Jashanahan
  1. Received the new PLM. Just set up the connected home. Amazing! Sent from my iPhone using Tapatalk
  2. Thanks for the replies. Good thing for Amazon two day shipping. Sent from my iPhone using Tapatalk
  3. Wow delicate device! Will I need to reconfigure anything in the console when the new one comes in or just plug into the isy? Sent from my iPhone using Tapatalk
  4. Thanks but no luck. There is no light evident on the PLM. Sent from my iPhone using Tapatalk
  5. Has anyone seen this process damage a PLM. ISY portal was installed and UUID confirmed. The admin console not consistently entering "safe mode". Sent from my iPhone using Tapatalk Meant now consistently entering safe mode. Sent from my iPhone using Tapatalk
  6. I have a scene that turns off all of the lights in the basement (when scene is turned on by mobilinc or keypad). "Basement Lights Off"-- unclear how that would be set up w Amazon. I would assume the word "on" would need to be used to activate the scene making the phrase "Alexa basement lights off on". Any ideas how better to configure? Sent from my iPhone using Tapatalk
  7. Moving from Mobilinc connect control of the ISY to UDI portal control (for both Mobilinc and Amazon ECHO control)... Can someone provide a step by step approach (or YouTube video). I have NOT used or attempted the skills approach prior to Connected Home release... Thanks, James
  8. I setup 2 Switchlinc dimmer as instructed via the ISY as a 3 way switch. Works locally just fine. When one switch is turned on or dimmer the other mirrors. However, when I try and control the switches via My Devices with the Mobilinc I get "Bad Message ISY failed to process...". If I go into My Scenes via Mobilinc and click on the 3 way scene I once again get a similar message"Bad Message ISY failed to process...". I cannot control the 2 switches via the Mobilinc via the scene menu or the devices menu.
