc=0x27 SWITCH_ALL grp=1 ch=0 --> <cmd id="ALLON"/> <cmd id="ALLOFF"/> <cmd id="DON"> <p id="" editor="ZW_0_100_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl> <link linkdef="BSW"/> </ctl> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC"/> <link linkdef="BSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW044_1 'Garage Door Lock' --> <nodedef id="UZW00CC" nls="111"> <sts> <!-- cc=0x62.03 DOOR_LOCK grp=1 ch=0 --> <st id="ST" editor="ZW_LOCK_STS_2"/> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="USRNUM" editor="_70_0_R_0_30"/> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <cmd id="ALARM"> <p id="" editor="_15_0_S_D80445E"/> </cmd> </sends> <accepts> <!-- cc=0x62 DOOR_LOCK grp=1 ch=0 --> <cmd id="LOCK"/> <cmd id="UNLOCK"> <p id="" editor="ZW_UNLOCK_NT" optional="T"/> </cmd> <cmd id="QUERY"/> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="S0"/> <link linkdef="S0_BASIC"/> <link linkdef="MC_S0"/> <link linkdef="MC_S0_BASIC"/> <link linkdef="S0_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW030_1 'Pantry - Light' --> <nodedef id="UZW00CD" nls="121"> <sts> <!-- cc=0x25.03 SWITCH_BINARY grp=1 ch=0 --> <st id="ST" editor="ZW_OFF_ON_UNKNOWN"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <cmd id="HAIL"/> <!-- cc=0x25 SWITCH_BINARY grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <!-- cc=0x27 SWITCH_ALL grp=1 ch=0 --> <cmd id="ALLON"/> <cmd id="ALLOFF"/> <cmd id="DON"> <p id="" editor="ZW_0_100_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="QUERY"/> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl> <link linkdef="BSW"/> </ctl> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="BSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="MC_BSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW061_201N002 'ZW 061 Scene Button 2' --> <nodedef id="UZW00CF" nls="201"> <sts/> <cmds> <sends> <!-- cc=0x5B CENTRAL_SCENE grp=2 ch=0 --> <cmd id="DON"/> <cmd id="FDSTOP"/> <cmd id="FDUP"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW082_1 'Blake's Left Shade' --> <nodedef id="UZW00D1" nls="107"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=1 ch=0 --> <st id="ST" editor="_51_0_R_0_101_N_IX_DIM_REP"/> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FADE"> <p id="DIR" editor="ZW_MLS_DIR"/> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> <p id="DIR2" editor="ZW_MLS_DIR" optional="T"/> <p id="STEP2" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="MLSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="MC_MLSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW062_1 'Master Bedroom - Repeater' --> <nodedef id="UZW00D3" nls="129"> <sts> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW024_306 'ZW 024 Access Control Alarm' --> <nodedef id="UZW00D9" nls="306"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=0 ch=0 --> <st id="USRNUM" editor="_70_0_R_0_50"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl> <link linkdef="S0"/> </ctl> <rsp/> </links> </nodedef> <!-- Z-Wave ZW062_119 'ZW 062 Multilevel Switch' --> <nodedef id="UZW00DA" nls="119"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=0 ch=0 --> <st id="ST" editor="_51_0_R_0_100"/> </sts> <cmds> <sends> <!-- cc=0x26 SWITCH_MULTILEVEL grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> <cmd id="FDUP"/> <cmd id="FDDOWN"/> <cmd id="FDSTOP"/> </sends> <accepts> <!-- cc=0x26 SWITCH_MULTILEVEL grp=0 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="S0_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW062_186 'ZW 062 Color Switch' --> <nodedef id="UZW00DB" nls="186"> <sts> <!-- cc=0x33.04 SWITCH_COLOR grp=0 ch=0 --> <st id="GV2" editor="_107_0_R_0_255"/> <!-- cc=0x33.04 SWITCH_COLOR grp=0 ch=0 --> <st id="GV3" editor="_107_0_R_0_255"/> <!-- cc=0x33.04 SWITCH_COLOR grp=0 ch=0 --> <st id="GV4" editor="_107_0_R_0_255"/> </sts> <cmds> <sends/> <accepts> <cmd id="DON"> <p id="GV2" editor="_107_0_R_0_255" optional="T"/> <p id="GV3" editor="_107_0_R_0_255" optional="T"/> <p id="GV4" editor="_107_0_R_0_255" optional="T"/> </cmd> <cmd id="FDUP"> <p id="ID" editor="_25_0_S_001C_N_IX_CCI"/> <p id="STARTLEVEL" editor="_107_0_R_0_255" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="ID" editor="_25_0_S_001C_N_IX_CCI"/> <p id="STARTLEVEL" editor="_107_0_R_0_255" optional="T"/> </cmd> <cmd id="FDSTOP"> <p id="ID" editor="_25_0_S_001C_N_IX_CCI"/> </cmd> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW063_1 'ZW 063 Remote Control' --> <nodedef id="UZW00DC" nls="126"> <sts> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> <!