stevehoyt
  1. just wondering??? Since the hub does not require a PLM the only use case for a better hub would be for 3rd party folks like ISY etc. Wouldn't it make more sense for insteon to invest their $$ in hub 3 instead.
  2. any Polisy users done the update?
  3. I had the issue too. Am running on an iMac. I cleared my cache and reloaded the installer. The problem was still there. After about 2 days it went away and is bac k to normal.
  4. I have been running Kasa for many months. FYI here are my parameters
  5. FYI I have 26 YOlink devices all running from a single hub in the center of my 2 story house. At least 5 are about 250 feet away from the hub. No issues.
  6. I have used the yolink for almost 2 years now. I second what @dwengravitz said. Great Product
  7. @photogeek54 As I assume you know by now, Benoit found the issue that related to the version number and has fixed it temporarily. When you make the change he requested, could you also make a change for me. I understand the part about having to add the custom parameter for the Api key. Could you have the custom parameter come up with the key word api_key filled in. That way I only have to add the key itself. It took me a couple tries to figure out that it had to be api_key. Not knowing that it needed the underscore, for us non programming folks, might help make it easier. Thanks
  8. @bpwwer @photogeek54 bpwwer thanks for the analysis. I logged in and out of PG3X, rebooted the polisy. Also tried manually logging into the portal to check my license....license was/is good. I can get into the portal manually and rebooting/logging out did not help. I will open a ticket Thanks Steve
  9. @photogeek54@Javi Yes it was the non production version. I get the message "Successfully checked for purchased node servers" ,but then the popup to install it, never comes up. I have tried other node servers and don't have the issue. I looked in the PG3 log and it appears I am getting a "failed to get license error". I have attached the log below. Please note the error around 6:32 am. this morning Maybe my license has gone bad? Is there some way for me to bypass this step and do a manual install? pg3_3-3-2024_63623_AM.zip
  10. @photogeek54 Hi I have been running this for some time v 1.1.04. I recently had a battery die and had to have it replaced. Multiple batteries showed up so I thought a good way to clean things up would be to delete the plug in and reinstall it from the non production store. I can't get it to install. I click the install button and nothing happens. Any ideas on what to do? Thanks
  11. Sorry if I offended you Paul. I have no problem with yolink support or ISY they are both great. My intention was that if more people reported as I had that they could resolve the issue quicker as the issue seems to have many facets to it. I have heard from them and know how to fix it now.
  12. Check out my post further down titled " "connect to broker timeout". Apparently they are throttling/ rejecting our connection requests. I have had problems all this month with the yolink API. I stopped getting updates through the Yolink nodeserver. Looking at the Yolink nodeserver logs I was getting the error "Connection to broker timedout" @Panda88 and Michaels team did a great job trouble shooting the issue and found that the nodeserver is being rejected by Yolink. Just recently many of my motion sensors stopped reporting their status via the Home Assistant interface. Check your HA logs. I am seeing "yolink MQTT client disconnected" thousands of times So the bottom line is, something has drastically changed with their API access over the past month. I have sent 2 emails to them and am still having the problem. I am going to escalate it to yolink again today. I think we all need to send our issues to their support people. I have heard, as others have posted here, that a new yolink hub is on the way that is going to have local API access. Hopefully that will solve these issues.
  13. stevehoyt replied to Crunchie58's topic in YoLink
    I have had 30+ devices running on Yolink for almost a year now. I placed my hub in the center of the devices. They are spread out up to 250 feet in all directions around it. Also the ISY Yolink plugin/nodeserver is rock solid and support great. It sounds like you may not even have an ISY in the mixture. So as said above maybe the yolink site might be a better place to go. In any case here is a bit of info on their sampling parameters
  14. Done check your messsages and let me know if you did not get the info @Panda88
  15. @Panda88 UDI just logged in and took a look....The current best guess is that the payload being sent back is too large to get transferred before a timeout. They are investigating. I will let you know what I hear. This all started around the time I added 2 new sensors to my yolink. That may explain it.
