GeneInSoCal
Everything posted by GeneInSoCal
  1. GeneInSoCal replied to GeneInSoCal's topic in ISY994
    Sorry.......That's what happens when you are a monopoly. I would think that they would be happy to have more approved devices on their short HAN list. Thanks for your efforts.
  2. GeneInSoCal posted a topic in ISY994
    Whatever happened to the testing of the ISY by SDG&E to be listed on their accepted HAN list? Is it no longer cost effective to have this device tested? Thanks
  3. I am a retired electrician. I have an electric cart (Gem) with a battery charger that draws about 18 amps at startup. I use a 30 amp 120 volt relay mounted in an 8x8x4 metal Hoffman type enclosure that in turn feeds a dedicated 20 amp cord for the battery charger. . Also inside that enclosure, I use an Insteon din-rail mounted on/off relay model #2453-222 mounted on a small piece of din-rail. I use that to break the 120volt coil circuit of the 30 amp relay. I also mounted an external switch on the Hoffman enclosure that will manually engage the 120volt coil if I want to override the insteon program. Sounds more complicated than it really is. Basically, The Insteon relay is interrupting the coil circuit of the 30 amp relay. Theoretically, you can do the same thing with any relay or motor starter up to about 100 amps (even a multi-pole relay/starter as long as the coil circuit of the relay/starter does not draw more than the rating of the Insteon din rail mounted relay (15 amps). I would not trust an Insteon device to open/close a load drawing more than 10 amps.
  4. I use Event Ghost with about 20 different audible notifications such as "Fountains on", "Motion sensed", "Irrigation started" and more. Works well.
  5. When LED Xmas lights first made an appearance on the scene about 3 years ago, I had problems with them not shutting off completely. Even though they were supposed to be off, they still glowed faintly due to leakby current. So I took a unused 120v to low voltage (i.e. 6, 12 volt) transformer and cut the low voltage side to about 2 inches long and taped off the ends. I then plugged it into the same power strip with the lights to give it a slightly larger load than the Xmas lights. This solved my problem of them not shutting off. Not saying that this will help your problem but it is worth the try. Just plug in a low voltage transformer without cutting off the secondary wire. If it works, then cut off the load wires and tape them. I am sure that you have an unused transformer from an old video game or phone.
  6. I just had my Home HVAC system replaced last week ($6000) and have been using the Venstar T5800 with the ISY for over 1 1/2 years without a problem. It links wirelessly with the ISY. I also use Event Ghost to announce any changes made to the stat by the ISY. There are a number of past topics addressing this very setup.
  7. I have the Venstar T5800 as well. The Skyport accessory will allow you to control the T-Stat over your Android phone from any location. I have been using that for about 2 years. I also have the ISY-994 controlling my T-Stat. I have the ISY automatically changing the Stat settings 4 times daily based on time of day. I use Mobilinc on my phone if I want to override or change those times remotely. I use Event Ghost to announce those changes as they are implemented. I am not sure how to post a previous thread here but if you Search for Venstar T6800 you will see the previous thread on how to use ISY and Venstar together. Gene
  8. Using your information, I am successfully controlling my Venstar T5800 with the networking module. Thank you so much for the information.