-- cc=0x84 WAKE_UP grp=1 ch=0 --> <cmd id="WAKEOPTS"> <p id="INTERVAL" editor="ZW_WAKE_INTERVAL"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW063_201N001 'ZW 063 Scene Button 1' --> <nodedef id="UZW00DF" nls="201"> <sts/> <cmds> <sends> <!-- cc=0x5B CENTRAL_SCENE grp=1 ch=0 --> <cmd id="DON"/> <cmd id="FDSTOP"/> <cmd id="FDUP"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW063_201N002 'ZW 063 Scene Button 2' --> <nodedef id="UZW00E0" nls="201"> <sts/> <cmds> <sends> <!-- cc=0x5B CENTRAL_SCENE grp=2 ch=0 --> <cmd id="DON"/> <cmd id="FDSTOP"/> <cmd id="FDUP"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl> <link linkdef="MLSW"/> </ctl> <rsp/> </links> </nodedef> <!-- Z-Wave ZW063_119 'Family Room Shade Remote' --> <nodedef id="UZW00E1" nls="119"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=2 ch=0 --> <st id="ST" editor="_51_0_R_0_100"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW064_1 'Master Bedroom Shade' --> <nodedef id="UZW00E2" nls="107"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=1 ch=0 --> <st id="ST" editor="_51_0_R_0_100"/> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> <cmd id="FDUP"/> <cmd id="FDDOWN"/> <cmd id="FDSTOP"/> </sends> <accepts> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FADE"> <p id="DIR" editor="ZW_MLS_DIR"/> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> <p id="DIR2" editor="ZW_MLS_DIR" optional="T"/> <p id="STEP2" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="MLSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_MLSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW066_1 'Dining Room Zwave Repeater' --> <nodedef id="UZW00E3" nls="129"> <sts> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW068_1 'ZW 068 Remote Control' --> <nodedef id="UZW00E4" nls="126"> <sts> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> <!-- cc=0x84 WAKE_UP grp=1 ch=0 --> <cmd id="WAKEOPTS"> <p id="INTERVAL" editor="ZW_WAKE_INTERVAL"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW068_201N001 'ZW 068 Scene Button 1' --> <nodedef id="UZW00E5" nls="201"> <sts/> <cmds> <sends> <!-- cc=0x5B CENTRAL_SCENE grp=1 ch=0 --> <cmd id="DON"/> <cmd id="FDSTOP"/> <cmd id="FDUP"/> <cmd id="DFON"/> <cmd id="DON3"/> <cmd id="DON4"/> <cmd id="DON5"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW068_201N002 'ZW 068 Scene Button 2' --> <nodedef id="UZW00E6" nls="201"> <sts/> <cmds> <sends> <!-- cc=0x5B CENTRAL_SCENE grp=2 ch=0 --> <cmd id="DON"/> <cmd id="FDSTOP"/> <cmd id="FDUP"/> <cmd id="DFON"/> <cmd id="DON3"/> <cmd id="DON4"/> <cmd id="DON5"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl> <link linkdef="MLSW"/> </ctl> <rsp/> </links> </nodedef> <!-- Z-Wave ZW068_119 'ZW 068 Shades' --> <nodedef id="UZW00E7" nls="119"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=2 ch=0 --> <st id="ST" editor="_51_0_R_0_100"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW079_1 'Backyard Lights' --> <nodedef id="UZW00ED" nls="121"> <sts> <!-- cc=0x25.03 SWITCH_BINARY grp=1 ch=0 --> <st id="ST" editor="ZW_OFF_ON_UNKNOWN"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <!-- cc=0x25 SWITCH_BINARY grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="DON"> <p id="" editor="ZW_0_100_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="QUERY"/> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="BSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="MC_BSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW079_251 'ZW 079 Basic Control 2' --> <nodedef id="UZW00F1" nls="251"> <sts> <!-- cc=0x20.03 BASIC grp=2 ch=0 --> <st id="ST" editor="_56_0_R_0_255"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl> <link linkdef="MC_BASIC"/> </ctl> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW024_172 'ZW 024 Intrusion Alarm' --> <nodedef id="UZW010B" nls="172"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=0 ch=0 --> <st id="ST" editor="ZW_OFF_0_ON_100"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts/> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW024_157 'ZW 024 Tamper Alarm' --> <nodedef id="UZW010C" nls="157"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=0 ch=0 --> <st id="ST" editor="ZW_OFF_0_ON_100"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts/> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW024_173 'ZW 024 Tamper Code