jmac
Everything posted by jmac
  1. Thx, but too late. I already repaired it with a cap replacement. Appears to work, but I'll just keep it as a spare....
  2. Thanks, all, for your help. Replaced PLM as other died after 2 years 2 months. Was able to restore system (after following procedures listed here in the Forum) by rebooting ISY and restoring each device individually. Took awhile, but all is well now. Michel - did a "Restore Modem", and after 2+ hours rebooted ISY, and did a restore on each device. No communication errors that I am aware of. Maybe I was impatient, but in spite of my blundering the system is now operational. Now I'll tackle the capacitor replacement on the old PLM, for a spare......thanks again!
  3. All right - guess I'll post again tomorrow. Didn't know the amount of time involved - if it were days, or weeks, or whatever for a "Restore". And I'm not trying to be sarcastic, I truly appreciate the help. Probably my weak understanding of the procedure, but I am trying to follow everyone else's triumphs and tragedies.
  4. Ok, let me get on this merry go round..... Just replaced my PLM and repowered the ISY and it has been about 30 minutes of "busy" (red flag - lower left). I had already configured the battery devices for a future "manual write". How long can I anticipate a wait, or should I start some other action here to regain my automation?
  5. jmac posted a topic in ISY994
    All of a sudden I have noticed many many status updates on several units in the Log. Most are related to a motion sensor at a time when no motion should be detected. Also several X10 messages are sent when not requested. My PLM is at that magical two-year life span. Should I just go ahead and change the capacitors, which I have on hand, at this time? Or do I have some other problem? Everything else is working smoothly, with no phantom activations.
  6. jmac replied to jmac's topic in ISY994
    Please disregard the above - eliminated a "Network Resource" that was creating the problem. All is well now.
  7. jmac posted a topic in ISY994
    Just tried a backup and procedure won't proceed past about 51%. I get the following messages "Could not create the Zip File", and "Could not retrieve File /CONF/NET/1.RES". Destination is a flash drive, but the same hapens with any other destination. I have made many backups and never had this happen. Does any one have a clue what my problem might be? Thanks.
  8. I use Mobilinc. Use only Insteon devices for the most part. Very few X10, no z-wave. I like Mobilinc. Some of my notifications are a bit late at times, but that's a fault of my cell phone coverage promarily, I think.
  9. Having trouble getting this one to work with my ISY. I believe the sensor might not be operating correctly. I turned the potentiometer dial all the way to the right and set at approximately 40 degrees F. to turn on a space heater. However, on placing the sensor in the freezer (for a quick test) the sensor is not triggered and the On/Off module is not turning on per the programmed ISY. Noticed that on "Query" (under "Options" , "Device Options" on the ISY) that the "Trigger Reverse" is checked. Could that have something to do with the fact the On/Off module is not being turned on? Forgot to mention that I am using this with an I/O unit....
  10. I use the MINOTAUR ENGINEERING IFD1 PRECISION FREEZE DETECTOR as sold here at SmartHome. Assume it's working, as I have had no alarms. Routed the sensor wire through the drain line in bottom of freezer, as routing out side of door prevented a good door seal. Did get warning (program) when I defrosted the freezer.
  11. jmac replied to tommet's topic in ISY994
    At this point very little. A program for lights, attic fan, and notifications, and that is about it.
  12. jmac replied to tommet's topic in ISY994
    Thanks to all for your help. I rarely have a problem, but this one totally confused me.....appreciate it!
  13. jmac replied to tommet's topic in ISY994
    CO - Off Clear - <Blank> Low Bat - Off Malfunction - Off Smoke - Off Test - Off Unknown Message - Off This is now the current state of the nodes (after tapping the Smoke Bridge button) - had to query two to go from "On" to an "Off", and query another to go from a <blank> to "Off". Does THIS look appropriate? I did unplug the PLM/ISY as suggested before I reinstalled the Smoke Bridge and paired it with the Smoke Detectors. I could post the Event Log, but it is somewhat lengthy.
  14. jmac replied to tommet's topic in ISY994
    I now only have the Test node functional - indicating "On" after the test. All other nodes blank.
