f.demello
  • Posts
    55
Everything posted by f.demello
  1. Perfect MrBill. Thank you
  2. I'm sorry - I stated this wrong. My problem is when I switched to Verizon from AT&T. Would the same logic apply? [10digit]@mms.verizon.net. Currently using [10digit]@vtext.com per the program drop down for Verizon text
  3. Thanks MrBill - will try that this weekend
  4. Hello - I use the Leak Sensor program listed in these pages and used to get full texts from events when with Verizon. I switched to AT&T and now my texts are truncated so I don't see the entire message. I changed the text parameters to AT&T Has anyone else seen this?
  5. Is there a simple way to check each device one at a time? I have some Remote Linc's as well. How do I know for sure each device is working? Thank you
  6. Seems like some of the sensors are working now. I'll work on the one's not communicating. Link cont being 0 doesn't make sense though
  7. Maybe I'm not doing it right but I am still getting a load count of 0 with the new PLM. Is it normal to go Tools/Diagnostics/Show Device Links and the system ask to select a device. I thought this reported all devices linked to the PLM? Seems difficult to get every batter device into programming mode at the same time. How do I test each device individually? Thank you
  8. Thank you. Will do
  9. PLM blue light on. Rx flashing blue Note: I recently unplugged the PLM/ISY and plugged back in from something I saw on the internet. Still getting a 0 count.
  10. Definitely > 2.5 years
  11. Sorry for the delay. Put all the battery devices in programming mode. Ran through Restore Modem. Count is still 0. Is the ISY dead in the water?
  12. I don't have that many devices. When I run the PLM Link Table it is coming up with 0. Very frustrating
  13. I worked perfectly for 2 years where it is currently. My leak sensor programs do have the heartbeat program but I don't in my 2 open/close sensors (although I just changed both batteries)
  14. Ran the If/Then statements and I received the text. I had just changed the batteries in the sensor. Do these sensors die? Not that old (1-2 years). I also suspect all my leak sensors are not working as well (have 7). Will have to test
  15. Got it. Both 4.5.1 Enabled = ON
  16. This is a simple open close program (2 parts) that worked for years: Shed Timer - [iD 0014][Parent 0001] If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Send Notification to 'Frank' content 'Door Activation' Send Notification to 'Abby' content 'Door Activation' Wait 5 minutes Else - No Actions - (To add one, press 'Action') ---------------------------------------- Shed Trigger - [iD 0015][Parent 0001] If Status 'Open-Close / Shed-Opened' is On Then Run Program 'Shed Timer' (If) Else - No Actions - (To add one, press 'Action') Thank you
  17. Will do. Updated the UI on 7/9. ISY Firmware 4.5.1. Not sure how to double check the UI version
  18. I am getting texts. I did notice my text group was set to regular e-mail all of a sudden (didn't set it up that way). But just did a test of one of the open/close sensors and it did not send anything. if you look at the screenshot I am not getting any of the daily runs I used to. What would cause all of them to stop? Thank you
  19. Not sure what has happened but in the last 3 months I have been getting no texts on triggers from various open/close & leak sensors. I changed some of the batteries and upgraded to 4.5.1 but still the same (see screenshot). Nothing has changed in my programs. I have no idea where to even start. Any help will be greatly appreciated
  20. Does anyone have a simple program to trigger an e-mail/text when the sensor is triggered? Including a daily battery check. Thank you
  21. Thank you!!
  22. Sorry about that. I had just updated the firmware to 4.2.18. My previous console looked more like the Wiki content
  23. Can someone point me in the right direction on how to edit programs in the new console? For some reason I cannot figure out how to access them. I have attached what my program looks like. I am on ver 4.2.18. It is very different from the previous version. I am on a MAC
  24. Looks like this was related to my SMTP setup (which I added after viewing the UD tutorial). Did not like it. Once I went back to the default settings the e-mails/texts and leak detection is working fine
  • Create New...
