DreamerI90
  1. I could be mistaken but that is what I recall. The PG3 dashboard looked normal, I seem to remember even going into the nodes to look for devices. At first I was resetting the nodes servers individually, but then I figured out I only needed to reboot the eisy. Do you want me to do any specific tests?
  2. They eisy does not connect to the node servers. The nodes still seem connected to their devices.
  3. I think I found a solution and did a couple tests to confirm. Hoping it proves out next time I have a power failure. What I came up with was an appliance surge protector with a delayed start of 3, 5, or 7 minutes. I used 5 and it seems to work. This way IoX doesn't start up before my internet access has resumed.
  4. Pretty sure it's a timing thing but don't know how to change it. I'm just trying to make the system more resilient/fault tolerant. I had a new one this week, but I didn't notice a power outage. The system was running, and Polyglots were working but the mobile app was down. It turned out the system was no longer connected to the portal, after a reboot it reconnected.
  5. It's always done this as long as I recall, I'm just trying to resolve it. It's not usually a big deal, but there are times when it could be.
  6. So I had another power outage, this time the eisy restarted but did not connect to the portal. I was able to access it using isy finder and LAN admin. The Polyglots had also not reconnected, but the interesting thing is that when I rebooted the eisy from the admin console not only did it reconnect to the portal but the Polyglots connected too. Usually, I have to restart them individually from the PG3 console.
  7. ************ IoX ************ isy-5.9.1_7 Name : isy Version : 5.9.1_7 Installed on : Sun Mar 2 13:15:02 2025 PST Origin : misc/isy Architecture : FreeBSD:14:amd64 Prefix : /usr/local Categories : misc Licenses : Maintainer : michel@universal-devices.com WWW : UNKNOWN Comment : ISY Port to X (IoX) ************ pg3x ************ pg3x-3.3.18 Name : pg3x Version : 3.3.18 Installed on : Sun Mar 2 13:15:18 2025 PST Origin : misc/pg3x Architecture : FreeBSD:14:amd64 Prefix : /usr/local Categories : misc Licenses : MIT Maintainer : benoit@universal-devices.com WWW : https://github.com/UniversalDevicesInc/pg3 Comment : Polyglot PG3x for UDI eisy
  8. After a power failure my PG3x Polyglots have to be restarted to resume working: Notifications Hue lights Ring Bond/Somfy Nu Heat Is there a way to resolve this issue so that manual intervention is not required after an outage?
  9. As hard as MK and I worked on it after an upgrade it was dead. I was told there were imaged SSDs but not available at the time so I upgraded to an eISY. Now I want to replace an iSY994 for a low demand application. Can I resurrect the Polisy Pro? Are the plug and play SSDs available again? Can I re-image the current one?
  10. My sunset/sunrise times are correct for my PST location
  11. I got up this morning and all my programs were disabled also. DST clock change was last night but maybe a coincidence? I'm currently on 5.7.0, eisy, iOX, PG3x, using Insteon and Zwave. The system status looks like it hasn't been restarted for a couple days so it doesn't look related to an update or restart. I don't remember this ever happening before and I've been using UDI for maybe 15 years. Then and else will run manually and when I renable the programs they seem to work again. Does anyone know what might have happened?
  12. Thank so much for the help! I didn't even have to restore, as soon as it powered back up, it reported temp. Go figure. They're all reporting temp now, a couple are not reporting everything but I don't need them too and I think your tips will help!
  13. Both UI and firmware are 5.6.2 Device links table matches/is identical to iSY links for the three devices that were reporting everything but temperature. Strangely, accessing and comparing the link tables resolved the issue with 2 of the three now reporting temperature. Tried deleting, defaulting, re-linking, and resetting the one that still isn't working. Tables match but still no temp.
  14. I've got a half a dozen 2441ZTH that I use to monitor temperatures around the house, in my camper, etc. They were all working fine on my iSY but I cannot seem to get full functionality on the eiSY. They are v.0Ds and v.0Es, v1.2, 1.3, 1.5, 1.6s the results are mixed so it doesn't seem version dependent. One of them is reporting only temperature and humidity (a v.0E, v1.5). Three of them are reporting everything but temperature (v.0Es, and a v.0D). I tried querying, waiting for days, making them hotter or colder to change the sensed temperature, relinking, factory resetting then relinking, etc. They are all near or have been near to dual band devices. They are mostly battery powered (Energizer Lithium), but one of the problem ones is AC powered. I've been trying to get these working for a couple of weeks now so it seems like time to ask for help