  15. jmac replied to tommet's topic in ISY994
    4.2.18 - the latest
  16. jmac replied to tommet's topic in ISY994
    Thu 11/20/2014 09:27:51 AM : [iNST-SRX ] 02 50 23.4F.40 00.00.03 CB 11 00 LTONRR (00) Thu 11/20/2014 09:27:51 AM : [std-Group ] 23.4F.40-->Group=3, Max Hops=3, Hops Left=2 Thu 11/20/2014 09:27:51 AM : [D2D EVENT ] Event [23 4F 40 3] [DON] [0] uom=0 prec=-1 Thu 11/20/2014 09:27:51 AM : [ 23 4F 40 3] DON 0 Thu 11/20/2014 09:27:51 AM : [D2D EVENT ] Event [23 4F 40 3] [sT] [255] uom=0 prec=-1 Thu 11/20/2014 09:27:51 AM : [ 23 4F 40 3] ST 255 Thu 11/20/2014 09:27:51 AM : [iNST-SRX ] 02 50 23.4F.40 11.00.03 CB 06 00 (00) Thu 11/20/2014 09:27:51 AM : [std-Group ] 23.4F.40-->11.00.03, Max Hops=3, Hops Left=2 Thu 11/20/2014 09:27:51 AM : [iNST-INFO ] Previous message ignored. Thu 11/20/2014 09:28:03 AM : [iNST-SRX ] 02 50 23.4F.40 00.00.03 CB 11 00 LTONRR (00) Thu 11/20/2014 09:28:03 AM : [std-Group ] 23.4F.40-->Group=3, Max Hops=3, Hops Left=2 Thu 11/20/2014 09:28:03 AM : [D2D EVENT ] Event [23 4F 40 3] [DON] [0] uom=0 prec=-1 Thu 11/20/2014 09:28:03 AM : [ 23 4F 40 3] DON 0 Thu 11/20/2014 09:28:03 AM : [iNST-SRX ] 02 50 23.4F.40 11.00.03 CB 06 00 (00) Thu 11/20/2014 09:28:03 AM : [std-Group ] 23.4F.40-->11.00.03, Max Hops=3, Hops Left=2 Thu 11/20/2014 09:28:03 AM : [iNST-INFO ] Previous message ignored. This was the result of the Event Log entry. Does this appear normal?
  17. jmac replied to tommet's topic in ISY994
    If I go through the test mode, press and hold Smoke Bridge setbutton until flashing, test smoke alarm (smoke bridge led turns red until smoke alarm tests complete) resulting in "Smoke Bridge-Test" "On". This can be reset to "Off" with a Query. The "Smoke Bridge-Smoke" stays blank. I have tried moving the alarms closer to the Smoke Bridge, but it makes no difference - same result.
  18. jmac replied to tommet's topic in ISY994
    I was just looking at my seven nodes and the Smoke Bridge-Smoke node is blank. I'm sure at one time it indicated "Off", but not any more. I have done a factory reset and paired with the two First Alert smoke detectors but the node remains blank. Shouldn't the state of the node either indicate "On" or "Off"?
  19. jmac posted a topic in ISY994
    Is there any way to download and view the "Comments" entered in my program list? Or produce a list of the created programs? That would be useful to me personally.....
  20. Is this true? Does the Query program cause network disconnections? Maybe that's why I cannot get my WF2IR (Global Cache device) to maintain connection over night. ???!!!
  21. jmac replied to jmac's topic in ISY994
    Disregard. I found that reverting to iLearn version 2.4 would solve any problems that I was having. Thanks, guedesluz!
  22. Thanks, guedesluz! iLearn2.4 solved my problem. Left the Capture Options as is and captured the On/Off for my TV, trimmed, named, and tested the SendIR button. Success the first time - the TV could be turned On/Off with this button. Then to the ISY Resource Editor where I pasted the TVON code, along with ",\r,\n". I then tested with the Test button at the bottom of the Configuration page and got "CompleteIR,1:1,1" along with an Off for the TV. I truly appreciate the help!
  23. It seems we have similar problems. I know that the signal reaches the WF2IR as the green light above the connector flashes, but no action with the TV. Since others have had problems with the appended "\r\n" and/or "r\l", with and without commas, I thought that might have something to do with the problem. We need a little more guidance here.
  24. Can anyone enlighten me on the appended letters added to the IR string? I can't seem to get my gear to respond to IR codes sent by the WF2IR. Also, does the "Send IR' button actually work in your system?
  25. jmac posted a topic in ISY994
    Went through all the info under "Global Cache WF21R Works", and am unable to use the ISY Resource Editor to send the proper code for unit activation. Can anyone enlighten me on the appended IR codes?
