62vetteefp
Everything posted by 62vetteefp
  1. Just got the new PLM and before I replaced it everything started working again. Here is the latest PLM links table. Seems back to normal.
  2. So I went to tools diagnostics PLM /info status and it did some kind of update. Is this a PLM restore? Still does not work.
  3. tried the links again and only the same two. So ordered a new PLM. Will see!! Thanks all!!!
  4. So both say 4.9.0 now and none of my switches will fast tap work. I did a restore switch after also.
  5. Just unplugged the PLM and plugged back in and then restore device the switch. Still not working.
  6. PLM 2413 S V2.2 1622 ISY UD 994 sn 0016279 Un plugging and replugging did not fix it.
  7. Is the bottom chart the link table you are asking for?
  8. Forgot to write that down. I did a restore on the switch in the program. Did not correct the issue.
  9. Noticed that one of my switches did not work with fast off and on. Tried another switch controlling other lights and also did not work. Reset the switch and still did not work. Setup a new fast off scene on a different switch and it did not work. Restore the device in the ISY software and it did not work. Ran tools-diagnostics-show device links table Have not revised anything recently in the system Can anyone see an issue from this? What next?
  10. Thanks. Basically the ATT router is used for wired devices (two laptops at their respective desk) and all the wifi runs off EERO extenders with the base one plugged into the ATT router. ATT router is mandatory with ATT fibre and I needed extenders for my long house. Have not tried it yet but if I try and access isy from a remote location will I be able to?
  11. Is this as simple as choosing Automatic (DHCP) under Network settings in the UD Network settings? and clearing the UPnP?
  12. I watched Steve Lees video on Port Forwarding and noticed my Gateway IP address (under Configuration/System) was not the same as my current router. Revised it to my ATT router and revised the DNS and saved and now my time is correct!! So I had two issues, one my laptop was on the separate EERO wireless system while the ISY was on the router. The other was my Gateway settings in the ISY console were wrong. Thanks everyone for the time and help.
  13. thanks! My ISY is connected to ATT modem thru a D-Link switch box. My Laptop is also connected to the same D-link switch box BUT I see that my laptop was actually set to the wireless eero system. I turned off the wifi on the laptop and now see isy and UID in the iox finder!! Windows 11 I go to my LAN console, login and see all my devices. I can activate my devices in the console. I have had my windows defender off for a couple hours. No VPN. online portal is same UID #. BUT the time is still off by 1.25 hours. In the Online portal it says ISY is not online. I think I did everything you said? It looks like my ISY is not going out to the outside timer server and the ISY Portal? This shows internet access disabled.
  14. .241/desc Not Found .71/desc Not Found .73/desc Not Found .240 Not Found
  15. Nope, same issue
  16. Here are my IP adress's on my network. None say ISY
  17. Do I need to get another year of Portal for me to be able to open the Launcher?
  18. Yes, but that is why I want to get in. Everything seems to work but my outside lights are coming on hours before sunset for some reason. Wanted to figure that out. I see you are right down the street from me! 13 and Lahser
  19. So I opened up the ATT router and there are four address's. None say isy. I tried to add all four and all came up with invalid URL..
  20. I logged into the ISY portal. says firmware 4.9.0 I do see that my license Expiry Date is expired last year. And my unit is expired. And I could buy a new year. SO, is the recommendation to upgrade to the new eisy?
  21. I did just completely uninstalled Java and installed latest from Java site. Still the same issue. No, do not know the software version.
  22. Thanks. I did follow the wiki before commenting. Opened JAVA as administrator by typing JAVA in the search box. Did click all 3 boxes in the settings cache clearing option. Also downloaded the latest link from the wiki and now from Techman's link above. I see now it shows IoX Finder: Not Found A new UD icon did show up on my desktop Same issue. What else can I try?
  23. Like the last guy been years and many computers later since I logged into ISY and used the programming feature. I updated Java and an icon is on my desktop. When I launch the icon the blue box comes up and says ISY Finder:Not Found. Below is a line with Name / URL / UUID with nothing in the cells below. At the bottom is the cancel add etc boxes. What do I do? thanks, Chris
