Spontaneous garage remote lockout
In my case, I already had a single wire into the Liftmaster, from the Ratdgo. the 880LM was wired into the Ratdgo in pass through mode. My problem was false, spontaneous "lock" signals. This was confirmed because the 800LM would display "locked." The question is whether the spurious lock signal came from the 880LM, which is 12 years old, or the ratdgo itself. I disconnected the 880LM completely. At this point, I only have the ratdgo and wireless remotes communicating with my Liftmaster. It's been four days and I have not had a recurrence of the problem. My plan for now is to live with only wireless remotes plus the ratdgo. It that proves to be a problem, I'll install a new wired controller in pass through mode to the ratdgo. I am tossing the old 880LM. I am also trying to add the ratdgo "lock" control to my Home Assistant instance, but am having some difficulty. I can see the control in the ratdgo ESPHome instance and control it from my HA dashboard, but when I add it to HomeKit, it does not appear in HomeKit.
I seem to be experiencing this same symptom now. As a test, I have disconnected my 880LM completely and will see what happens. Did you ever track down a diagnosis or solution @SHM ?
maxnorth started following Protection Against Device Failures , Spontaneous garage remote lockout , Not Seeing elk-m1 zone status and 4 others
My recollection is that the IP for the M1xep is set in the Elk settings. I use ElkRP software for that. It is located in the Account Details tab.
.yaml file location
# Store in /usr/home/admin/ # No SSH required, Command to copy file FROM cd current directory (e.g., Mac desktop) to eisy # Replace with your own IP and user name and dev file name scp 2025-10-10-devfile.yaml admin@10.20.30.xxx:/usr/home/admin/
Programming help please
I believe the best approach is to create a scene including your relay. Then use programs to have the scene turned on and off (including by the KPL). For the light on the KPL button, that is another story. Create another scene including the KPL button. In the program controlling the relay, add an entry to turn off the KPL button scene when the relay is turned off.
Elk node issues recently
I, too, would like to know if there is anything in process to fix the Elk problems related to the upgrade. I am holding off on the upgrade to 6/7 until this is more stable. I am unclear if this is a node server issue or something else. Clarification on that would be helpful.
I don't live in an area affected by lightening, but we do have periodic power outages during the winter months. I had several Insteon devices fried during outages like this. After installing a single whole house suppressor, I have not had any.
Time server for Elk M1XEP
I have used darwin.kenyonralph.com successfully.
Sonoff S31POW polling interval
Ah, yes, "TelePeriod 20" does in fact set this to 20 seconds. Nice to be able to set this on a per-device basis! Thank you!
I am wanting to work with the power readings thrown off by the S31POW. I notice that polyglot seems to retrieve these readings using some sort of polling. They only update every three minutes (per the log). Not very helpful when you have an application needing more frequent readings. The Sonoff itself updates immediately, it's just that Polyglot does not get the updates promptly. Is there a setting somewhere that this can be changed?
MQTT message payloads
You don't really send commands to sensors. Here is a screenshot from a Tasmota device console for a switch. If you have a more specific question, let us know. In this case my "status topic" configured in Polyglot is "stat/sSlamphC/POWER"
Room Off button
I always use a program to control the LED status, and I have the button set to non-toggle off. Pressing the button turns everything off.
Sonoff TH Origin (16A) with THS01 (SI7021) sensor
To answer my own question, the correct type to use is "TempHumid." This is working now. It might be helpful to update the configuration help to list the SI7201 sensor as an acceptable sensor for TempHumid.
Find the MQTT Broker
I believe that if you then want to set up the S31 as a switch, you would create a second device for that, using "switch" type.
I can't figure out what node server yaml entry to use for this setup. I tried the types "analog" and "Temp", but the resulting node device does not show any temps. My tasmota config identifies the Sonoff THS01 temp/humid sensor as a SI7021, and that config is working fine in the Tasmota web setup. It show readings. I am using "SI7021" in the node server as the sensor ID. From the Tasmota web console: "18:08:48.992 MQT: tele/sSonoff_THR316/SENSOR = {"Time":"2025-05-18T18:08:48","SI7021":{"Temperature":68.7,"Humidity":51.3,"DewPoint":50.0},"TempUnit":"F"} I also have a "switch" device for the TH Origin. It is working fine in the node server and the switch device appears in order after the sensor device. Below is an example: - id: "sSonoff_THR316Sens" type: "Temp" name: "AtticSwTemp_145" sensor_id: "SI7021" status_topic: "tele/sSonoff_THR316/SENSOR" cmd_topic: "cmnd/sSonoff_THR316/power" - id: "sSonoff_THR316" type: "switch" name: "AtticSw_145" status_topic: "stat/sSonoff_THR316/POWER" cmd_topic: "cmnd/sSonoff_THR316/power"
maxnorth
Joined
Last visited
