MARosen
  1. Hey guys - can you elaborate a bit on the configuration of the ISY plugin within Event Ghost? Is it reasonable to think one would use the port address already set up for regular HTTP protocol to the ISY? If not, what protocol is being used to talk to ISY via Event Ghost?
  2. MARosen replied to flemingmike's topic in ISY994
    Michel, I did have the correct USER and PASSWORD ... but, the 401 error and your interpretation of it were still the key here to solving this. That and something I had noted earlier in the post as well. That the first time I would try the same command directly in a browser window, the browser still prompted me to enter the USER and PASSWORD a 2nd time. And then from that point forward, I could issue further commands directly in the browser without having to re-enter that information. Both of these combined made me realize that the error was not the PASSWORD itself, but rather the PARAMETER name of the password. I was using PASSWORD= and should have used PWD= instead. So whether directly in the browser or in ISY, the camera was not getting the password sent correctly. The browser's response was to prompt again, the ISY obviously cannot do that as a resource, and so it simply gave the error. Once I corrected this mistake... (how did I ever do that, I was sure I copied the URL right out of the .pdf from Foscam that you guided me towards? No, wait, I didn't. It had so many parameters that I didn't care to set, that I only copied the first important bit of it, and then manually typed the remainder of it!) ... well once I corrected this, it of course worked like a charm. I can now enable and disable the the motion detection through ISY. Thanks for your excellent guidance. Now I am off to figure out how to make use of that resource and somehow tie it my MobiLinc application. Good stuff!
  3. MARosen replied to flemingmike's topic in ISY994
    Thanks Michel - I get an error message when I try this of: TCP client request failed [Net Module Rule: 1:401]. By 'try' I mean using the 'Test' button in the ISY Network Resources module. The first time I tried it, I also got an additional error message, which seems to refer to the WeatherBug module. Only the first time, on subsequent tries I just get the error message above. If I simply paste the command into a browser it works. One note, the first time I paste it into the browser, the browser still prompts me to manually enter the USER and PASSWORD again. Even thought they are embedded as parameters in the URL. Once I enter the first time, it does not prompt me again in that session. I can turn the MOTION DETECTION on and off without re-entering the user and password. Just the first time in a session.
  4. MARosen replied to flemingmike's topic in ISY994
    Michel, Thanks, that resource is 'somewhat' helpful. If you spend a few minutes with it, you will see that the language is rather poor, to the extent that it's even hard to know what the purpose of some of the commands are. Nevermind that it has typos and mistakes etc. in it as well. Putting that aside, I am able to work with it and come up with a URL that allows me to enable the motion detection in my camera. It looks like this; http://MYURL:MYPORT/set_alarm.cgi?motion_armed=1&motion_sensitivity=2&motion_compensation=1&input_armed=1&mail=1&upload_interval=5&schedule_enable=0&user=MYUSER&password=MYPASSWORD. However, what's not clear to me is then how to make this into a resource inside ISY. Is it a GET, a POST, etc? Where does the rest of the URL go, is it in the PATH or is it in the BODY? Do I need to add an Authorization Header? Because as you can see, the user name and password for the camera are embedded into the URL itself - but I notice that in some of the posts, the forum users suggest you have to add this when you create a network resource. Is the Encode URL checkbox checked or unchecked? What is the MODE: URL Encode, Raw Text, etc? Lots of questions right? Is there a resource somewhere that lays this out clearly for me to resolve on my own?
  5. As my 7th grade math teacher would say "Dawn over Marblehead" - I finally get it. Thanks for your replies, I am with you now. You default certain lights on to begin with each day, and then let the Sunny Day pgm turn them off if necessary (and then both programs will turn them on and off again throughout the day as needed.) Makes perfect sense. My issue was because I didn't default them on via schedule. I was letting the programs try to set them (either on or off) based on the weather each day, with no default schedule. The feedback and input is greatly appreciated. Cheers.
  6. Rand, Yes - the "Clear Day" program works, but that wasn't the issue. The issue was the "Cloudy Day" program. That program requires that the Wait program is TRUE. And nothing was setting the program to TRUE, because I had several Cloudy day's in a row. So each day the Wait program remained at the 'default' state of FALSE. And as a result, my lights never got switched on. It wasn't until 2-3 days after I wrote the program, that we had a sunny day. Finally, at that point, the WAIT program changed to TRUE (the programs turned the lights off.) Then, once it was finally TRUE, and it eventually became Cloudy again, then the "Cloudy Day" program worked for the first time. It seemed from the logic that this would happen, and that the programs would only work following at least one period of Clear/Sunny weather. Because of the fact that programs default to being "FALSE" and therefore requiring at least one kick-start to be set to TRUE. If that's so, then I wonder if the same issue will re-occur when my ISY has to be re-started or re-set for any reason. Am I wrong to think that the program logic works, but only after at least one Clear/Sunny period of weather happens? Do you think that if the programs are set up during extended Cloudy/Overcast weather that they should in fact work? If so, then I wonder if somehow I have them set up incorrectly?