Alarm' --> <nodedef id="UZW010D" nls="173"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=0 ch=0 --> <st id="ST" editor="ZW_OFF_0_ON_100"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts/> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW024_153 'ZW 024 Glass Break Alarm' --> <nodedef id="UZW010E" nls="153"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=0 ch=0 --> <st id="ST" editor="ZW_OFF_0_ON_100"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts/> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW024_155 'ZW 024 Motion Sensor' --> <nodedef id="UZW010F" nls="155"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=0 ch=0 --> <st id="ST" editor="ZW_OFF_0_ON_100"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts/> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW026_1 'Blake's - Sound Machine' --> <nodedef id="UZW0110" nls="122"> <sts> <!-- cc=0x25.03 SWITCH_BINARY grp=0 ch=0 --> <st id="ST" editor="ZW_OFF_ON_UNKNOWN"/> <!-- cc=0x80.03 BATTERY grp=0 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <!-- cc=0x25 SWITCH_BINARY grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <!-- cc=0x27 SWITCH_ALL grp=0 ch=0 --> <cmd id="ALLON"/> <cmd id="ALLOFF"/> <cmd id="DON"> <p id="" editor="ZW_0_100_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC"/> <link linkdef="BSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW018_145 'ZW 018 Water Meter' --> <nodedef id="UZW0120" nls="145"> <sts> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="WVOL" editor="_69_3"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x32 METER grp=0 ch=0 --> <cmd id="RESET"/> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW045_1 'Family Room Plug' --> <nodedef id="UZW0122" nls="121"> <sts> <!-- cc=0x25.03 SWITCH_BINARY grp=2 ch=0 --> <st id="ST" editor="ZW_OFF_ON_UNKNOWN"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <cmd id="HAIL"/> <!-- cc=0x25 SWITCH_BINARY grp=2 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <!-- cc=0x27 SWITCH_ALL grp=2 ch=0 --> <cmd id="ALLON"/> <cmd id="ALLOFF"/> <cmd id="DON"> <p id="" editor="ZW_0_100_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="QUERY"/> <cmd id="SETTIME"/> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl> <link linkdef="BSW"/> </ctl> <rsp> <link linkdef="ASSOC"/> <link linkdef="BSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW026_143 'ZW 026 Energy Meter' --> <nodedef id="UZW012A" nls="143"> <sts> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="ST" editor="_73_3"/> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="PULSCNT" editor="_55_3"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW072_194 'ZW 072 Basic' --> <nodedef id="UZW0132" nls="194"> <sts/> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl> <link linkdef="MC_S0_BASIC"/> </ctl> <rsp/> </links> </nodedef> <!-- Z-Wave ZW019_143 'ZW 019 Energy Meter' --> <nodedef id="UZW0134" nls="143"> <sts> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="ST" editor="_73_3"/> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="CV" editor="_72_3"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW093_1 'Utility Room Siren' --> <nodedef id="UZW0135" nls="137"> <sts> <!-- cc=0x25.03 SWITCH_BINARY grp=0 ch=0 --> <st id="ST" editor="ZW_OFF_ON_UNKNOWN"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <cmd id="HAIL"/> <!-- cc=0x25 SWITCH_BINARY grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="DON"> <p id="" editor="ZW_0_100_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="QUERY"/> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="SCENE_S0_R_CFG"/> <link linkdef="SCENE_MC_S0_R_CFG"/> <link linkdef="S0"/> <link linkdef="S0_BASIC"/> <link linkdef="S0_BSW"/> <link linkdef="MC_S0"/> <link linkdef="MC_S0_BASIC"/> <link linkdef="MC_S0_BSW"/> <link linkdef="S0_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW049_1 'Storage - Light' --> <nodedef id="UZW0148" nls="121"> <sts> <!-- cc=0x25.03 SWITCH_BINARY grp=1 ch=0 --> <st id="ST" editor="ZW_OFF_ON_UNKNOWN"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <cmd id="HAIL"/> <!-- cc=0x25 SWITCH_BINARY grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <!