AT&T to end email-to-text ×
tsolve
  • Posts
    19
Everything posted by tsolve
  1. tsolve
    80009 error
    Michel - Thanks. Better than that, I fixed the router config!
  2. tsolve
    80009 error
    I just happened to look at my Error Log today, and I noticed that there were thousands (20k+) of 80009 Error messages. I looked up the code, but it means nothing to me: -80009 IGD FAILED STRIPPING HTTP HEADERS Can someone tell me what this means, and do I have a problem? Thu 2013/05/23 04:03:44 PM System -80009 n/a Thu 2013/05/23 04:03:52 PM System -80009 n/a Thu 2013/05/23 04:03:52 PM System -80009 n/a Thu 2013/05/23 04:04:00 PM System -80009 n/a Thu 2013/05/23 04:04:00 PM System -80009 n/a Thu 2013/05/23 04:04:09 PM System -80009 n/a Thu 2013/05/23 04:04:09 PM System -80009 n/a Thu 2013/05/23 04:04:17 PM System -80009 n/a Thanks, Steve
  3. Doh! I figured it out. Turns out I must have linked it to the ISY in a mode where it ignored those buttons (4 scene?). When I looked at the ISY link table there were only links for the 6 buttons. So all I had to do was remove it from the ISY, the re-link it. Viola, it works now - all 8 buttons! Thanks for the clue on the link table, that's what mae me go look there.
  4. Actually, there should be no links, as I dd a factory reset and have not done any linking with it, but I will try this.
  5. I have a Remote Linc 2 (2444) and it appears (to me at least) that the bottom 2 buttons don't work. I have set the device in 8 button non-toggle mode, and when i press any of the other 6 buttons (a-f) i can see in the event viewer a message like : [ 1C 20 BD 3] DON 0,but when i press g or h, nothing. The led on the device flashes green, however so I know I have actually pressed the button. Is this a device issue, or something else?
  6. tsolve
    Run-Then Problem
    OK, so is this a known issue/problem? Is there a workaround - other than setting the folder to true (not easy if nested 2-3 folders), or moving the pgm out of the folder (a pain, cause then you need to remember to move it back)? Thanks, Steve
  7. tsolve
    Run-Then Problem
    Perhaps I was unclear - what I meant was from the administrative Console, if I right click on a program in the Program Summary tab and choose Run Then, I expect the Then clause to run - period (testing), but if the program is under a folder that is False, it does not.
  8. tsolve
    Run-Then Problem
    I did some testing and came to the following conclusion - If a program is inside a folder, and the Folder Status is FALSE, Run Then does NOT work!!!!!!
  9. tsolve
    Run-Then Problem
    I too have a problem with Run Then not working. I am on vsn 2.7.15 On a certain pgm if I do a Run Then, All I get in the Event Viewer is: Sun 07/25/2010 12:37:15 AM : [ Time] 00:37:14 0(0) Here is my pgm: If Folder 'Motzei Shabbos' is True And Folder 'Yom Tov 1' is False And Time is Sunset + 45 minutes Then Set 'Dishwasher' On Set 'Stove' On Set 'Basement Shabbos Relay' Off Set 'Bookcase' Off Set 'Basement Sh Lights' Off Else - No Actions - (To add one, press 'Action')
  • Create New...