  7. Rand, Sorry, I'm still confused. Are you saying you agree, that the programs only work after the first sunny day (after the status of the Wait program gets set to TRUE)? Or am I just doing something wrong?
  8. Rand, Thanks ... how (where) can I take a look at that 4th program? Matt.
  9. I wrote these 3 programs (which I found on the UDI Wiki, but they appear to be the same ones noted here.) When I wrote my three programs, the weather outside was already overcast, my light level was <5 to begin with. The status of my Control program (the 'Wait' program) was FALSE. It was the first of the 3 programs I wrote, and so it had never been run by either the Sunny Day or Cloudy Day programs (they did not even exist yet.) Although it was overcast (light level <5), the status of the Control program was false. In order for the Cloudy Day program to run, the conditions are that light level<5 AND Control program is TRUE. So that program never ran. Am I wrong to think that the program won't work unless you start on a sunny day, and then it eventually turns cloudy??
  10. Have either of you noticed that on iPhone (or any mobile device) it seems impossible to clear the cache when you visit your ISY? Any device that I log in on, using the DEVICES, SCENES or PROGRAMS remains in the memory of the device somehow. Even if I clear history, cache, etc. When I go back to those pages, it never asks me for my ID or Password again. Any thoughts on this?
  11. Michael D et al, Thanks for your replies, appreciate it very much! on item #1: Interestingly, this is exactly what I thought the answer would be. However, I found that no matter what i put in the FROM field, the email comes through using the name of the actual email account. So for example, the user ID I am using is my gmail account which is Matthew.Rosen.00@gmail.com. And that account must be set up with my name which is Matthew A. Rosen. So when I get email from that account, on say, my Yahoo email, it appears to come from Matthew A. Rosen. But even when I put something alternate in the FROM field, for cosmetic purposes as you say, it has no effect. I put the name of my lighting system which is call 112UPLights ... and the email still appears to come from Matthew A. Rosen. Not a big deal at all, just curious because I thought that was what the FROM field was for. on item #2: I am using my gmail account to send the notifications, and it works on 25 but not 587. At least it didn't when I first tried it. Oh well, it works so that's all that matters I suppose. on item #3: what do you know about the ability to actually now customize the notifications? Is that something down the road for the ISY? Or is that something I can do now?
  12. Michel et al, A few questions on this topic overall: 1. What is the difference between the FROM field and the USER ID field? I am on 2.6.8... 2. In your examples, you often show the SMTP port for gmail as 587. However, when I tried that it failed. When I tried using the default port that ISY had in the configuration tab (25) it worked. What is this port, is this something on my router, or something specific to the gmail email service? 3. Is there a way to customize the notifications? I've heard this is possible, is this a future enhancement or something I can today?
  13. Michel, Not sure I ever answered your questions of "am I using Dynamic DNS". I think I am, if by Dynamic DNS you mean how I refer to my network from the outside world. I do NOT get to it by using an IP address in the form of nnn.nnn.nnn.nnn. Instead I use an URL address that I have gotten through a service called no.ip. That address is kept in synch with the actual numeric IP address via a client that runs on my home network and checks for the current assigned IP from the cable modem and associates it with the URL. So in this way I don't have to remember a hard to remember 4 sequence #, and I don't have to keep track of when it changes (and it does on occassion change.) But if you mean something else by Dynamic DNS then I am not sure. I noticed that in my Netgear router admin console there is an entire section devoted to Dynamic DNS but that I don't have this set up. I wonder if this is just an alternate way to do what I am already doing using the no.ip client that runs on my network perhaps?
  14. Michel, Can you remind of whether my Console should say "Enable Internet Access" or not? In other words, does it need to be enabled to allow the appropriate access? The reason I ask is that it crashed again this morning, and I was unable to revive it through the normal method of Telnet ... I had to physically unplug and re-plug in the ISY device. On doing that, it seems that the "Enable Internet Access" was set back to not being enabled. That said, I was able to access the page remotely - - but I am not sure it worked as well as it should. The programs area was difficult to work with, and I could not save any changes while I was remote. I've tried a few times now to "Enable" but I get an error message of "Failed Enabling Internet Access" As a reminder I have UPnP disabled, and have port 443 forwarded to the fixed IP address as assigned in my router. And I can see that the device is in fact attached to my router.
  15. Michel, I suspect you have it figured out. Once I resolved my original issue (being on the old version of the ISY software) and having seen the ISY auto-magically connect on my router I stopped all the port forwarding. So now I have disabled UPnP and forwarded port 443 for HTTPS to the device's assigned static IP. I suspect that this will resolve any temporary burps or glitches that take place on my network and will keep the ISY device available for connection over the internet. If it doesn't for any reason I'll let you know. Cheers!