-- cc=0x27 SWITCH_ALL grp=1 ch=0 --> <cmd id="ALLON"/> <cmd id="ALLOFF"/> <cmd id="DON"> <p id="" editor="ZW_0_100_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="QUERY"/> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl> <link linkdef="BSW"/> </ctl> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="BSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="MC_BSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW045_119 'ZW 045 Multilevel Switch' --> <nodedef id="UZW016B" nls="119"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=0 ch=0 --> <st id="ST" editor="_51_0_R_0_100"/> </sts> <cmds> <sends> <!-- cc=0x26 SWITCH_MULTILEVEL grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> <cmd id="FDUP"/> <cmd id="FDDOWN"/> <cmd id="FDSTOP"/> </sends> <accepts> <!-- cc=0x26 SWITCH_MULTILEVEL grp=0 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW045_186 'ZW 045 Color Switch' --> <nodedef id="UZW016C" nls="186"> <sts> <!-- cc=0x33.04 SWITCH_COLOR grp=0 ch=0 --> <st id="GV2" editor="_107_0_R_0_255"/> <!-- cc=0x33.04 SWITCH_COLOR grp=0 ch=0 --> <st id="GV3" editor="_107_0_R_0_255"/> <!-- cc=0x33.04 SWITCH_COLOR grp=0 ch=0 --> <st id="GV4" editor="_107_0_R_0_255"/> </sts> <cmds> <sends/> <accepts> <cmd id="DON"> <p id="GV2" editor="_107_0_R_0_255" optional="T"/> <p id="GV3" editor="_107_0_R_0_255" optional="T"/> <p id="GV4" editor="_107_0_R_0_255" optional="T"/> </cmd> <cmd id="FDUP"> <p id="ID" editor="_25_0_S_001C_N_IX_CCI"/> <p id="STARTLEVEL" editor="_107_0_R_0_255" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="ID" editor="_25_0_S_001C_N_IX_CCI"/> <p id="STARTLEVEL" editor="_107_0_R_0_255" optional="T"/> </cmd> <cmd id="FDSTOP"> <p id="ID" editor="_25_0_S_001C_N_IX_CCI"/> </cmd> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW045_143 'ZW 045 Energy Meter' --> <nodedef id="UZW016D" nls="143"> <sts> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="CC" editor="_1_3"/> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="ST" editor="_73_3"/> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="CV" editor="_72_3"/> <!-- cc=0x32.02 METER grp=0 ch=0 --> <st id="TPW" editor="_33_3"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x32 METER grp=0 ch=0 --> <cmd id="RESET"/> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW050_306 'ZW 050 Access Control Alarm' --> <nodedef id="UZW0171" nls="306"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ALARM" editor="_25_0_S_50A66_N_IXA_AC"/> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="USRNUM" editor="_70_0_R_0_30"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="S0"/> <link linkdef="S0_BASIC"/> <link linkdef="MC_S0"/> <link linkdef="MC_S0_BASIC"/> <link linkdef="S0_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW044_306 'ZW 044 Access Control Alarm' --> <nodedef id="UZW0172" nls="306"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ALARM" editor="_25_0_S_50A66_N_IXA_AC"/> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="USRNUM" editor="_70_0_R_0_30"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="S0"/> <link linkdef="S0_BASIC"/> <link linkdef="MC_S0"/> <link linkdef="MC_S0_BASIC"/> <link linkdef="S0_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW080_1 'Allison's Left Window Shade' --> <nodedef id="UZW0179" nls="107"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=1 ch=0 --> <st id="ST" editor="_51_0_R_0_101_N_IX_DIM_REP"/> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FADE"> <p id="DIR" editor="ZW_MLS_DIR"/> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> <p id="DIR2" editor="ZW_MLS_DIR" optional="T"/> <p id="STEP2" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="MLSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="MC_MLSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW081_1 'Allison's Right Window Shade' --> <nodedef id="UZW017A" nls="107"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=1 ch=0 --> <st id="ST" editor="_51_0_R_0_101_N_IX_DIM_REP"/> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FADE"> <p id="DIR" editor="ZW_MLS_DIR"/> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> <p id="DIR2" editor="ZW_MLS_DIR" optional="T"/> <p id="STEP2" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="MLSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="MC_MLSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW051_1 'ZW 051 Unavailable' --> <nodedef id="UZW017B" nls="0"> <sts> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW059_1 'ZW 059 Unavailable' --> <nodedef id="UZW017C" nls="0"> <sts> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW083_1 'Blake's Right Shade' --> <nodedef id="UZW017E" nls="107"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=1 ch=0 --> <st id="ST" editor="_51_0_R_0_101_N_IX_DIM_REP"/> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FADE"> <p id="DIR" editor="ZW_MLS_DIR"/> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> <p id="DIR2" editor="ZW_MLS_DIR" optional="T"/> <p id="STEP2" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="MLSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="MC_MLSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW085_1 'ZW 085 Remote Control' --> <nodedef id="UZW017F" nls="126"> <sts> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> <!