Big517
  1. For those unsure of how to Link the devices for this. Go To: https://my.isy.io/index.htm Click on Tools: Amazon Echo Then choose from the following: Device | Scene | Program Then select the device and type in the "Spoken Name" you expect to ask Alexa to control. I can't wait to get home and play with this! Thanks Michel!
  2. Chuck, that link above is exactly what I purchased. You need a monitor for initial setup, however afterwards it runs headless and you can use Putty to update your rc file, and WinSCP to update files, both softwares run from your windows pc. Sent from my SM-G900V using Tapatalk
  3. I too have a windows server running 24/7 mainly for Plex. Ended up buying my first RPi because of the same issues you probably ran into. Just spend the $60 and you may find yourself porting some of your windows stuff over. Good investment, most importantly it works . Sent from my SM-G900V using Tapatalk
  4. Thank you for the update! Sent from my SM-G900V using Tapatalk
  5. I have noticed that I cannot "TURN ON" a dimmable light.. I have to say "Alexa "brighten" device"
  6. I completely understand that which is why I'm posting this... The strange part is when the first line was un-commented it did not work.. .only until I used the same server on line 2 uncommented did it work. DID NOT WORK 192.168.X.X:8080-ISY '192.168.X.X:8080-ISY '192.168.X.X:8083-SERVER3 '192.168.X.X:8084-SERVER4 WORKED '192.168.X.X:8080-ISY 192.168.X.X:8080-ISY '192.168.X.X:8083-SERVER3 '192.168.X.X:8084-SERVER4 Seemed strange, but might be a small bug..
  7. Not sure if anyone else had this, but I was pulling my hair out for an entire day trying to get Barry's software to pick up the Server... In the config file there are 4 server lines... for some reason after updating the software it would ONLY find whatever server was on LINE 2 of the server lists! I copied exactly what was showing on line 1 to line 2 '192.168.X.X:8080-ISY 192.168.X.X:8080-ISY '192.168.X.X:8083-SERVER3 '192.168.X.X:8084-SERVER4 I assume I did something wrong, but this fixed it and allowed Barry's software to FIND my server... You can also test if your server is running by pulling it up in the browser as 192.168.x.x:8080
  8. Plan on calling it Izzy for the native integration with echo. If you install and setup the Hue Emulator route you can do basic on/off commands for your lights and really anything else in your home that is controllable via REST or HTTP requests! So there will be 2 types of control respectively; "Alexa, tell Izzy to lock/unlock/set cooling/heating arm/disamrm" etc... And with the Emulator "Alexa turn on/off the (any device name)" BTW the Arm / Disarm command was just a guess since the skill is not complete, or it has not been fully disclosed by the UDI team yet.
  9. What is the friendly name for this in BarryGordans software? I was under there impression it had to on/off or 0-100. Does this mean its possible to say "Lock the front door" or "Close the garage door"? Sent from my SM-G900V using Tapatalk
  10. UP AND RUNNING! currently on BWS 1.1.0. I'm going to add the Harmony later since it's being delivered today and will visit on that later, but I'm curious about a few things regarding the voice commands and how the the dimming works... When I said "Alexa turn chandelier to 50%" it wouldn't work, but it did work when I said 20%... Then I looked at the URL being sent thanks to @BarryGordon's awesome piece of software, and I noticed this: ${intensity.byte}. I'm having a little bit of trouble getting the chandelier on (dimmable device) but NOT with the on/off switches... Should I change this to "Intensity.percent" to get the expected response when I say "Set brightness to 90 percent" for example?
  11. Suggestive/subliminal marketing!?
  12. I am interested in ceiling mount as well. Although I have a vaulted ceiling in that room I'm wondering if I placed it at the peak if it would affect the acoustics and help or hurt the mic picking up people speaking Sent from my SM-G900V using Tapatalk
  13. I thought you ALWAYS has to say the wake word before giving a command... So are you saying with the BWS or Jimbo's emulator you can simply say "turn the tv off" and it will work?!
  14. From what I can tell this recent issue is ONLY applicable to your rpi running a more than one instance of BWS' server correct? I'll be installing tonight, and want to minimize issues so i'll be sure to run a single instance, and from what I read somewhere it will cap out a 46 devices... that should get my living room and kitchen running
  15. Does that mean after this next submission it will also be reviewed sooner than the typical 10 days since they are assisting you directly? It's awesome you will be able to actually talk with them to get real time feedback. Sent from my SM-G900V using Tapatalk
