AT&T to end email-to-text ×
TheEther
  • Posts
    19
Everything posted by TheEther
  1. Wanted to follow up on this. After buying a new ISY 994i ZW+ IR/Pro and transferring everything over. I had the same issue. So... Packet captures, wire sharks and switch mirror ports fun ensued. Narrowed it down to my Plex Media Server. ....and making a very long story short. Disabling the DLNA server in Plex Media Server (PMS) fixed the issue. Good news is I have a shiny new ISY.
  2. I'll also add this ISY-994i is 10 years old (or very close to it). Been a great unit. Ordered a replacement today. I've been noticing my Insteon stuff has been flaky lately and it appears due to Tcp timeouts, that'd be the reason.
  3. I dont think the issue is Firmware frankly. It appears to be a hardware issue with the ISY. I've tried different Ethernet cables, different switch ports, a different switch and hard-setting the switch ports to 100-full and 10-full. I'm using an Aruba enterprise class POE switch (no consumer class garbage). I've verified no packet loss elsewhere on my LAN. I dont know of anything else to try on the ISY. Thoughts? Suggestions welcome or time to replace it? Thanks! ISY Log Shows: Wed 2021/04/21 06:22:59 PM System -5 Start Wed 2021/04/21 06:23:00 PM System -110022 /CONF/INSTENG.OPT Wed 2021/04/21 06:23:00 PM System -110012 /CONF/INSTENG.OPT Wed 2021/04/21 06:23:04 PM System -110022 /DEF/F6/I1/NLS/EN_US.TXT Wed 2021/04/21 06:23:05 PM System -110022 /CONF/UXT.BIN Wed 2021/04/21 06:23:05 PM System -110012 /CONF/UXT.BIN Wed 2021/04/21 06:23:06 PM System -7153 ID 0002 :err=0, tag='/group', num=20, nest=5, o Wed 2021/04/21 06:23:06 PM System -7153 ID 0003 :err=0, tag='/node', num=28, nest=5, of Wed 2021/04/21 06:23:06 PM System -7153 ID 0004 :err=0, tag='/node', num=28, nest=5, of Wed 2021/04/21 06:23:06 PM System -7153 ID 0005 :err=0, tag='/node', num=28, nest=5, of Wed 2021/04/21 06:23:06 PM System -7153 ID 0006 :err=0, tag='/node', num=28, nest=5, of Wed 2021/04/21 06:23:06 PM System -7153 ID 0008 :err=0, tag='/node', num=28, nest=5, of Wed 2021/04/21 06:23:07 PM System -170001 UDQ:Queue Full: ELK : Task[13] Modules MOD-CB-Elk Secu pty=24 Wed 2021/04/21 06:23:28 PM System -170001 UDQ: Queue(s) Full, message ignored Wed 2021/04/21 06:23:53 PM System -170001 UDQ: Queue(s) Full, message ignored Wed 2021/04/21 06:24:04 PM System -170001 UDQ: Queue(s) Full, message ignored Wed 2021/04/21 06:24:31 PM System -170001 UDQ: Queue(s) Full, message ignored
  4. I'm using the ToggleLincs so am I correct that the LED's wouldnt matter if I did one dimmer and multiple relays?
  5. When doing 3 and 4 way switches and a dimmer is desired, do all of the switches need to be dimmers or just the load switch? Thanks!
  6. I hadn't noticed the Peren's lines *facepalm*. Thank You!
  7. The following program is intended to turn on the lights in the kitchen when the garage door is opened between sunset and sunrise and the Elk is armed in certain modes. It doesn't work that way though... What this program does is turn on the lights at Sunset regardless of whether the garagedoor is open or not and leaves them on till I turn them off. Appreciate your help. If From Sunset To Sunrise (next day) And Elk Area 'House' 'Armed State' is Armed Away Or Elk Area 'House' 'Armed State' is Armed Night Instant Or Elk Area 'House' 'Armed State' is Armed Stay And Elk Zone 'Garage Ovrhd Dr' 'Physical Status' is Open Then Set '1st Floor Kitchen Bar Lights' 50% Else Set '1st Floor Kitchen Bar Lights' Off
  • Create New...
