tosterhouse
  1. Ticket #23836
  2. I also need to restart my EISY almost weekly. it functions with my devices but not google or UD mobile. I put in a help ticket but they must not know how to fix yet
  3. EISY IoX v.5.7.0 I am trying to add ZSE11 motion sensors. They appear to include/install just fine. I see them active in the level 3 event viewer. I am trying to use them as control or status to turn on a light and nothing? All other Insteon and Z wave work just fine.
  4. I tried with no success
  5. These switches do have Scene modes. I am not sure how to utilize them?
  6. I will post tonight. Thank you for the responses!
  7. If I select the status the program will trigger with the motion sensors which will disable the programs intention. This program runs my garage lights. When we are under the car and no motion is sensed the lights turn off. This is why I was using the on switch to turn the garage lights on and it also then disabled the motion sensor program. I then press the off on the switch to turn the lights off and then re-enable the motion sensor program. This worked perfect with the Insteon switch.
  8. Yes, from the admin console I am able to turn the light on and off. The switch also displays on and off in the admin console when I press the physical switch.
  9. I have a program that was using an insteon switch as a control. When I pressed the on button, the program ran Then. When I pressed off the program ran Else I replaced with an Ultra Pro ZW switch and the program does not recognize the on push:? Any advise will be helpful:
  10. Motion sensor II now has sensitivity settings for motion. Is lower or higher more sensitive?
  11. I am also having the same issue. It connected to ISY just fine but will not respond? Is there a recommendation for another motion sensor that is more reliable and small?
  12. Thanks Michel but this is the process. Reset ISY - Restored ISY - unplugged ISY unplugged PLM, held button while plugging in for 10 sec - Connected internet cable to plm and ISY Turned on ISY restored plm I will try again this evening
  13. OK I am having the exact same problem. 5.0.13 was working then no communication with anything wireless purchased new PLM - Nope, this did not fix the issue 30 second reset on ISY and PLM, started from scratch, wireless works and event log level 3 shows communication. Restore my ISY to the previous save and no wireless showing in level 3? Yet I can write changes to these devices??? I am proceeding with rebuilding everything.
  14. Thank you My point is that the new motion sensor for insteon (perhaps not fully supported is the cause) only captures 10% of the old sensors. I have the new 2844-222 next to the old 2842-222 and added a variable for each sensor. I can then count the number of on's and the new sensor is terrible. If this is true going forward I would add a Z Wave module to my ISY for flexibility but i currently have no experience with Z Wave. All feedback is appreciated.
