Sparks
  1. Sparks replied to MarkJames's topic in ELK
    Yeah - sorry. I didn't read the question - my bad! I will try to capture some more data from PG3 and EISY this weekend and post back.
  2. Sparks replied to MarkJames's topic in ELK
    So I looked at the event log. Zone 3 is the door contact. 20 8B 6B is the light. Zone 3 logical state changes 2 seconds before the physical state GV0 and the DON and of course before the light turns on. The 2 seconds appears to be repeatable. I tried using the logical state and the control trigger in the program but it makes no difference. The delay between the door and the light seems longer than 2 seconds but the log won't lie. (Ignore Zone 8 - that's other activity in the house) Any ideas?
  3. Sparks replied to MarkJames's topic in ELK
    Yeah - I agree I need to look at logs. Just checking if this was a noted problem, or not. It is odd. We are all seeing new "issues" after changing to EISY as ISY was so solid. That's the Home Automation World for you!
  4. Sparks replied to MarkJames's topic in ELK
    Just replicated the program in Home Assistant (ELK addin + UDI Insteon) and the lights turns on before I even opened the door fully - this cannot be right. The light is an Insteon scene though EISY so my only conclusion is this is somthing wrong with Polyglot.
  5. Sparks replied to MarkJames's topic in ELK
    So I did a quick search of the forums and found this thread. I have a similar problem - ISY with the Elk integration and the response was within a second. Now with EISY and the ELK Poly, it is like 2-3 seconds to trun on a ligh with EXACTLY the same program as before. EISY is supposed to be faster. Polyglot is supposed to be better and more robust, has more features and all. But if the basic functionality means we have a 2-3 second delay ... then we seem to be going backwards. Is there any reason you can think of .. .anything I can check in the logs. I did try changing from Status->Violated (as it always was with ISY) to Control->On but it makes no difference whatsoever.
  6. Sparks replied to Sparks's topic in eisy
    Thanks for the feedback folks. It hasn't reached egg frying temperature so I guess running warm is normal.
  7. Sparks posted a topic in eisy
    I appreciate the body of the EISY is a heatsink but what is considered the "normal" surface temperature of EISY. Mine is almost uncomfortable to pick up and a quick measure shows it at about 45C. It is only running the standard UDI packages of Insteon plus a few Poly's - nothing extra. Just concerned that running hot 24/7 will affect lifespan.
  8. I looked in the logs and nothing obvious appears relating to the store. I did see some store dumps in the logs and it is clear that the trial option is not there for Bond. So I can't explain it, and I don't want to waste any more of your time, or my own. I'll decide if I want to use Bond, I'll just buy it and hope it works. Thanks for your help.
  9. Something weird happened in the Node Server store - I selected the Bond trial but it actually purchased the MyQ trial. Now the Bond trial option has disappeared but an option to install the MyQ trial is active. There is no way back, it seems. Is there something wrong with the setup of the Poly's? Other people must have installed this Node Server already. This happened on a brand new fully updated EISY/PG3X system. I put in a ticket to UDI, but Michel pointed me to the developer for support.
  10. OK so weird thing - I rebooted via the admin console - no luck, failed authorization every time. Rebooted via the power cord (yes, a bad idea, but desperate times and all that) and PG3 allows me to login again. Apparently I'm still on 3.1.26 despite trying the "update packages" via the IOX admin page but looking at the changelog then nothing seems to have addressed this particular issue. I'll see how it goes, but certainly something strange afoot. I'll also try the power button single push but as this should just call the same routine as doin it from the admin page, I'm not hoping for miracles. So for now, I can login, but if I get locked out again I'll put in a ticket (because a hard power rest isn't really a solution) and see if there is anthing more I can help the developers to troubleshoot.
  11. Just when I thought I was out of the woods ... back to the PG3X login failures again. I have seen other people having similar issues with various fixes suggested such as : upgrade to latest PG3x, restart the EISY and wait ...and hope. To be honest, this has been a problem from the very first bootup of a new EISY, fresh out of the box this week, fully updated to the latest everything (5.6.0 and 3.1.26), original admin/admin username/password (not changed). I see there may be a new PG3X 3.1.27 available, but then I can't login to check. I am getting the red box at the bottom of the PG3 login screen: HTTP failure response for https://eisy.local:3000/auth:401 Unauthorized. I found the Poly log using SSH ... in /var/polyglot/pg3/logs and it says : 5/24/2023, 14:35:53 [pg3] info: call_udx: Making reqeust to socket for /rest/pg3.auth.ns 5/24/2023, 14:35:53 [pg3] debug: call_udx: sending {"username":"admin","password":"admin"} 5/24/2023, 14:35:53 [pg3] info: call_udx: /rest/pg3.auth.ns on socket happened. 5/24/2023, 14:35:53 [pg3] error: call_udx: Request failed :: Error: connect ECONNREFUSED /tmp/udx2client261892 5/24/2023, 14:35:53 [pg3] info: UDXauth: {"success": false} 5/24/2023, 14:35:53 [pg3] error: UDX says we failed to authenticate admin: false 5/24/2023, 14:35:53 [pg3] info: call_udx: /rest/pg3.auth.ns on close happened. 5/24/2023, 14:35:53 [pg3] debug: call_udx: Wrote body data to socket Tried rebooting. Tried power cycling. I did get in once from one computer and was able to play around installing some nodeservers, etc. But then I had to logout and now cannot get back in again. I cannot believe the solution is to keep power cycling the EISY - the last thing you want to do with an automation controller is keep cycling power. There is obviously some issue here - it shouldn't be so fickle. And did the usual geek things - multiple computers, multiple browsers, no change. Any other ideas before I annoy the UDI team with another ticket - I think I reached my quota already!
  12. ELK function keys now work, but I had to edit the relevant program entries because they mysteriously changed after the upgrade.
  13. Looks like installing the firmware and ELK module does monkey around with the X10-esque addressing between ISY and ELK. All my lights are working incorrectly with ELK rules now. I have had to "add" all devices in the "export" tab of the new Security system module to assign X10 addresses, then export to XML, import XML to ELK lighting module, and then edit all the ELK rules because most of the addressing changed. It's worth it to get the long-awaited ISY functionality, but seems like a bug as all previous firmware upgrades have always managed to preserve the ELK X10 addressing. I'll be moving all my ELK rules to ISY now anyways. Thank you Michel and the ISY team! It's been a most anticipated upgrade.
  14. There is a little info in the Wiki on using the GC100 with the ISY, but it is limited to the raly outputs on the GC100. The ITach uses the same command format as the GC100, but allows you to learn IR commands out of the box which the GC100 did not. The procedure for using Global-Cache and ISY requires you to learn the IR codes first using the Global-Cache iLearn software (see documentation on their website), then copy and pasting this command string into the ISY network module (which you need to purchase, if you have not already). The command structure looks something like: sendir,1:1,45234,34500,4,3,34,48,24,12,24,960 I have a GC100 and it works like a charm with the ISY once you have it all set up. If you have not already gotten the hang of the Global-Cache software to give you a command string like the above, then tackle this first, then move onto the ISY network module.
  15. The biggest challenge I had with my GC-100 was learning the IR codes because the original GC-100 did not have a built-in IR receiver/learner. I had to buy the Global Cache IR learner (plugs inot a serial port) in conjunction with it's software. Looks like the new models have addressed this omission, but you will need software to generate the string to send. Once you have the correct string to send to the unit to generate your IR code of choice, and there are utilities from Global Cache to test these, then the ISY network module is very easy to get working.