-- cc=0x84 WAKE_UP grp=1 ch=0 --> <cmd id="WAKEOPTS"> <p id="INTERVAL" editor="ZW_WAKE_INTERVAL"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW085_201N001 'ZW 085 Scene Button 1' --> <nodedef id="UZW0180" nls="201"> <sts/> <cmds> <sends> <!-- cc=0x5B CENTRAL_SCENE grp=1 ch=0 --> <cmd id="DON"/> <cmd id="FDSTOP"/> <cmd id="FDUP"/> <cmd id="DFON"/> <cmd id="DON3"/> <cmd id="DON4"/> <cmd id="DON5"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW085_201N002 'ZW 085 Scene Button 2' --> <nodedef id="UZW0181" nls="201"> <sts/> <cmds> <sends> <!-- cc=0x5B CENTRAL_SCENE grp=2 ch=0 --> <cmd id="DON"/> <cmd id="FDSTOP"/> <cmd id="FDUP"/> <cmd id="DFON"/> <cmd id="DON3"/> <cmd id="DON4"/> <cmd id="DON5"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW085_119 'ZW 085 Multilevel Switch 2' --> <nodedef id="UZW0182" nls="119"> <sts/> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl> <link linkdef="MLSW"/> </ctl> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW095_001_1 'Sump Pump - Parent' --> <nodedef id="UZW0186" nls="0"> <sts> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW095_001_143 'Sump Pump' --> <nodedef id="UZW0187" nls="143"> <sts> <!-- cc=0x32.02 METER grp=0 ch=1 --> <st id="CC" editor="_1_3"/> <!-- cc=0x32.02 METER grp=0 ch=1 --> <st id="ST" editor="_73_3"/> <!-- cc=0x32.02 METER grp=0 ch=1 --> <st id="CV" editor="_72_3"/> <!-- cc=0x32.02 METER grp=0 ch=1 --> <st id="TPW" editor="_33_3"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x32 METER grp=0 ch=1 --> <cmd id="RESET"/> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW088_1 'ZW 088 Notify Sensor' --> <nodedef id="UZW0188" nls="185"> <sts> <!-- cc=0x80.03 BATTERY grp=0 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> <!-- cc=0x84 WAKE_UP grp=0 ch=0 --> <cmd id="WAKEOPTS"> <p id="INTERVAL" editor="ZW_WAKE_INTERVAL"/> </cmd> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW088_251 'ZW 088 Basic Control 2' --> <nodedef id="UZW0189" nls="251"> <sts> <!-- cc=0x20.03 BASIC grp=2 ch=0 --> <st id="ST" editor="_56_0_R_0_255"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl> <link linkdef="BASIC"/> </ctl> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW088_306 'ZW 088 Access Control Alarm' --> <nodedef id="UZW018A" nls="306"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ALARM" editor="_25_0_S_C00000_N_IXA_AC"/> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="USRNUM" editor="_70_0_R_0_50"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW088_184 'Leak Sensor - Sump' --> <nodedef id="UZW018B" nls="184"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ST" editor="_97_0_R_0_104"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW088_308 'ZW 088 Home Security Alarm' --> <nodedef id="UZW018C" nls="308"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ALARM" editor="_25_0_S_0008_N_IXA_HS"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW053_1 'Dining Room - Right Shade' --> <nodedef id="UZW018D" nls="107"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=1 ch=0 --> <st id="ST" editor="_51_0_R_0_100"/> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> <cmd id="FDUP"/> <cmd id="FDDOWN"/> <cmd id="FDSTOP"/> </sends> <accepts> <!-- cc=0x26 SWITCH_MULTILEVEL grp=1 ch=0 --> <cmd id="DON"> <p id="" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="DFON"/> <cmd id="DFOF"/> <cmd id="BRT" native="F"/> <cmd id="DIM" native="F"/> <cmd id="FDUP"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDDOWN"> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FADE"> <p id="DIR" editor="ZW_MLS_DIR"/> <p id="STARTLEVEL" editor="ZW_DIM_PERCENT" optional="T"/> <p id="RR" editor="ZW_RR" optional="T"/> <p id="DIR2" editor="ZW_MLS_DIR" optional="T"/> <p id="STEP2" editor="ZW_RR" optional="T"/> </cmd> <cmd id="FDSTOP"/> <cmd id="QUERY"/> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl> <link linkdef="MLSW"/> </ctl> <rsp> <link linkdef="ASSOC"/> <link linkdef="MLSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_MLSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW088_157 'ZW 088 Tamper Alarm 1' --> <nodedef id="UZW018E" nls="157"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ST" editor="ZW_OFF_0_ON_100"/> </sts> <cmds> <sends> <!