bwoodfl
Everything posted by bwoodfl
  1. Yes, they both are in the scene as a controller/responder. I also tried turning the scene off and on and it still is not lighting the B Button on the keypad. If I look at the scene it shows both as being on.
  2. Hi, I just added an 8 button Keypad, I have the "B" button assigned to a 2634-222 On/Off Outdoor Module. When I press the B button on the keypad the module turns on just fine. The LED brightens when it is on and dims when it is off. If I turn the module on from the Admin Console the LED does not change to show if the module is off or on. How do I make the LED change when the module is turned on or off from the Admin Con?
  3. Hi Guys, I have no idea what y'all are taking about with all of this. Will there eventually be something that a non programmer/code will be able to use with my ISY and Echo, or do I have to try to figure out what you are doing?
  4. bwoodfl posted a topic in ISY994
    I have a 2477D - Dual Band Switchlinc Dimmer that controls ceiling can lights in a room. The switch works just fine, I also have 2 lamps in the same room. Is there a way to program the switch so if I press Off twice that it would turn the lamps on and then if I pressed Off again twice that it would turn the lamps off? I still want the swith to control the canned lights with the normal on and off and hold for dim and be able to use the same switch to control the lamps. Thanks for any help. Bill
  5. bwoodfl replied to garybixler's topic in ISY994
    About the same here. It sits in the corner, I have to retry setup almost daily because it won't do anything except beep. I retry setup and it will respond and will tell me the time when I ask. I do have the utterance set, so I can say I am home and it will send a text message to all our cell phones letting the household know I am home. I am patience and will wait until it will really do something.
  6. bwoodfl replied to clarkes71's topic in ISY994
    I am having this same problem. I was changing the port on my ISY tonight. It did a reboot, then all my lights went out and I cannot connect to the ISY again. When I reboot the ISY manually, it reboots and turns off all my lights and I still cannot connect to it again. It says ISY not found.
  7. bwoodfl replied to bwoodfl's topic in ISY994
    Hi Gary, Thanks, but I need more help. Not sure about programming much. Would this be correct: http://user:pass@XX.XXX.XX.XX:80/rest/nodes/26 4A 66 1/cmd/DON Not sure what port to use (80) Does that go as http request GET or POST? If it is post which of the following: Text URL encoded json xml This is the Custom Behavior Screen Any help or explanation would be appreciated. Once I get the idea in my head I think I would be ok. Thanks, Bill
  8. bwoodfl posted a topic in ISY994
    Hi, I just got my UBI (www.theubi.com) it seems to work pretty good. I am trying to see if there is a way to have the UBI control my lights, etc through my ISY. I don't know much of anything about programming, the UBI can make http Get and POST commands but I don't know what that is. Is that something that would work with my UBI? Several months ago, I sent Michael a link to the ubi and he contacted the designers of the ubi, but I don't know if anything came from that or not. Is this possible to do? Thanks, Bill
  9. No changes, Using v 3.3.10
  10. Thanks Lee, That was the problem. Is there something that would change all my lamplincs like that? I went and changed them all to 100% and they work fine now. Don't know what changed them all to 0% to start with. Thanks again.
  11. The Event Viewer Log is attached. First I ran the program that would turn the lamps on, then I issued an off from Admin Console and the issued an ON from the Admin Con. I then issued a 'FAST On' from the Ad Con. ISY-Events-Log.v3.3.10__Wed 2013.04.03 11.51.25 PM.txt
  12. All of the sudden all my lamplincs will not respond to 'On' from the ISY or from Mobilinc. They will respond to 'On' from a program but not from the mobilinc or the ISY. They will respond to 'Fast On' from the ISY, but the mobilinc does not have the fast on, just off and on. Everything will respond to 'Off' both from the ISY and mobilinc and programs. Any ideas what to check? Thanks, Bill
  13. Thanks for the replies. Would it make a difference that the lights on the fans are on separate switches? The lights are on 2 light switches one at each door and each control both lights, then the fans are on a different switch. Bill
  14. I have 2 ceiling fans in my living room that are both on one regular light switch. I want to automate the fans. I tried using the Switchlinc 2 wire Dimmer (2474DWH) with no success. It worked for a few minutes then burned out. I do not find another switch that might work. Does anyone have any suggestions what else I could do to add the ceiling fans to my ISY994i so I could add to my programs? Bill