  9. Michel: Has there been any progress with the testing and acceptance for SDG&E?
  10. Any news yet on SDG&E Michel?
  11. Yahooooooooo...it works. Thank you for your efforts. Gene
  12. Michel: Has there been any forward progress with SDG&E? Thanks,
  13. Has anyone gotten this Event Ghost plugin to work with ISY-994i as of yet? I too tried to modify the .ini file with Wordpad as well as Notepad and it still does not work. If someone has, could you please post the file like the initial configuration file on page 1 of this posting. Thanks, Gene
  14. Thanks Michel. Like I said, I knew if anyone could work this through it was you. By the way, I believe that SDG&E requires a 16 digit MAC ID and Install Code, not 24 or 32. Gene https://www.sdge.com/webform/3837/conne ... mart-meter
  15. Michel: I found these web sites for more information about testing products with SDG&E. I am not sure if this would help you or not? http://www.sdge.com/home-area-network-d ... validation http://www.smartgrid.gov/recovery_act/n ... art_meters And am I to understand that testing with the Utilities is dead in the water due to the cost of the proprietary test harness? Thank you, Gene
  16. It seems as though Kingtd is the author of this plug-in. (page 1 of this post) I am having the same problem as everyone else. Thanks, Gene
  17. Thanks Michel. I knew if anyone could solve this problem, it was you. With more and more utilities changing to smart meters, it had only to be a matter of time until the ISY-994i got accepted. Utilities like PG&E, SCE and SDG&E will set the standards for the rest of the Industry. I live in SDG&E Country but actually work for SCE. If the ISY becomes type accepted by all 3 of these Utilities, it should not pose a problem with others in the Country. However this turns out with SDG&E, thanks for your effort. Gene
  18. I recently had this plug-in working fine with an ISY-99i. I had Event Ghost announcing voice commands. I could also see the "heart beat" of the ISY-99i. Last week, I upgraded to an ISY-994i and seem to have lost the ability to communicate with Event Ghost. I can no longer even see the "heart beat" of the ISY-994i. Is this plug-in not compatable with the ISY-994i or should I be looking somewhere else for my problem? Thanks
  19. Thanks Michel for your generous offer but I think that I'll hold off requesting a refund and hope that the problem with SDG&E can be settled sometime in the near future. Thanks
  20. I received this letter from SDG&E today: Hello Gene, We regret to inform you that the Universal device is not approved for secure compatibility with our smart metering system and we are unable to connect your device at this time. If you have any questions please contact us at homeareanetwork@semprautilities.com. Thank you, Home Area Network Team
  21. I have just purchased a new ISY994i-ZS and wonder if I can use it in SDG&E territory as yet. It is not listed in their list of approved HAN Devices. I just installed a Rainforest RAVEn two weeks ago without any problems from SDG&E and I hope that the ISY994i-ZS will be the same.
  22. First Download and Install Windows Speech SDK51MSM.exe (131.5) http://www.microsoft.com/en-us/download ... x?id=10121 Download and install EventGhost. http://www.eventghost.org/downloads/ Download ISYevent.zip. Unzip and put into the EventGhost plugins folder. viewtopic.php?f=27&t=7274 There is an existing EventGhost plugin that comes preinstalled called Speech with Audio Output. Following the EventGhost instructions, I cleared out all of the plugins on the right side of the screen and installed only the Speech and Isy-99i Plugins. I then linked the isy-99I plugin to the ISY-99i. The Event Ghost should start logging any ISY Event on the left side as it happens. For instance, "Insteon, Heartbeat" is the polling of the ISY-99i. If that is working you are more than halfway there. On the right hand side the configuration tree should say >Autostart > Plugin: ISY-99i > Plugin: Speech with Audio Output On the right side, I added a folder called "Speech" to the "Speech with Audio Output Plugin". Then add a macro to "Speech with Audio" and type in the box whatever I want it to say. From the events logged on the left hand side, I drag and drop the ISY command onto the created macro. An example macro for my Garage Motion Sensor is as follows: I hope that this helps. It sounds more complicated than it is. Gene
  23. This is my first post so I am not sure if it belongs here or not. Please move as necessary. I run a host computer 24/7 with cameras and weather software. I installed Event Ghost on the host computer. I then installed two Event Ghost plugins, the ISY-99i plugin and the "Speech with Audio Output" plugin. First I linked the Event Ghost plugin to the ISY-99i. (I have the network plugin on the ISY-99i) Then on the right side in the "Speech" plugin, I typed whatever I wanted the computer to speak and from the left I dragged the corresponding ISY-99i event to trigger the speech. It works very well and is simple.