-- cc=0x30 SENSOR_BINARY grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts/> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW055_1 'Dining Room 2 - Button Remote' --> <nodedef id="UZW018F" nls="126"> <sts> <!-- cc=0x80.03 BATTERY grp=1 ch=0 --> <st id="BATLVL" editor="_51_0_R_0_100"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> <!-- cc=0x84 WAKE_UP grp=1 ch=0 --> <cmd id="WAKEOPTS"> <p id="INTERVAL" editor="ZW_WAKE_INTERVAL"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW055_201N001 'ZW 055 Scene Button 1' --> <nodedef id="UZW0190" nls="201"> <sts/> <cmds> <sends> <!-- cc=0x5B CENTRAL_SCENE grp=1 ch=0 --> <cmd id="DON"/> <cmd id="FDSTOP"/> <cmd id="FDUP"/> <cmd id="DFON"/> <cmd id="DON3"/> <cmd id="DON4"/> <cmd id="DON5"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW055_201N002 'ZW 055 Scene Button 2' --> <nodedef id="UZW0191" nls="201"> <sts/> <cmds> <sends> <!-- cc=0x5B CENTRAL_SCENE grp=2 ch=0 --> <cmd id="DON"/> <cmd id="FDSTOP"/> <cmd id="FDUP"/> <cmd id="DFON"/> <cmd id="DON3"/> <cmd id="DON4"/> <cmd id="DON5"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl> <link linkdef="MLSW"/> </ctl> <rsp/> </links> </nodedef> <!-- Z-Wave ZW055_119 'ZW 055 Shades' --> <nodedef id="UZW0192" nls="119"> <sts> <!-- cc=0x26.03 SWITCH_MULTILEVEL grp=2 ch=0 --> <st id="ST" editor="_51_0_R_0_100"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW088_181 'ZW 088 Power Alarm 1' --> <nodedef id="UZW0193" nls="181"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ALARM" editor="_93_0_S_0800_N_IXA_PM"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW088_104 'ZW 088 Binary Sensor 1' --> <nodedef id="UZW0194" nls="104"> <sts> <!-- cc=0x30.03 SENSOR_BINARY grp=1 ch=0 --> <st id="ST" editor="ZW_OFF_0_ON_100"/> </sts> <cmds> <sends> <!-- cc=0x30 SENSOR_BINARY grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts/> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW050_308 'ZW 050 Home Security Alarm' --> <nodedef id="UZW0195" nls="308"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ALARM" editor="_25_0_S_1FFF_N_IXA_HS"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="S0"/> <link linkdef="S0_BASIC"/> <link linkdef="MC_S0"/> <link linkdef="MC_S0_BASIC"/> <link linkdef="S0_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW050_172 'ZW 050 Intrusion Alarm 1' --> <nodedef id="UZW0196" nls="172"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ST" editor="ZW_OFF_0_ON_100"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts/> </cmds> <links> <ctl/> <rsp> <link linkdef="S0"/> <link linkdef="S0_BASIC"/> <link linkdef="MC_S0"/> <link linkdef="MC_S0_BASIC"/> <link linkdef="S0_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW095_002_1 'Radon Fan - Parent' --> <nodedef id="UZW0197" nls="0"> <sts> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW095_002_143 'Radon Fan' --> <nodedef id="UZW0198" nls="143"> <sts> <!-- cc=0x32.02 METER grp=0 ch=2 --> <st id="CC" editor="_1_3"/> <!-- cc=0x32.02 METER grp=0 ch=2 --> <st id="ST" editor="_73_3"/> <!-- cc=0x32.02 METER grp=0 ch=2 --> <st id="CV" editor="_72_3"/> <!-- cc=0x32.02 METER grp=0 ch=2 --> <st id="TPW" editor="_33_3"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x32 METER grp=0 ch=2 --> <cmd id="RESET"/> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp/> </links> </nodedef> <!-- Z-Wave ZW097_1 'ZW 097 On-Off Power Switch' --> <nodedef id="UZW0199" nls="121"> <sts> <!-- cc=0x25.03 SWITCH_BINARY grp=0 ch=0 --> <st id="ST" editor="ZW_OFF_ON_UNKNOWN"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <cmd id="HAIL"/> <!-- cc=0x25 SWITCH_BINARY grp=0 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <!-- cc=0x27 SWITCH_ALL grp=0 ch=0 --> <cmd id="ALLON"/> <cmd id="ALLOFF"/> <cmd id="DON"> <p id="" editor="ZW_0_100_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="QUERY"/> <cmd id="SETTIME"/> <cmd id="CONFIG"> <p id="NUM" editor="_107_0_R_0_255"/> <p id="VAL" editor="ZW_CONFIG"/> </cmd> <cmd id="WDU"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="BSW"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="MC_BSW"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW097_143 'ZW 097 Energy Meter 1' --> <nodedef id="UZW019A" nls="143"> <sts> <!