Everything posted by ISYNewBee
Some devices no longer responding to ISY
Thanks LeeG and larryllix. You pointed me in the right direction. These problems were with the scenes. The scenes lost some of their programming. I ended up deleting the scenes and re-creating them to get it to work. Seems to work during test now. I'll see if it works tonight when the program is set to turn them on.
I have had my ISY994i for about a year and everything was working great. Now, for some reason, several of my devices are no longer responding. There seems to be no rhyme or reason as to which ones quit working (seemingly all at once). I have 2 Insteon Dimmer Switches in my kitchen, located side by side with each other. One works, the other doesn't. I have 3 OutetLinc in my living room, all within 12 feet of each other. Two of them work, the third doesn't. I have 3 outletlincs in the yard to turn on/off the LV lighting. 2 of those work and the third does not. Surprislingly, it is the closest one to the house that DOESN'T work. The ones that are farther down-line are working fine. If anyone has clues, please help. I'm totally confused.
On but not Off
Thanks All. That was my mistake - no else clause. I'll try it tonight.
On but not Off
I've been using Insteon for years, with Houselinc software on my PC. I don't really like leaving my computer on all the time so I bought the ISY recently when it went on sale. I've plugged it in and it seems to have retrieved all the links in my devices, after I ran around the house and pushed the linking button on each device. I can turn lights on and off from the software interface, and I've looked through the scenes that it created and they seem to be good. I created a scene of my own for my Outside lights. These are all on Outletlincs. The low voltage transformer is plugged into the controlled outlet. I wrote a program to turn the lights on from Sunset + 30 minutes to 11:00 PM, same night. For some reason, the ISY will successfully turn on the lights at sunset + 30 minutes without fail, but it does not turn them off. I've found them left on every morning when I get up. I manually turn them off using the web interface. Does anyone have experience in this arena? BTW, I had a corresponding event in the Houselinc software that worked flawlessly, but I disabled all of the events in Houselinc so the ISY should be doing everything by itself. Thanks for your comments.
