mcgedoue
Everything posted by mcgedoue
  1. Mine working fine now too after switching to Google.
  2. Seems like latest iOS 11 requires 2 factor authentication now, is this working reliably? I’m considering using this script. Sent from my iPhone using Tapatalk
  3. mcgedoue posted a topic in ISY994
    I understand that the Echo will only control Insteon through the Insteon hub, yet I have ISY994i already in place. Does anyone know if having both devices will cause issues? Sent from my iPhone using Tapatalk
  4. Yes that was a typo, but the issue is getting the correct tstat variable to actually send me a text with current temp
  5. Seems simple enough, but I can seem to get below notify variable to work. Just want to be notified I'm away if the temp inside goes above or below range below to indicate a problem. There doesn't seem to be the built in variable in the message options, so found the wiki article about Custom Email Substitution Variables. http://wiki.universal-devices.com/index.php?title=ISY-99i_Series_INSTEON:Custom_Email_Substitution_Variables I still can't seem to get it to notify with current Tstat indoor temp. If <Whatever program here> Then Send Notification to 'Text' content 'Message' ------------------------------------------------------ Message Body... Thermostat temp is: ${sys.node.11 22 AA 1.ST}
  6. by "ISY device status", what I meant was what ISY shows as the current devices status of the fan (on or off).
  7. Referring to TJF1960's question above, is there a way I can have the notification message, include current ISY device status? I see variable options, and have used them before (like current date time), but not sure how to get ISY device status.
  8. The fan is being controlled by a 2477S Dual Band SwitchLinc On/Off Switch. So after rethinking the program logic, one thing comes to mind. After the first...Then Wait 30 minutes Send Notification to 'Group1' content 'Room1 Fan Message' Would the program just blindly send the notification 30 minutes after the 'if' criteria were met? or is the 'if' criteria assumed still? In other words does the current way it's written only check at the beginning, but not current status again just prior to the notification being sent?
  9. Oh and yes I'm checking the fan immediately after the notification, so it should not be off at that point. This is to allow time for her to go turn of her fan that she forgot to get her in a good habit, but if it still does not get turned off within 30 minutes it will go off anyway.
  10. I will check at next false on, and report back.
  11. I have a teenager who is bad about leaving the lights in her room on. To help teach/remind her to get in a good habit, I added following program, however since I'm new to this I must have forgot to cross a t or dot an i somewhere. Please have a look, and see why I may be getting false positives. I will get the text that fan has been on in room with no motion detected for 30 minutes, but then when I check the room the fan is off. Any guidance is appreciated. If On Mon-Fri From 6:00:00AM To 10:00:00PM (same day) And Status 'Room1 Motion Sensor' is Off And Status 'Room1 Fan' is On Then Wait 30 minutes Send Notification to 'Group1' content 'Room1 Fan Message' Wait 30 minutes Set 'Room1 Fan' Fast Off Thanks