-- cc=0x32.02 METER grp=1 ch=0 --> <st id="CC" editor="_1_3"/> <!-- cc=0x32.02 METER grp=1 ch=0 --> <st id="ST" editor="_73_3"/> <!-- cc=0x32.02 METER grp=1 ch=0 --> <st id="CV" editor="_72_3"/> <!-- cc=0x32.02 METER grp=1 ch=0 --> <st id="TPW" editor="_33_3"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x32 METER grp=1 ch=0 --> <cmd id="RESET"/> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW097_304 'ZW 097 Heat Alarm 1' --> <nodedef id="UZW019B" nls="304"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ALARM" editor="_25_0_S_0004_N_IXA_HEAT"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW097_166 'ZW 097 Overheat Alarm 1' --> <nodedef id="UZW019C" nls="166"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ST" editor="ZW_OFF_0_ON_100"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts/> </cmds> <links> <ctl/> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW097_181 'ZW 097 Power Alarm 1' --> <nodedef id="UZW019D" nls="181"> <sts> <!-- cc=0x71.05 NOTIFICATION grp=1 ch=0 --> <st id="ALARM" editor="_93_0_S_0040_N_IXA_PM"/> </sts> <cmds> <sends> <!-- cc=0x71 NOTIFICATION grp=1 ch=0 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="SCENE_R_CFG"/> <link linkdef="SCENE_MC_R_CFG"/> <link linkdef="ASSOC"/> <link linkdef="BASIC"/> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="ASSOC_CMD"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW097_001_1 'ZW 097.1 On-Off Power Switch' --> <nodedef id="UZW019E" nls="121"> <sts> <!-- cc=0x25.03 SWITCH_BINARY grp=0 ch=1 --> <st id="ST" editor="ZW_OFF_ON_UNKNOWN"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <!-- cc=0x25 SWITCH_BINARY grp=0 ch=1 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="DON"> <p id="" editor="ZW_0_100_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="MC_BSW"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW097_001_251N002 'ZW 097.1 Basic Control 2' --> <nodedef id="UZW019F" nls="251"> <sts> <!-- cc=0x20.03 BASIC grp=2 ch=1 --> <st id="ST" editor="_56_0_R_0_255"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl> <link linkdef="MC_BASIC"/> </ctl> <rsp> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW097_001_143 'ZW 097.1 Energy Meter 1' --> <nodedef id="UZW01A0" nls="143"> <sts> <!-- cc=0x32.02 METER grp=1 ch=1 --> <st id="CC" editor="_1_3"/> <!-- cc=0x32.02 METER grp=1 ch=1 --> <st id="ST" editor="_73_3"/> <!-- cc=0x32.02 METER grp=1 ch=1 --> <st id="CV" editor="_72_3"/> <!-- cc=0x32.02 METER grp=1 ch=1 --> <st id="TPW" editor="_33_3"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x32 METER grp=1 ch=1 --> <cmd id="RESET"/> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW097_002_1 'ZW 097.2 On-Off Power Switch' --> <nodedef id="UZW01A1" nls="121"> <sts> <!-- cc=0x25.03 SWITCH_BINARY grp=0 ch=2 --> <st id="ST" editor="ZW_OFF_ON_UNKNOWN"/> <st id="ERR" editor="ZW_ERR" hide="T"/> </sts> <cmds> <sends> <!-- cc=0x25 SWITCH_BINARY grp=0 ch=2 --> <cmd id="DON"/> <cmd id="DOF"/> </sends> <accepts> <cmd id="DON"> <p id="" editor="ZW_0_100_PERCENT" optional="T"/> </cmd> <cmd id="DOF"/> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> <link linkdef="MC_BSW"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW097_002_251N002 'ZW 097.2 Basic Control 2' --> <nodedef id="UZW01A2" nls="251"> <sts> <!-- cc=0x20.03 BASIC grp=2 ch=2 --> <st id="ST" editor="_56_0_R_0_255"/> </sts> <cmds> <sends/> <accepts> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl> <link linkdef="MC_BASIC"/> </ctl> <rsp> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> </rsp> </links> </nodedef> <!-- Z-Wave ZW097_002_143 'ZW 097.2 Energy Meter 1' --> <nodedef id="UZW01A3" nls="143"> <sts> <!-- cc=0x32.02 METER grp=1 ch=2 --> <st id="CC" editor="_1_3"/> <!-- cc=0x32.02 METER grp=1 ch=2 --> <st id="ST" editor="_73_3"/> <!-- cc=0x32.02 METER grp=1 ch=2 --> <st id="CV" editor="_72_3"/> <!-- cc=0x32.02 METER grp=1 ch=2 --> <st id="TPW" editor="_33_3"/> </sts> <cmds> <sends/> <accepts> <!-- cc=0x32 METER grp=1 ch=2 --> <cmd id="RESET"/> <cmd id="QUERY"/> </accepts> </cmds> <links> <ctl/> <rsp> <link linkdef="ASSOC_MC"/> <link linkdef="MC_BASIC"/> </rsp> </links> </nodedef> </nodeDefs>
  8. Sorry for the confusion. I meant ISY Portal and the shade type in Google, to use open/close (similar to the way that Alex was configured).
