brain shocker
Everything posted by brain shocker
  1. So about a month ago I was having the exact same issue with Bell Canada. Every time I called Bell half the people I talked to didn't even have a clue what I was talking about. I was even told that Bell didn't offer email to text service even though I had been using it for 5 years. So I requested a service ticket be created for the issue and about a week later I received a call from Bell Canada saying the issue was resolved and everything has worked fine since. All I was told was some settings had been changed on their end. Sent from my SM-G920W8 using Tapatalk
  2. Do you still have to pay for a dynamic dns service to get a ddns name or is everything done through your router? Sent from my SM-G920W8 using Tapatalk
  3. What do you mean by set up properly? I thought it was because it's been working fine except when the ip changes. I have LAN and port forwarded. Sent from my SM-G920W8 using Tapatalk
  4. My ISP (Bell) frequently changes my ip address so I lose communication to my ISY via Mobilinc. If I purchase the ISY Portal will this eliminate the issue? Sent from my SM-G920W8 using Tapatalk
  5. Paul That's awesome thanks so much. I still have to purchase the module but now that I know Munro can be used I'll be getting it tonight. Peter ( brain shocker is my screen name....I'm an electrian) Sent from my SM-G920W8 using Tapatalk
  6. Can anyone tell me with the climate module can you only use the weather stations that are listed or can you manually enter a weather station id that is not listed? Sent from my SM-G920W8 using Tapatalk
  7. I was hoping Munro would be listed since it's an international airport and only a few minutes from my home...bummer Sent from my SM-G920W8 using Tapatalk
  8. Thanks, I didn't even think about checking wiki for info. I think Climate module opens a lot more doors and I'm heading that way... Sent from my SM-G920W8 using Tapatalk
  9. I would like to adjust my HVAC according to temp. Also be able to switch my HRV on and off according to temp. Sent from my SM-G920W8 using Tapatalk
  10. I assume the climate module also gives other values besides temp? Humidity, wind, pressure etc.? Sent from my SM-G920W8 using Tapatalk
  11. I would like to use outdoor temperatures in some programs but not sure what's the best way to get the temp. Can someone recommend an outdoor sensor or is the climate module a better way to go? My ISY has the zwave add on. Thanks Sent from my SM-G920W8 using Tapatalk
  12. I have also purchased all my insteon devices and security equipment from Aartech and their customer support is excellent not to mention how fast they ship. Would definitely recommend them. Sent from my SM-G920W8 using Tapatalk
  13. Thanks guys I will try these out. It sounded simple in my head just couldn't get it on paper Sent from my SM-G920W8 using Tapatalk
  14. Sorry just my wording scene on at 6:30 , scene off at 7:30 Sent from my SM-G920W8 using Tapatalk
  15. Yes I need the scenes to only run between 6:30 and 7:30. The only difference being if it's light outside a scene (summer) will run but if it's dark outside scene (winter) will run Sent from my SM-G920W8 using Tapatalk
  16. I will have to post it later today when I have my laptop
  17. Need some help with programs to run a scene(winter) from 6:30 to 7:30 before sunrise but if it is after sunrise I need scene(summer) to run from 6:30 to 7:30. Please excuse the wording I don't have the program in front of me Program 1: If before sunrise -10 minutes and mon, tues, wed, thurs, fri 6:30 - 7:30 Then run scene winter Else stop scene winter Program 2: If after sunrise +10 minutes and mon, tues, wed, thurs, fri 6:30 - 7:30 Then run scene summer Else stop scene summer I know its simple but I can't get it to work any help would be appreciated. TIA
  18. So I removed the batteries, waited 5 seconds, re-installed the same batteries and communication is back
  19. 4.2.7 and Z-wave firmware most recent loaded. Not sure if it would make much of a difference with 4.2.8
  20. No lock still operates
  21. I have added Z-Wave to my ISY994 with external antenna, added a Kwikset lock and everything has been working fine for a couple of months. Just recently I have a red exclamation beside the Kwikset node and have lost communication. I have tried to query the lock but that did not work, tried sync, and heal but cannot re-establish communication. Do I need to exclude the lock? Will this affect the programs that use the lock when I add it back?
  22. Tried the code works great, I decided to use it for a couple different areas were I want the lights to come ON instantly but OFF slowly for the effect. Thanks for everyone's help
  23. I think the easiest thing is to go to halogen bulbs then no problems with ramp rate Sent from my SGH-I747M using Tapatalk
  24. Yes slow ramp ON and slow ramp OFF. OFF works ok its the ON that is the problem. They blink ON OFF before they reach full. Sent from my SGH-I747M using Tapatalk
  25. Thanks for the info. Guess I'll having to try a couple different types till I find the right ones Sent from my SGH-I747M using Tapatalk
