3PNTSTech
  • Posts
    10
Everything posted by 3PNTSTech
  1. 3PNTSTech
    Programing
    Yeah thinking maybe a full restore and clear is needed. I removed the Montion Sensor from ISY, and re-added it. check to ensure that the lights were not going on and off. the lights in the basement are now acting when I walk into the office. So must be a communication issue. So it's not that they are work sometimes, they are working all the time, just not link or maybe incorrectly linked. Oh, I even factory reset the sensor and deleted it from ISY. So there is something a little fishy. Kevin
  2. 3PNTSTech
    Programing
    Awe thanks guys, your great. No I removed all the scenes, however it seems that the "scenes" are still there. but there is no scene in ISY. I am going to try to relocate the PLM away from everything just I have the ISY next to the (servers) which the PLM is currently plugged into the same (dedicated Line for them) Its not on serge protection, just on a the same line something like this: PLM ----- PLUG ------ PLUG-----FUSE BOX---- OUTSIDE WORLD | A few servers Other than that I really don't how else to bring everything to a start point, to ensure good communication, (as all of my stuff is duel band) and the stuff removes links. Kevin
  3. 3PNTSTech
    Programing
    Not sure why it double posted here... must be sleepie!
  4. 3PNTSTech
    Programing
    Here is my idea. I have a sensor in the office which controls a plug and light. I wanted that once I walk into the room it would turn on that small light and stay on if motion is detected. Which it does. However, with all the changes going on etc. It seems that it's linked to another device. Next to my office is a living space with one sensor and 3 Insteon light bulbs. Before I had them programmed to come on once someone walks into the basement living area, but now when I walk into the room only 2 of the 3 turn on, and it seems that the one light is now controlled by office sensor. This is what i mean about some lights go on and some do not. But what gets me, is my first few initial tries the office light turned on but didn't turn off, even after leaving the room all night the light was still on. I have the following set. If Control 'Office Motion' is switched On Then Set 'office Lights' On Wait 15 minutes Set 'office Lights' Off Else - No Actions - (To add one, press 'Action') See what I'm puzzled about, and from past experiences, that one you have a IF/THEN/Else program, the program doesn't run it self again until it stops. So in theory, when you trigger the sensor it would turn on the lights, wait 15 minutes and then turn it off before or even if the sensor is tripped again. but it wouldn't explain why the lights go off even with a program is there, and the lights till go out after 1 minutes even though the program tells it to wait 15.... I'm very weirded out. At this point, I'm wondering if resetting the PLM or whatever you call it. and just fresh clean start would be a good option. I did relocate the PLM, to a more and less noisy area, I guess it would be ideal if you could install that almost right next to the fuse box eh? Well, I'll leave that for now, and possible tomorrow start fresh. Unless you guys have an idea? Kevin
  5. 3PNTSTech
    Programing
    Hey Guys, Thanks for the info, not sure what I'm doing wrong, but it's not working. I may need to reset everything, but now after clearing the scenes, and create new programs, some of the lights are going on, and staying on, others are turning off. Does Folders make a difference here? So if a program is nested in a folder will that effect it. Give you an example. If Control 'Main Bath Motion.1-Sensor' is switched On Then Set Insteon 'office Lights' On Wait 15 minutes Set Insteon 'office Lights' Off Else - No Actions - (To add one, press 'Action') Once I walk into the room this morning the office lights were still on. Sensor is configured like this: Timeout 2 LED Brightness: 50 Dark Sen: 128 Sensing Mode: Checked On only Mode: Unchecked Night Mode: Checked maybe I just need to walk away for a bit! hahaha I'll play with a bit more this evening. Kevin
  6. 3PNTSTech
    Programing
    Awe, thanks guys, I'll give that a try. When deleting a scene, I sometimes think that the "link" is never broke, how do you break or make sure those links are broken? Kevin
  7. 3PNTSTech
    Programing
    Hi there, I'm new to UDI, but so far it's looks like a awesome tool. I'm not a programer by trade, but I was wondering if someone would be willing to help me. I used this link below to setup a simple motion, triggers lights, and lights to stay on for 15 minutes, if motion is sensed again, that it would stay on type of thing. http://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Using_Motion_Sensors_in_Bathrooms However, even using that, once the motion sensor turns off, it turns off the light too. Doesn't repeat or anything. I'm more of a guy that likes to be shown first, then I can go from there. So what am I doing wrong? Is it that I setup the lights in a Scene... because before I setup any type of program, it would turn them on or off. Or is a push to device type of thing? Any suggestion welcome. I used Code 4,5,6 in the WIKI, and can't get it to work. 5. Program Main Bath Motion On - Enabled If Control 'Main Bath Motion.1-Sensor' is switched On And Program 'Main Bath Motion Timer Enable' is True And Status 'Main Bath Lights' is not On Then Set Scene 'sMain Bath Lights' On Else - No Actions - (To add one, press 'Action') 6. Program Main Bath Motion Timer - Enabled If Status 'Main Bath Motion.1-Sensor' is Off And Program 'Main Bath Motion Timer Enable' is True Then Wait 4 minutes Set 'Main Bath Lights' Off Else - No Actions - (To add one, press 'Action') 7. Program Main Bath Motion Timer Enable - NOT Enabled If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set Program 'Main Bath Motion Timer Enable' To Run At Startup Else Set Program 'Main Bath Motion Timer Enable' To Not Run At Startup Thanks Kev.
  • Create New...