  9. Any chance of getting the portal to provide native support for Zwave Shades? I see in the Google documentation that shades are a supported type. Thanks in advance, Craig
  10. Good morning all, I'm trying setup a simple program to monitor my sump pump. I did not want to plug something inline with the pump, so I took a short power cord, stripped away the outer insulation and am trying to use the Aeotec Home Energy Monitor GEN5 to monitor the pump running. My goal is to detect when the pump hasn't run in a long time (we live in a wet area, so it wouldn't be normal for it to have no run in say 8 hours), or if the pump was on for more than a minute (the float is stuck). I'm presently running ISY version 5.3.4 (zwave 5 board). I don't want to overwhelm the zwave network with unnecessary traffic, so I am trying to only report when values change over a certain threshold (say 50 watts, vs the typical fluctuation). If I run this thing in selective reporting mode off (parm 3 set to 0), I reliably get results back from both clamps at the scheduled reporting interval (options 111,112 set to 10) . If I then take and change option 3 to 1 (selective reporting on), I get no data back, unless I run a query on the node. Presently I've set parm 5 (Threshold change in wattage to induce a automatic report) to a value of 5 watts, and am reporting just wattage (option 101 is set to 256). The power usage should be easy to detect as the pump itself goes from 0 watts being used to 500 watts when it's running, this would be well over the 5 watt reporting threshold. I also found someone reported that disabling option 13 (CRC-16 Encapsulation Command) worked, but thus far no dice. Any help would be appreciated. Manual page for the device are: https://s3.amazonaws.com/cdn.freshdesk.com/data/helpdesk/attachments/production/6103460145/original/ES - Home Energy Meter Gen5.pdf?response-content-type=application%2Fpdf&X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAS6FNSMY2XLZULJPI%2F20210809%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20210809T182513Z&X-Amz-Expires=300&X-Amz-SignedHeaders=host&X-Amz-Signature=a6cdb63beb99277fcae7d790652c0b959d5ac4edb7f91265ec3fff0d76ea08f1 The parameter configuration for option 101 is described here: https://help.aeotec.com/support/solutions/articles/6000191986-hem-gen5-parameter-101-103-and-111-113-use- Thanks in advance, Craig
  11. You can set up a routine with "open the gate" then have it actually turn on the gate device. Hope this helps, Craig
  12. cwitter posted a topic in Google Home
    Good morning all, I see that GH now supports local control of devices and that the SDK is now out of the developer preview. Are there any plans for ISY to be supported? https://www.androidpolice.com/2020/04/07/googles-speakers-and-displays-add-local-control-of-smart-home-devices-starting-with-hue-tp-link-more/ Thanks! Craig
  13. I see in the release notes that the option button for the Schlage lock is supposed to be fixed. I can confirm that it does still error out around 50% of the time.
  14. cwitter posted a topic in ISY994
    Last night I installed the 4.2.18 build for the ISY994. Now I've noticed that my motion sensors (2842-222) aren't reporting back dusk status. I'm getting back battery and motion information, just not dusk. The information at that point is just blank. Does anyone else have this issue? I also just downloaded the event log from the ISY and it too shows no dusk events since yesterday evening after the upgrade. Any help would be appreciated. Thanks in advance, Craig
  15. Hello everyone, In the past I had an IOLinc connected to my alarm panel. I used the sense option to attach to a trigger on the alarm panel that would be opened or closed depending upon the state of the alarm system (disarmed or away). I then had used the relay to close a zone so that the alarm system could be remotely turned off or on (basically a 2second close would cause the zone to arm or disarm (toggle)). I do recall in the middle of the night hearing my alarm keypad beeping at 3 am (the time the query all runs), so the relay must have changed state. Ive since gotten rid of this arming/disarming function and have only got the sense wire hooked up for alarm state. I can only think of this happening 2 or 3 times in a year. I just bought another IO linc with the intent of being able to open / close my garage and see the status of this. In this case if that relay changes status the garage door will open or close in the middle of the night. Has anyone else experienced this? I've done quite a bit of reading and see other people having trouble with getting the proper status back. I've also saw one person having issues with the relay changing status and it was suggested that it could be due to communication issues. Any thoughts? Thanks in advance, Craig
